Projects K-88 Dragster / 6 Cylinder
Discussion in 'The Hokey Ass Message Board' started by Countn'Carbs, Apr 30, 2019.
  1. Countn'Carbs
    Countn'Carbs
    from CO
    I've always seen this thing with some simple white scallops maybe outlined in maroon or something with the mandatory GMC Fisher Equipped along the bottom sides or something along those lines. Decided to get on the painters schedule sooner than later and I'm certainly no artist but he said to start laying out some ideas and we'll go from there so here is a rough, rough draft to get some ideas going.
    Thinking the front 3 inches or so of the cowl is white and then need to figure out curvature and what not of tying the scallops together. Oh and don't forget each side needs to be the same....I always did **** at this artsy stuff but we're going for it anyway.
  2. FinnishFireball
    FinnishFireball
    Looking good I like your artsy plan and color choices
    Countn'Carbs likes this.
  3. saltflats
    saltflats
    from Missouri
    Looks like the artist should have no problem pull off what your vision is from there.
  4. Countn'Carbs
    Countn'Carbs
    from CO
    Took a break from art cl*** and I hated to do it but put another leaf in the front to get the perch off the axle. Put it back on the ground to see how much it raised the front end. It is what it is but hopefully the front end doesn't come up on this thing.
  5. Countn'Carbs
    Countn'Carbs
    from CO
    With the GNRS going on...makes me think of the Albertson Olds car in the museum. Here's some additional information about it and worth a watch in my opinion.
  6. Countn'Carbs
    Countn'Carbs
    from CO
    Still plugging away on this thing and was able to get some scallops laid down on it. Still need to get them striped along with some mild lettering. Also knocking other things off the list like wiring, plumbing oil gauge, plug wires, etc...
    rod1, Chucky, catdad49 and 17 others like this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    excellent work
    keep it up!
    Countn'Carbs and winduptoy like this.
  8. dirt car
    dirt car
    from nebraska
    Good to see mention of Joe Umphenour with respect to his in-liner endeavors & establishment of the National Nomad Club who also happens to be in the Colorado Racers Hall of Fame.
  9. What’s the story on the 3 2’s tunnel ram? Inquiring Inline Minds wanna know!
  10. jimmy six
    jimmy six
    Clifford Research manufactured many 3-2 cast and tubing manifolds like you see in the back of the photo. Some had equalizing tubes or p***ages and some didn’t. None went into a common plenum like a tunnel ram.
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think a tunnel ram design is about optimum for an inline six drag car. Side draft tunnel rams may be better but carb choices with a downdraft are better, as is packaging in some cases.
  12. ENUF 41
    ENUF 41
    Two thumbs up!!!
  13. Countn'Carbs
    Countn'Carbs
    from CO
    Earlier this year we had the car lettered with just some simple "GMC Fisher Equipped" on the side panels and the scallops outlined in a maroon. I leaned heavily on my two brothers for thoughts and guidance on what to do because I **** at the artsy side of things...always have. I couldn't be happier with Beth's work and you can check out more of her awesomeness here.....https://www.lildamestripes.com/
  14. Countn'Carbs
    Countn'Carbs
    from CO
    And...with the help of so many....we finally breathed some life into this little GMC. I need to figure out the whole YouTube thing to be able to post videos here but here's a still shot of it running.
    OFT, RileyRacing, Chucky and 14 others like this.
  15. Cliff Ramsdell
    Cliff Ramsdell
    Great job, love the picture but a video would be great, you’ll get it done.
    Thanks for sharing.
    Cliff Ramsdell
  16. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I love the paint scheme you have chosen. On my (unpainted) avatar carI was planning the opposite - gunmetal grey scallops over a creamy base color, with red pinstriping.
  17. Harv
    Harv
    from Sydney
    Congratulations man :):cool:
    A running FED is an awesome Christmas present.
    Cheers,
    Harv
    OFT and Countn'Carbs like this.
  18. Countn'Carbs
    Countn'Carbs
    from CO
    Thank you Harv and I really appreciate all your information and input with this 420 pump and the fuel injection in general. You have been a great help for sure!!
  19. Countn'Carbs
    Countn'Carbs
    from CO
    Although Ch***is Research was only around for a few years...here is a great video recently released by Brian Lohnes with an in depth look at Scotty Fenn and Ch***is Research.
  20. Just saw this thread . . . really a great piece of workmanship . . . can't wait to see/hear it run someday!
    Countn'Carbs and Cliff Ramsdell like this.
