Projects Jordan's 29 Ford Roadster
Discussion in 'The Hokey Ass Message Board' started by Cali4niaCruiser, Oct 18, 2022.
  1. Cali4niaCruiser
    Cali4niaCruiser
    I machined these bosses to mount the steering box. I've always felt that flat plate style mounts with a vega box makes them look out of place. Hopefully these make the box look more at home...
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Cali4niaCruiser
    Cali4niaCruiser
    Tim, jet996, attitudor and 12 others like this.
  3. Bandit Billy
    Bandit Billy
    jet996, Kelly Burns and chryslerfan55 like this.
  4. Cali4niaCruiser
    Cali4niaCruiser
    Back on drivetrain alignment voodoo
    Runout measured .0075 so I had to get offset dowel pins. I managed to get it down to .005", just in spec.
    Working on making the T-5 fit. Started by t******* the beating retainer down on the lathe.
    [​IMG][​IMG]
    Everything fits, but the clutch disc is bottomed out all the way on the splines, so I've got a 9g steel trans spacer coming that should get things landing where they should
  5. Cali4niaCruiser
    Cali4niaCruiser
  6. Cali4niaCruiser
    Cali4niaCruiser
    Decided to remake the engine mounts I fabbed up some 14 years ago. Dimensionally very close to the originals. My usual process. Solidworks model, 3DP prototype then CNC...
    The original part
    Model
    3D Printed Prototype
    Job Stock
    Surfacing
    https://youtube.com/shorts/txaDALxnqjc?si=OfQ49UvwuiY6Lqyk
    2nd OP
    Finished product ready for hand blending and polishing... [​IMG]
    [​IMG][​IMG]
  7. Cali4niaCruiser
    Cali4niaCruiser
    Bolted up...
    Time to design the lower half now. I've got speed holes on my mind...
  8. Cali4niaCruiser
    Cali4niaCruiser
    Following my usual process of making a mountain out of a molehill...
    I started with lots of measurements and CAD models. After about 5 revisions and plenty of sample 3D prints I came up with a design that worked well and looked the way I wanted.[​IMG]
    Testing the fit...
    5 axis machining...[​IMG]
    After 2nd op...[​IMG]
    [​IMG][​IMG]
    Working on hand blending them to give them a more organic look, then polishing next.
  9. Your level of craftsmanship is outstanding. Keep it up!
    Cali4niaCruiser likes this.
  10. Cali4niaCruiser
    Cali4niaCruiser
    I drilled all the way through the frame and welded in some threaded bosses. Bolted in my mounts and, viola. Its tight packaging getting the vega box, motor mount and low mount alternator all in the same real estate. But as we say in the machining business "clearance is clearance!"[​IMG]
    [​IMG][​IMG]
  11. Cali4niaCruiser
    Cali4niaCruiser
    The next rabbit hole I'm jumping down; Trying to make my own polyurethane motor mounts...
    I started with an Speedway motor mount kit. The upper works fine as is, but the lower is too wide to use in my custom motor mount setup. So I figured, heck with it. Why not try to make my own from scratch....
    I designed a "mold over" setup that places an aluminum core at the center and gets encapsulated in .080" of 60A liquid polyurethane. [​IMG]
    [​IMG][​IMG]
    I popped my first attempt out of the mold to find lots of air pockets and a mount that still felt too soft...
    I'm going to revise my mold, get a harder poly and give it another shot...
    The 39 guy, charleyw, Tim and 8 others like this.
  12. BigJoeArt
    BigJoeArt
    @Anderson is also playing with a similar casting of polyurethane thing, maybe he'll have an insight?
  13. Cali4niaCruiser
    Cali4niaCruiser
    2nd attempt: I used 80A durometer poly this time. Density is spot on where I want it. The new 3D printed molds proved to work pretty well and didn't cause any major voids. The one big problem I faced with this attempt was lots of micro bubbles being trapped. I think I caused this by pulling too much vac on them in the vacuum chamber.[​IMG]
    [​IMG][​IMG][​IMG]
    I'll take my learnings and go for a 3rd attempt...
  14. Cali4niaCruiser
    Cali4niaCruiser
    Many attempts later, I got my process pretty well figured out. I managed to get a handful of usable units. I want to play with this some more at a later date. I need something tougher than the urethane I'm using now.[​IMG] [​IMG]
    The 39 guy, Tim, cla5675 and 3 others like this.
  15. Cali4niaCruiser
    Cali4niaCruiser
    I bought some Brookville cowl sides to replace my hacked up originals. Unfortunately the fit really wasn't great. Specifically in the top corner, things just didn't line up. Angles were too shallow, lines weren't very crisp. Pretty much on par with all the other aftermarket panels I've ever bought...
    I decided to demote my replacement panels to patch panels. Chopped off what I needed and welded them in...
    Need to do some slapping to get things back in line, but overall I'm happy with the outcome...
    brEad, Finnrodder, Jeff34 and 5 others like this.
  16. Cali4niaCruiser
    Cali4niaCruiser
    Finally got some time to start digging deeper into the body. I'm in the process of cutting out everything I did in 2012. The cowl always sat ****eyed on the sub-rails and it bothered the heck out of me. The quarter panel patches never had the right shape and looked awful. Now that I have a nice square ch***is, my thought is to start from the bottom again and work my way up... [​IMG]
  17. 05snopro440
    05snopro440
    Wow, your work on this car is really incredible. Hadn't seen it before but following along now!
  18. The 39 guy
    The 39 guy
    Glad I found this thread today! Not sorry I filled up your alerts box with likes. You have great planning, design and fabrication skills! Thanks for sharing your project with us!
  19. Cali4niaCruiser
    Cali4niaCruiser
    Designed and built a 54”x90” fixture table for the home shop. It’s just big enough to get an old twisted up roadster body on it to straighten things out… IMG_3414.jpeg
  20. brady1929
    brady1929
    Wow! Your work is amazing.
  21. Tim
    Tim
    from KCMO
    Looks beefy! Should be a great ***et!
  22. KevKo
    KevKo
    from Motown
    All I got is “wow”! That’s superb work.
    Cali4niaCruiser and Kelly Burns like this.
  23. @Cali4niaCruiser Great work! How did the you finish up your block off plate/PVC deal to the carb? How did it work out on the engine stand run?
  24. Cali4niaCruiser
    Cali4niaCruiser
    I ended up making a fuel pump block off with a threaded hole in the middle and ran soft line up to the PCV during the break in. Worked great. I’ll probably end up tapping a hole in the intake for the final install
    Kelly Burns likes this.
  25. Thanks! I'm anxious to see what you do.
  26. Cali4niaCruiser
    Cali4niaCruiser
    Made up some stand offs to fix the sub rails to the table. Time to start getting this body figured out
  27. patsurf
    patsurf
  28. Cali4niaCruiser
    Cali4niaCruiser
    anothercarguy, Stu and Tim like this.
  29. Cali4niaCruiser
    Cali4niaCruiser
    We're all the way in now... It was easy to see where a bunch of rust jacking had happened over the last 96 years. I'm dis***embling every panel an pulling the bracing to fix up all the seams. I'm planning to drill the rivets out on the quarter panel irons to get those seams as well. When re***embling the irons do you guys like to source flush rivets like factory, or just use a flush screws? Image (36).jpg Image (35).jpg
    anothercarguy and lurker mick like this.
  30. alchemy
    alchemy
    I bet you’re the first guy to ever remove the T strips to clean behind them.
