Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    Yep. It’s not that sort of noise. It’s just like when you use a ratchet on a winch. Really weird. Did go out this afternoon to get a video of the noise and it’s not doing it now.
    Cant be the parking pawl or sprag as the output isn’t turning.
    On a positive note I got the AC compressor turning. Apparently someone hadn’t turned the dial to cold!
  2. ClayMart
    ClayMart
    Geez. It does my heart good to see someone who understands how something like an automatic choke is supposed to work. And knows how to logically investigate and troubleshoot it when it doesn't work. Then decides to just go ahead and fix what's already there as opposed to cobbling things up with a manual choke cable kit or adapting an electric choke thermostat. As one of my former auto tech instructors was fond of reminding us:
    "Knowledge of operation is the first step to proper diagnosis."
    Good show, old chap! :D
    Don't know about your specific transmission and the noise when shifting to reverse, but some transmission used to make a similar groan or low frequency hum when first put into gear. Sometimes the cause was a sticking or loose valve in the valve body, or a weak or broken spring that was supposed to hold tension against a valve. Usually the noise only lasted a second or two and often didn't seem to have any ill effects on the rest of the transmission.
  3. Oneball
    Oneball
    Thanks Clay, in my mind if you want something to just plain work what the manufacturer intended is usually best, I broke that rule and did try an electric choke and guess what…didn’t work properly
    Transmission is the stock 3 speed Cruise-o-Matic, I’ll try adjusting the linkage and servicing it first. I think the detents don’t quite line up with those in the box
    Algoma56 likes this.
  4. Oneball
    Oneball
    Got the old master cylinder and servo off and the “adapter” bracketry
    New servo fixed into the factory mounts
    Think I can cut, turn down slightly and thread the fixed push rod off the old servo, so might have a go at that tomorrow if not I’ll get a Rose joint the right thread.
  5. Oneball
    Oneball
    Unfortunately I’ve not got a 7/16-20 nut so need to get a jamb nut then I can fit the new booster and start on the brake cylinders.
    bobss396 and Nominal like this.
  6. Oneball
    Oneball
    Started painting the underside, blimey that’s tedious.
    Also ordered some seat belts, 3 point for the front and a couple of lap belts for the back, mainly to stop the Ms’ bags whacking you in the head if you stop quickly! Chose the sort of olive green on the right for the belts. They’ll make them up and post them next week.
    bobss396 and 61Cruiser like this.
  7. Oneball
    Oneball
    Seatbelts arrived, think they’re a good colour.
  8. guthriesmith
    guthriesmith
    Man, you took a great car and are making it so much better! I hadn’t really taken time to catch up until today and it is coming along great! Helps with my motivation to start working on a car I have sitting outside the shop that is just a couple years too new to talk about here but similar in many ways to yours. Hoping to make it a decent driver as starting today.
  9. Oneball
    Oneball
    Thanks Guthrie, get on with it, it’s almost warm enough to work on now!
    Fingers crossed a couple of weeks and I’ll be able to take it for a spin round the block and start breaking things!!
  10. Oneball
    Oneball
    I needed a brake pedal to pushrod bush as it was missing when I got the car. After searching for one it came up that it was still being used on Mk6 Transit vans. I found it difficult to believe but as it was so cheap from Ford I thought I’d order one. And what do you know it fits, seems that bush has been in use unchanged for 50 odd years.
  11. Oneball
    Oneball
    Took the rubber filler strip that covers the gap to the bumper off the rear body seam
    And no rust, which I find a bit of a miracle coming from the UK
    Got about half the underside painted now
  12. Pontmerc
    Pontmerc
    from Finland
    You cant go wrong for owning a mercury. IMG_20220927_193201.jpg IMG_20221006_161537.jpg
    deadbeat, williebill, Nominal and 5 others like this.
  13. Oneball
    Oneball
  14. Oneball
    Oneball
    Finished painting underneath and moved on to brakes.
    Booster in place and set up
    Attached to the pedal
    Master cylinder on, all Ford factory stuff and not a bodged bracket or half dozen washers in sight.
    Just need to find what I’ve done with the brake light switch o_O
  15. bobss396
    bobss396
    Nice and clean... we expect no less. I always carry a spare switch in the glove box.
    Oneball likes this.
  16. Oneball
    Oneball
    Cleaned and waxed the wheels I got off eBay before Christmas, hopefully will drop them off at the tyre place before work tomorrow IMG_7256.jpeg
    As an aside, has anybody been watching Fallout on the telly, there’s loads of amazing 50s cars that need saving, wonder where they got them from.
  17. Oneball
    Oneball
    Got the rear bumper off so I can paint the irons and inside of the bumper.
    New slave cylinders on the back. Is there any trick to getting the springs off the top post or is it just a case of prying them off?
    And new brake hose, axle breather and shocks
    guthriesmith likes this.
  18. Pontmerc
    Pontmerc
    from Finland
    Take all else springs locks adjusters off and then grab shoe with both hands and use it as a tool to lenghten the upper springs.
    No need to use any special brake shoe spring pliers.
  19. Oneball
    Oneball
    That’s what I normally do but couldn’t get it to work because of the retainer behind the springs on the top post.
  20. Oneball
    Oneball
    Pulled the rear seat base out to look at fitting the rear belts. Not even one single penny under there :(
  21. bobss396
    bobss396
    I have been using the same Craftsman brake spring pliers since 1975, also the hold-down spring tool, made by KD.
    Oneball and Truckdoctor Andy like this.
  22. Oneball
    Oneball
    Front slave cylinders and new hoses on
    Wheel bearings cleaned and re-packed
    Master cylinder connected up and bled and we have brakes.
    You ******! ;) That jinxed it! Brake lights are stuck on. To be fair probably my fault, I used a torch to make sure I got the union out of the old master cylinder without rounding it off and probably melted the switch :oops:
    guthriesmith and bobss396 like this.
  23. ClayMart
    ClayMart
    I like that your upgraded booster and master cylinder look like they could be the 1962 original equipment style. Especially that single reservoir, one-circuit master cylinder. Hope everything stops as good as it looks! ;)
    Oneball likes this.
  24. Oneball
    Oneball
    Only driven it into the garage but the booster definitely works whereas it didn’t before when it required quite a force to hold it against the torque converter when it was on full choke.
  25. Oneball
    Oneball
    Started on seatbelts, got the mounts in for the belts in the rears, cut two holes in the carpet in the wrong place for the fronts which has really annoy me, I’ll see if I can stick the bits back in with some tape backing. ********!
  26. Oneball
    Oneball
    Belts bolted in
    and one of the front retractor units.
    Baumi and guthriesmith like this.
  27. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Its really unbelievable how much of a clean Merc you own... man its solid and a Creampuff!
  28. Oneball
    Oneball
    I know, you ought to see the floors under the carpet, I find them unbelievable on a 60 year old car.
    bobss396 likes this.
  29. Oneball
    Oneball
    Made up some inserts to allow me to bolt the top of the front belts into the b pillar
    Then threaded them up through the bottom of the pillar and riveted in place
    Front and rear belts now in
    Just need to do the scary bit and put a hole in the b pillar trim!!
  30. bobss396
    bobss396
    I had to measure my pillar garnish a bunch of times. I put a small hole in it first and eyeballed it before going full size. The plate and cover do a good job covering it up.
    Oneball likes this.
