Projects hemi water crossovers- whatcha got because this sucks.
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Dec 22, 2016.
  1. DDDenny
    I want one and I don't even need one!
  2. nrgwizard
    nrgwizard
    from Minn. uSA
    Good. Glad it all finally worked out. They do look nice.
    Marcus...
  3. Kan Kustom
    Kan Kustom
    Awesome! Killer persistence. Persistence is the only thing that ever got anything worthwhile done.
  4. drumyn29
    drumyn29
  5. milwscruffy
    milwscruffy
    Glad you stuck with it, will they be aluminum or cast iron ? Hard to tell by the photo.
  6. Aluminum
    bchctybob and milwscruffy like this.
  7. sunbeam
    sunbeam
  8. bostonhemi
    bostonhemi
  9. milwscruffy
    milwscruffy
    Any progress reports ?
  10. dart4forte
    dart4forte
    from Mesa, AZ
    Performed surgery on the stock unit on my Red Ram 241. One e the crossover was separated from the water pump ***embly I had it chemical stripped and bead blasted. Got the cast iron really clean. Had the bottom below the T stat housing brazed and here you have it. No worries since the crossover is not under pressure. B43A916B-E20D-407E-8F90-8D9BF9A36C86.jpeg
    bchctybob, brigrat and Just Gary like this.
  11. Hemi Joel
    Hemi Joel
    from Minnesota
    Why do you say that it's not under pressure, I don't understand? I thought the whole system was under pressure.
    Not that you're well executed surgery on the crossover couldn't withstand some pressure. I'm sure it could.
    bchctybob and gimpyshotrods like this.
  12. dart4forte
    dart4forte
    from Mesa, AZ
    Meant to say high pressure
    gimpyshotrods and Hemi Joel like this.
  13. deucemac
    deucemac
    I am running the stock crossover on the 354 in my avatar. Have had no problems in the 15 years I have had it on the road. I am using a 180° Chevy thermostat and it is still performing well to this day.
    bchctybob likes this.
  14. Cuda340
    Cuda340
    Did you get the water crossover ready to sell? I want one, so if it’s ready, I’ll buy one. If not, put me on the list!
  15. Cuda340
    Cuda340
    Following up on this. Are they available? I need one.
  16. nochop
    nochop
    from norcal
    Change the an fittings to jic and black hose with crimped tube lock fittings IMG_8872.jpeg
  17. Hemi Joel
    Hemi Joel
    from Minnesota
    Is this available now? Where can it be bought? Is it designed to fit with 354 heads on a392 block? Thank you, Joel
  18. Fordors
    Fordors
    I think it’s been twenty months since @31Vicky with a hemi has visited here, no other information has been offered. Apparently the project died on the vine, that’s too bad, it looked promising.
  19. Nick Arias 3rd
    Nick Arias 3rd
    from Aromas, CA
    My water crossover patterns for 331-354 heads on a 392 have been acquired by Hot Heads.
    bchctybob, Hemi Joel and Pist-n-Broke like this.
  20. bostonhemi
    bostonhemi
    I sent him a few aluminum water crossovers that were never drilled to see if he could do anything with them but he busy after the move. Hope he’s ok
