Projects Squaring up a body - 35 Chevy Query
Discussion in 'Traditional Hot Rods' started by meeksie, Nov 15, 2022.
  1. In_The_Pink
    In_The_Pink
    Just keep doing exactly what you are doing, please, regardless of comments or the lack thereof. It's a treat to watch and follow along, and I'm sure I'm not the only one who is inspired by your progress. :)
    What can you tell us about those (***uming) magnets you are using? Is the black triangular thing on top an on/off type thing or maybe just a knob? May be a down under thing we (I) haven't seen in the U.S., but they look interesting.
  2. meeksie
    meeksie
    from Australia
    Initially the outer sides of the frame started as one piece and I was going to fold the skin over the frame but I changed my mind after making the skin. I have changed it to somewhat like a ford inner and outer.
    Initially I put in the small (outside) 45 degree bend into a straight piece of material and then shrank the inside with a foot shrinker to get my shape same as the 1/4 panel. I then put in the inner 45 degree bend. Because I changed direction they are now made of 2 pieces with a final 90degree bend welded around perimeter - the four edges of the frame. I thought this way would give me a better way for water to drain into the boot gutter and reasonable gaps up top.
    Yep they are Mag-Jig Magnetic Clamps the small ones are good for 95lb and the bigger ones 150lb of force. They really help me out as I mostly work alone in the shed and being able to be turned on and off is really handy. I got them from Lee Valley (Canada) some time ago and were well worth the price and postage. We can get them local in Aus now which is good.
  3. meeksie
    meeksie
    from Australia
  4. deathrowdave
    deathrowdave
    from NKy
    Amazed at the beautiful work . Stand tall and be proud
    meeksie likes this.
  5. inthweedz
    inthweedz
    Great work, another wooden framed Chev saved.. Those boot lid struts are from EJ-EH Holden wagons (from memory) HD on had the wind up window..
  6. meeksie
    meeksie
    from Australia
    Thanks I had no clue what those struts were off, I do plan on getting them coated but I have no idea how to redo the rivets to dip and coat them properly.
    inthweedz likes this.
