Technical Tail gate hinges ford truck size problem
Discussion in 'The Hokey Ass Message Board' started by ActionYobbo, Oct 23, 2022.
  1. ActionYobbo
    ActionYobbo
    I’m working on my 39 truck and I am missing one tailgate hinge so I ordered some repros online and they arrived and they are 2/3 the size of the hinges so I ordered another set from a different vendor and they are also 2/3 the size of hinges I need. The bolt holes are a smaller spacing. They are just totally the wrong size. I did confirm both times that they were for truck replacement hinges. Where should I be looking for hinges that will be the correct size? Thanks
  2. gene-koning
    gene-koning
    Maybe the bed on your truck is newer then a 39, or older then 39?
    It may be an aftermarket bed, or even a bed from a different brand of truck.
    Maybe just your hinges were replaced with something that was readily available at the time they were needed.
    Lots of stuff could have happened since 39.
    Maybe you need to start talking to the vendors with the measurements of the parts you have.
  3. pprather
    pprather
    What brand and what model 1939 truck?
    Do you have a large size truck?
  4. ActionYobbo
    ActionYobbo
    I have a 1939 ford truck. The bed is from a 1940 ford truck. I do not have a sedan pickup I have a truck. Bed is original unmodified but the hinges may have been changed but they do fit the original bolt holes where the repro hinges have a smaller bolt hole and the spacing is narrower.
  5. manyolcars
    manyolcars
    Ford pickups used the same tailgate hinges from 1937 to 1973. Bob Drake is wrong about this.
  6. pprather
    pprather
    Can you give the distance from center of bolt hole to center of other bolt hole of the hinge you need?
  7. ActionYobbo
    ActionYobbo
    I was ***ured by both vendors that the pickup and the truck used the same hinges thats why I am asking here.
  8. ActionYobbo
    ActionYobbo
    I will post that tomorrow
  9. pprather
    pprather
  10. junkman8888
    junkman8888
    If you want us to help you we need pictures of the bed itself, and the tail gate.
  11. manyolcars
    manyolcars
    Yes. I have many ol trucks, Fords, and the hinges are stamped steel. Ford didnt use cast iron hinges from 1937 to 1973
  12. ActionYobbo
    ActionYobbo
    Repro hinge has a 2 inch bolt spacing with quater inch holes. The old hinge has a 2 and a quater inch bolt spacing and 3/8 holes.
    I have a truck the gas tank is under the seat. I think there is a difference in the parts used for the light weight pickup and the heavier truck like I have
    edit to add. I think I am finding out the hard way that there is a difference in parts based on where the gas tank is. I just got some more dainty undersize parts in the mail. Starting to look like sedan pickup parts are 2/3 the size of truck parts.
  13. pprather
    pprather
  14. ActionYobbo
    ActionYobbo
    Tried to get some pictures tonight in the dark with heavy rain but they are all out of focus except this one that shows the bolt holes for the hinge.
  15. ActionYobbo
    ActionYobbo
    I am back to working on this trying to get the tailgate working. It’s an original ford 1940 1 ton express bed. Only has the original holes for the hinges at 2-1/4 spacing. I will end up making the hinges to match the parts I already have. So far on this build so many repro truck parts have been undersized or totally wrong. Makes it hard when I try and buy parts and the vendor says pickups and trucks are the same. They are not. Of the major body panels only the grill, hood and windshield are the same all other body panels are different. They may look the same but 1/2” here 6” there is not the same
  16. squirrel
    just a suggestion...if you take pictures of the truck bed, all of it in one picture, taken in good weather, with good light, in focus, and post it here...then we can be more likely to figure out what you are working on, and could offer more useful suggestions.
  17. krylon32
    krylon32
    from Nebraska
    Have you tried Mack Hils in Missouri? They seem to make accurate reproduction parts.
    bschwoeble and sidevalve8ba like this.
  18. ActionYobbo
    ActionYobbo
    here are some pictures I found on the internet. My truck is a 39 1 ton that started out as a cab ch***is I managed to find a bed for a 1940 I ton which I am currently in the process of straightening and fixing the rust so its pulled down to separate panels now The only difference between a 39 bed and a 40 bed is the center stake pocket. Anyhow here is some pics of a 1940 1 ton so you can see the 1 ton bed and a 1939 1 ton so you can see what I am building
    Toms Dogs likes this.
  19. Toms Dogs
    Toms Dogs
    from NJ
  20. pprather
    pprather
    It looks like the one ton truck has very little in common with the p***enger car based pickup.
    Also, there is no one ton specific aftermarket parts.
    You will have to fabricate a hinge, or modify the standard pickup hinge, to work with your application.
    Maybe something off another brand heavy truck could be adapted?
  21. 38bill
    38bill
    from Minnesota
  22. ActionYobbo
    ActionYobbo
    Yeah I did that and was suggested to post on the hamb that has a more diverse range of builders.
    Just went there to find it and post a link here but it looks like it got nuked. The thread had degraded to arguing over commercial car Vs an actual truck
  23. Bandit Billy
    Bandit Billy
    These are the hinges on my 41 ford bed. 2 1/4" spacing and 3/8" holes. The also have a more pronounced lip that the gate rides up to like the one in your picture above. The small hinges don't have that I notice.
    5window likes this.
  24. ActionYobbo
    ActionYobbo
    Is your hinge stamped / folded metal or cast?
  25. Roothawg
    Roothawg
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
  27. Roothawg
    Roothawg
    Talk to the folks at Mack Products in Moberly, Missouri. They know Fords.
  28. ActionYobbo
    ActionYobbo
    I have sent them an email enquiry but it’s not looking good. They have no truck parts on their website only pickup parts.
  29. ActionYobbo
    ActionYobbo
    How can you tell from just the picture? The chrome is hiding the contours so it’s hard to tell.
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The thickness of the flange. Resembles that of a thermostat housing as well. Or is it just me?
    By the way, what chrome are you referring to?
