Technical Hard chop: sitting on the chopping block
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 21, 2024.
  1. Woogeroo
    Woogeroo
    from USA
    This is interesting to watch, thanks for sharing.
    65standard and 31chevymike like this.
  2. I’m no metallurgy expert. The last couple 18 gauge panels I bought seems harder to shape.
    just whatever cold rolled the steel place has.
    The 20 gauge is almost too EZ
    We had 19 gauge occasionally in my pro days. Seems to work easier that the 18 I’ve been getting.
    31chevymike likes this.
  3. krylon32
    krylon32
    from Nebraska
    In the past I think I bought 18 or 19 gauge Aluminum killed steel sheets that were easier to shape? I may have the terminology wrong?
  4. gimpyshotrods
    gimpyshotrods
    You are correct.
  5. gimpyshotrods
    gimpyshotrods
    I am experiencing that, too. Something changed, or age/wear is taking its toll.
    AK steel seems easier to form still, but I have to order it.
  6. Mo rust
    Mo rust
    That's probably why Henry used 19 gauge on the body pieces
  7. 65standard
    65standard
    661F63CE-9FC0-4333-B4A5-A1CF47CF695F.jpeg Finished filling the cowl gap
  8. 65standard
    65standard
    B34C21D6-718F-4D4E-8E9D-4BBA5696650A.jpeg 68359E29-5D03-4AB7-AC81-DCDC038D10DB.jpeg 7AEAD43B-E216-4B21-A8F6-751B9012B933.jpeg Back on the rear window now. I cleaned the cut on the upper half of the window. Used ****m fluid on the lower half and cleco it together. Scribe the seam and pull it back apart
  9. 65standard
    65standard
    C5FBEBA7-B2D4-4E75-9F8F-E4C535137802.jpeg 613D28A9-6ECA-493A-A1D0-BC23A9E0B30E.jpeg D904EBFD-787E-43BC-AE5B-0F6D74B258C5.jpeg 6FB3E210-0E6E-4F39-B7C3-20AD14915E75.jpeg F3AE4F6B-D746-4320-A13E-66B519AD9CF1.jpeg D4250DF1-1618-43AB-B773-ECD65E1D9631.jpeg Now Is the perfect time to weld up the roll bar. Would be nearly impossible to get it fully welded before.
    I cut the window at the scribe and left a small tab so I can cleco it back together. Carefully align the seam and start tack welding it up.
  10. 65standard
    65standard
    84993BA8-3D3E-4C01-B503-01FA88E1F30C.jpeg Continuing with the back window. Finished tacking the seam.
  11. 65standard
    65standard
    7E5E6753-44D6-42C7-9CA3-B1A8B2605A9F.jpeg Next set the back window pitch to 82.2 degrees, same as the B-pillar pitch.
  12. 65standard
    65standard
    E75CBB83-8F96-4D44-9967-E6726066C4F6.jpeg 2F1DC92B-A8EB-466A-9BC2-18FC5819AD5C.jpeg D4A345E4-1F24-4466-829F-635AA1EF4BCE.jpeg Then tack it in to the roof to lock the pitch it. Clean the corner openings so I can scribe them to fit.
  13. 65standard
    65standard
    06D8A4A8-8831-42DB-8AEA-342549B96C09.jpeg Some ****m on the corners so I can see the scribe line. Scribing will be in two steps. If I just hold the corner on the inside to scribe it, it will be the thickest of the 19ga too small. I need to do this in two steps. To be continued…
  14. 65standard
    65standard
    89DA4B42-D4EE-4162-A7A7-6614917C7B57.jpeg 8C3D80D2-52BA-49B3-AB28-2007870588B1.jpeg C5BE610E-E459-4422-B0F1-BA8F468358E4.jpeg Test fitting the corner back in. I moved it around until it flowed with the top just right. I’m happy with it. I will scribe two edges now. Trim that and put it back in flush to scribe the last edge.
  15. It's such a great thread so far. Keep the updates coming, and thank you for all the detailed photos.
    65standard, Outback, Woogeroo and 2 others like this.
  16. 65standard
    65standard
    785C5ED8-D035-4770-BFBA-A3A3D88EF6E6.jpeg 27CF6EBF-7C94-431B-8EF0-DD23BC95B581.jpeg 093AD0DD-DF19-42AE-A786-1D1D5648DF3B.jpeg E16F0B09-F31B-45C4-804B-F302C64CCE34.jpeg 89023939-7ACF-4B48-9E92-84F6F25165DC.jpeg 41B8FF4A-D745-4586-8708-AF161A384185.jpeg I scribed a couple alignment marks then removed the corner. Trimmed it with snips and put it back in.
  17. 05snopro440
    05snopro440
    The profile is looking really good.
  18. 65standard
    65standard
    C67C52F7-B353-42AF-BBA9-08E57372AF3A.jpeg And with the roof panel sitting on. Next will be the other corner and the roof.
  19. Have you thought at all about leaving the soft insert in place?
    Outback and 31chevymike like this.
  20. guthriesmith
    guthriesmith
    Looking great!
    31chevymike and Outback like this.
  21. 65standard
    65standard
    I don’t like the soft insert. They flap in the wind. I thought about using the metal insert and gluing the vinyl to the metal. But I still don’t like the look with the aluminum nail strip. That makes the soft top look like a mattress on the roof.
    I’m not welding the steel insert in. It will bolt on the top rolling bones style. I just don’t know if I’m going to flange the roof to make the insert flush or just lay it on top.
    But I’m still thinking about wrapping the insert in Mercedes material to keep the look of an original car, but without the tack strip.
  22. The37Kid
    The37Kid
    Really like the way the corners worked out.
    65standard, Outback and 31chevymike like this.
  23. My old work place made an aluminum roof insert
    Removed the tack strip from the roof and fabricated a deeper channel. The roof insert had an aluminum band thick enough to thread. The insert with band was flush mount with the roof and bolted in from inside.
    No tack strip
    Looked great
  24. 65standard
    65standard
    4A341417-518E-4160-A075-D58185EEAF25.jpeg A2BC3503-902C-4B31-919D-F51E1AD4C2A7.jpeg 99523DB5-6DD3-4826-B109-EEA3621ECB4B.jpeg CA8FD3D6-8C12-419E-9A47-EB2ABDBCEB15.jpeg 15B58045-9B40-41C0-8B0D-9B8EFED90A47.jpeg I cheaped out and used a “Henry Ford Steel” roof insert.
  25. flamedabone
    flamedabone
    Some Mustang guy is gonna be mad at you.
    -Abone.
  26. The37Kid
    The37Kid
    Looks like that one rotted up to the windows, thought to restore it. o_O
  27. 65standard
    65standard
    The guy I got the mustang roof from wasn’t too happy when he asked what I was going to do with it. He said “I was hoping you were a mustang guy.”
  28. choptop40
    choptop40
    Rustang ....interested to see how you pull off the bolt on top....
    65standard, The37Kid and 31chevymike like this.
  29. Fogger
    Fogger
    I used a '65 Mustang Coupe roof top when filling my 3W. I did get some flack but the Mustang was a total and using Ford sheet metal on my Coupe sold the naysayers that it was acceptable. LOL
  30. Cali4niaCruiser
    Cali4niaCruiser
    Fantastic work! Thank you for sharing. I've learned lots from Peter Tomasini videos, glad to see his name mentioned on the HAMB
