Hot Rods ZIP WATER PUMP RISER FACT THREAD!!!
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Apr 23, 2024.
  1. ALLDONE
    ALLDONE
    made it... just waiting on the aluminum pump..
  2. '51 Norm
    '51 Norm
    from colorado
    Good Lord! And I thought that Pontiac pulleys were a pain.
    bchctybob and 2FORCEFULL like this.
  3. deucendude
    deucendude
    from norcal
    Mine are all fine and line up with no problems.
  4. deucendude
    deucendude
    from norcal
    Mine all worked fine. 3 of them. Even put one on a Desoto. Did cut some ears off though. 20200501_122316.jpg 20220823_173618.jpg
    GlassThamesDoug and bchctybob like this.
  5. ALLDONE
    ALLDONE
    thanks for the pics,...makes it a lot easier to look at what you did rather than amagine.....
  6. ALLDONE
    ALLDONE
    does the pump fit the zip, or all differant??? any pics???
  7. RockyMtnWay
    RockyMtnWay
    Here’s a few I’ve installed/used.
    Top one not painted yet, but might leave as is.
    Bottom pic was one I trimmed both ears off and used a lower alt mount.
  8. Mr48chev
    There was one hiding in plain sight on this 32 that I saw Saturday. IMG_2415.JPG
    Just Gary, bchctybob and X-cpe like this.
  9. ALLDONE
    ALLDONE
    Well, finally got the aluminum water pump.... spent the day hunting down 1/2 to 1/2 fittings... then a couple hours looking for my 1/2 pipe thread tap, finally went and bought a new one... so now all I need is about 6'' of 1/2 heater hose to be done... that and a new top pulley and fan...
    upload_2024-5-3_20-44-33.jpeg upload_2024-5-3_20-44-33.jpeg IMG_2479[8723].jpg
  10. ALLDONE
    ALLDONE
    update,... got-er done.... works perfect... went from running 220 and up in traffic @ 85 ambient to now runs right at 180 in 104 ambient... the one thing I didn't check was the stat.... must be a 165 in there... might go up to a 175
    pprather and 72yenkonova like this.
  11. wheeltramp brian
    wheeltramp brian
    Cool....got a pic?
  12. GlassThamesDoug
    GlassThamesDoug
    Somec trick solutions there.
  13. 325w
    325w
    My cope runs several degrees cooler all the time since I changed to Zips.Hot day AC on no issue
  14. 325w
    325w
    Ofilleys had a replacement pump for the 230 Chevy six that had the cast impeller like flower cooler used
  15. choptop4
    choptop4
    Thanks for this information . I am swapping out engines this summer in my 32 and have everything in line . I thought !
    I had forgotten about zips. Thanks again.
  16. 4wd1936
    4wd1936
    from NY
    Just a quick question for those volunteering info/help. Do I understand it correctly that with a stock Chev water pump you need either a heater connected or a byp*** from water pump to manifold? Thanks
  17. ALLDONE
    ALLDONE
    what it does is,... the small hose ****s water out of the manifold and pushes it back into the block. this gets all the coolant to an even temp.. with out it the water in the block doesn't circulate till the stat opens, by then the block coolant has got to hot and the rad. struggles to cool it before it reenters the block... hope that makes sense , as there are alot that say it's nonsense and say take the stat out or drill holes in it...
  18. ALLDONE
    ALLDONE
    I never did put the shroud on... runs cool with out it... probley be a winter project...
    bymanr and RICH B like this.
  19. 4wd1936
    4wd1936
    from NY
    2FORCEFULL : Thanks, You learn something everyday.
  20. ALLDONE
    ALLDONE
    till you get to 60, then on you forget something every day...by 70 you end up with CRS
    choptop4 likes this.
  21. jimmy six
    jimmy six
    Wait until your 80 and your still changing your own oil….1/2 zimers.
    ALLDONE, bschwoeble and deucemac like this.
  22. 325w
    325w
    2 forceful where did you get your water pump.my there would no way yo tap heater outlet
    ALLDONE likes this.
  23. 19Eddy30
    19Eddy30
    from VA
    The one I pick up was from autozone aluminum , also make one one cast iron,
    I also tapped , (pipe) you can also tap to SAE thread & chaffer for O ring
    ALLDONE likes this.
  24. ALLDONE
    ALLDONE
    I cut all but about 1/4 of the ****** off then dilled and started tapping, the ****** ends up too thin to tap
  25. X-cpe
    X-cpe
    I had no problem drilling and tapping mine.
    ALLDONE and 19Eddy30 like this.
  26. 19Eddy30
    19Eddy30
    from VA
    Yes its kind of thin there , but No problem , watch how deep / tight you screw in pipe fitting / tap ,,,
    its only for water !! Not a motor mount!!
  27. ALLDONE
    ALLDONE
    also, a uni bit made drilling easy as you could see the hole get bigger and keep it straight on the car, any future I would do it on the bench before it goes in,...I need to do it on my wifes RPU, but she doesn't like me changing things on her pick up, always thinks it will never run again... I took her 55 apart years ago... took like 3 years before she could drive it again ...but it was bad *** when done
  28. ALLDONE
    ALLDONE
    looks like you used a smaller fitting than the one on the block, and I'm sure it works fine....on mine before I did the mods,.. at 80 ambient, It would climb to near 230, so I wanted to go as big as I could to get as much water flow, also went with 1/2 heater hose.. also, I don't know if you can get the cast with the cavitation plate, they say the aluminum is a super cool pump, don't know if they mean it cools better , or "LOOKS" super cool on an aluminum head motor....LOL
  29. ALLDONE
    ALLDONE
    good zips info
  30. V8RPU
    V8RPU
    from Nor Cal
    So, where can I find one to buy?
    ALLDONE likes this.
