Technical Rebuilt 302 has no get up! Help.
Discussion in 'The Hokey Ass Message Board' started by Brandon141, Apr 15, 2024.
  1. lostn51
    lostn51
    from Tennessee
    If it were me I’d make sure my intake was matched to my cam, something that hasn’t been addressed yet. Then call TCI and get a 3,000 stall and put some gears in the back and play hot rod :D
    Sharpone likes this.
  2. oldiron 440
    oldiron 440
    You don’t say if you’re using headers or not.
  3. Budget36
    Budget36
    Has anyone mentioned cam and gears? ;)
    WC145, Driver50x, Dos Cincos and 3 others like this.
  4. Sharpone
    Sharpone
    34 5W Paul asks if you’re running a flat tappet cam ? Are using roller lifters? Aahhh ? IDK
    Maybe back to firing order??? The possibilities are almost infinite
    Dan
    oldiron 440 likes this.
  5. GlassThamesDoug
    GlassThamesDoug
    2nd build always goes better....
  6. Rickybop
    Rickybop
    I honestly have a funny feeling it might not be a cut and dried case of the cam being too big. Cuz no matter the gears, no matter the weight of the car, no matter the torque converter stall speed... I'm thinking that a well-built overhead valve V8 should pull pretty hard at least in the higher RPM range, even with an inappropriately large cam.
    Might take some hands on detective work that we can't do here.
  7. lostn51
    lostn51
    from Tennessee
    Hmmm weak valve springs, maybe pushrod length……. I never would have gone with a flat tappet cam come hell or high water. Something to think about are the heads set up for pedestal rockers or are they studded. That would throw the geometry out on the valve train by mixing the two. I’ve run solid rollers in the late model SBF and boy do they pop with 12:1 compression but you have to measure for the pushrods.
  8. gallagher
    gallagher
    from califorina
    New distributor? Roller motors have longer push rods did you check length
  9. Deuces
    Deuces
    Actually shorter length due to the longer over all length of the roller lifter....
    finn and Sharpone like this.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Pushrod length needs checked. Could explain things.
    Deuces and Sharpone like this.
  11. flynbrian48
    flynbrian48
    "I build 'em twice, to make 'em nice."
  12. RmK57
    RmK57
    There is about 3/4" difference in pushrod lengths between flat tappet and roller pushrods. Could you even get enough adjustment to get the engine to run?
  13. Brandon141
    Brandon141
    My heads came ***embled.
    Shorty headers
    Longer pushrods, the roller on rockers are riding center of valve stem.
    Flat Tappet cam I already had, so I used it.
    4:11 gears are next. I’m going to try that first and see what happens, I need to change the rear gear anyway!
  14. Cooder2
    Cooder2
    from tejas
    Rear gear - 2:47 or 2:73
    Yikes there's a good part of the problem, 2:47 ??
    Sharpone and seb fontana like this.
  15. Kerrynzl
    Kerrynzl
    Do one thing at a time !
    Gears is a good starting point.
    Before you rip the engine apart , give it a compression check ,and a vacuum test.
    Many years ago I heard a seasoned racer say "you start at the tyre footprint and work your way forward, then up through the engine, and eventually you end up at the accelerator pedal" :D:D
    This is so true in many cases
  16. seb fontana
    seb fontana
    from ct
    I am wondering if the heads can be milled, probably could handle .050 but I don't know where that would put the cc's. Edelbrock for answer.
  17. Budget36
    Budget36
    I think he corrected himself on the CC size. They are 60cc as I recall, but not 72?
    Kerrynzl and Sharpone like this.
  18. Sharpone
    Sharpone
    The Flat Tappet Cam with roller lifters !!!!!
    I’ll bet a doughnut, a cup a coffee and a dollar this is the problem.
    1) Profiles are not the same
    2) something or many something’s are going to wear at a rapid rate.
    Put the factory stock cam back in !!
    See if it runs good
    Hopefully still have original cam, fairly inexpensive and easy to swap.
    Sorry didn’t mean to yell but FT cam with rollers sent bells, whistles and light bulbs off in my pea brain.
    Good luck
    Dan
    RMcCulley and Deuces like this.
  19. Kerrynzl
    Kerrynzl
    He said he put longer pushrods in with the flat tappet cam. [this cannot be done with roller lifters]
    My interpretation, is he pulled the roller cam and lifters and replaced it with a flat tappet cam and lifters he already owned. [so we can ***ume he also used the matching lifters that were already broken in]
    If the lifters were mixed up, it could've chewed a lobe BUT this would've shown up as a noisy tappet and rough running long before it became a performance problem.
    I agree with the stock roller cam suggestion but he could do the rear gears first before opening up the engine.
    @Brandon141 have you tried thrashing it up the road manually holding the gears in 1st to get some revs out of it.
    Your engine should pick-up some grunt at about 3-3500rpm
  20. 1biggun
    1biggun
    I don't care what cam or engine mods mods
    2.5?? gears with a over drive trans is a problem even if he fixes the engine issue.
    It's a heavy car with a small engine and a stock stall.
    I'd run 3.70 ish gears with the OD .
    I have 4.11 in my Mustang and OD and it's a bit to low geared for the interstate, long trips. I wish I'd gone with 3.73 gears for this street car.
    If I was racing it or not doing interstate then my 4.11 are OK.
    The other issue is with the Ford OD auto it gives shift right at the wrong time going into OD when it's pulling way to hard. Rough on the trans snd in stock form I can't prevent the shift .
    That cam is way to big and unless you checked it with a degree wheel who knows were its really at . It's likely retarded from the sounds of it. That boat needs a torque making engine not a high RPM engine with those gears and weight . In top gear you would need to be going 220 MPH to have the RPM at peak HP.
    IS That a 600 holley ?
    The whole point of a OD is to allow lower rear gears so you can accelerate faster . I have 2.56 gears in a vette woth a turbo 400 and at 55 the stock converter is not even locking up yet . With a OD I'd be idling LOL.
    OP your going to want to do gears no matter what so I'd pay the toll first . Then if the engine dosent run right fix it.
    I'd do a compression test if it's low I'd bet the cam is to retarded for any use under 3500 RPM
    Sharpone and Brandon141 like this.
  21. Brandon141
    Brandon141
    It was a brand new cam and matching tappets!
    And I haven’t tried rolling in 1st and revving it out. I will definitely try it on Sunday when I get back home.
    Sharpone and winduptoy like this.
  22. Sharpone
    Sharpone
    Brandon141 I owe you an apology should’ve known you changed lifters with the cam.
    Good luck
    Dan
    ekimneirbo, Budget36 and Brandon141 like this.
  23. Brandon141
    Brandon141
    No problem Dan. This is a long thread!
    Sharpone and Budget36 like this.
  24. Kerrynzl
    Kerrynzl
    He has 26.85" diameter tyres , so it would be better with 4.10's
    This is a Free Test :D
    2.73:1 gears in 1st gear [2.40:1] is slightly lower than 4.10's in 2nd gear
    So it will need some urging to get off the line initially then it should wind out if you hold it in first
    [In theory you should get 73 mph in 1st @ 6000 rpm]
    AOD's are an amazing trans, But there is one problem [no 2nd gear hold]
    You have 1 , 3 , OD , N , R , P , So to hold it in 2nd you need to click into 3 then back into 1 [after it shifts into 2nd]
    Do all the free tests before throwing $$$ at it [unless you like blowing $$$$ on experiments for other people]
    Also did you degree the cam when you installed it?
  25. RmK57
    RmK57
    Funny enough my old Fordomatic worked the same. Had to pull it back into low after it shifted into second , then up shift to drive.
    nosford and Sharpone like this.
  26. flynbrian48
    flynbrian48
    Wait, WHAT? Roller lifters with a flat tappet cam? That can't work either, along with that super long legged rear gear. Those bits are not interchangeable, the distributor gears aren't compatible, you've got a miss-mash of parts that aren't designed to work together.
    Deuces likes this.
  27. RmK57
    RmK57
    Look at post #113.
  28. Driver50x
    Driver50x
    One thing I would do before changing any parts. Hold the engine at about 2000 RPM and pull off one plug wire at a time, just to make sure you don’t have any dead cylinders for whatever reason. Also spray in some carb cleaner and create a vacuum leak at 2000 RPM, just to make sure the fuel mixture is somewhere in the right ballpark.
  29. Brandon141
    Brandon141
    Ok, just took my car up the road. Put it in 1st and it eventually climbed to 5000 rpm. And it ran like dog sh*t ! I have to re-adjust the rockers and probably retime it. 4:11 gears will be ordered next week.
  30. Budget36
    Budget36
    At those RPMs, even with the tall gears you have, the car should not be sluggish.
    I’d hold off on the gears just yet, look deeper into the engine.
    Ie land speed cars have healthy engines and run tall gears. They are certainly pulling well at those RPMs.
