Technical The Old Days of Dual 4's
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 30, 2024.
  1. Terry D
    Terry D
    from NY
    I like Edelbrock 500 CFM carbs..A lot of people don't like them I know,but they are very easy to tune with metering rods and jets. Lots of info on this on the net. I have 4 cars with multiple carburetion and once you have them dialed in they are as good as a single carb [or better] and a lot more fun to look at.
  2. PackardV8
    PackardV8
    IIRC, the Mopar Six Pack and Hemi were both available in 1971.
    jack vines
    SS327, 2OLD2FAST, Deuces and 2 others like this.
  3. GlassThamesDoug
    GlassThamesDoug
    That's right, forgot about 340 6 pack AAR too. Mopar must have been the only one left after hp wars.
    SS327, chevy57dude, Deuces and 2 others like this.
  4. Balljoint
    Balljoint
    Very nice! With a 428 I’ll bet that thing scoots!
    31 B'ville and Deuces like this.
  5. swade41
    swade41
    from Buffalo,NY
  6. Jalopy Joker
    Jalopy Joker
  7. Jalopy Joker
    Jalopy Joker
  8. hipojoe
    hipojoe
  9. Robert Pierce
    Robert Pierce
    IMG_0732.jpeg Edelbrock intake and 500 carbs on 283, 4 speed. Works like a champ.
    enloe, Deuces, swade41 and 7 others like this.
  10. 53olds
    53olds
    This is what I'm gonna run on my 390 FE I'm building for my 60 F100
    enloe, winr, Tow Truck Tom and 6 others like this.
  11. Deuces
    Deuces
  12. AmishMike
    AmishMike
    See post 118. Bore out the dual plane manifold, couple aluminum plates & 2 two barrel carbs. Cheap, easy to tune & looks great
    Deuces likes this.
  13. Deuces
    Deuces
    You could use 2 Holley 350s or 2 Holley 500 2-bbl carbs....
    Tow Truck Tom likes this.
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Guaranteed to make you stop @ every gas pump ...
  15. Gotgas
    Gotgas
    from DFW USA
  16. jimmy six
    jimmy six
    I’ve have dual quads on my car for 7 years and there was no measurable difference over a single 4 barrel once I got use to driving the car. It actually improved over time.
  17. swade41
    swade41
    from Buffalo,NY
    An engine needs X amount of fuel to run at a particular speed, if the single 4 needs half throttle to achieve it a dual 4 needs only a 1/4 throttle to supply the same amount of fuel.
    One of my cars averaged 15.8 mpg running 3,000 rpm on an extended trip, pair of 600 Carters, 4.11 gears and non overdrive trans.
    enloe, Tow Truck Tom and loudbang like this.
  18. Besty34
    Besty34
    always ran dual quads just love the look, always ran Edlebrocks never had a problem just take off the tags and spray gold for a more vintage look IMG_4202.jpeg
  19. Rootsy
    Rootsy
    from Monroe, MI
    Little 289 I had back in high school. Never ran very well. Later in HS I swapped to an Edelbrock Crossram and it ran way worse still….
  20. 1biggun
    1biggun
    The manifold comes with a thin steel plate that you use if its not a quadra jet . Works fine .
    enloe and Chucky like this.
  21. D-Russ
    D-Russ
    Carter 500s on a 354:
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Sorry , I was commenting on the 2x500 cfm 2 bbls . My 2x4 bbldoes very well mileage wise @ 16.5 overall mpg average .
    enloe likes this.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    Venturi shape & size are part of the equation as are booster configuration. .
    enloe likes this.
