Projects 31 Kustom Roadster (DIY duvall, tudor to roadster conversion)
Discussion in 'Traditional Hot Rods' started by Chevy28, Feb 13, 2020.
  1. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I just can't find the proper words to say about your labors.
    Thank You for sharing the talent you have.
    Outback, Sharpone and HelminenHotrods like this.
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Man, the welds are *****in' good.
    Metal art.
  3. continentaljohn
    continentaljohn
    Crazy how many subtle details in everything, you sir are a true Craftsman
  4. Happydaze
    Happydaze
    Fantastic stuff!
    Chris
  5. hotrodA
    hotrodA
    Boy, was I wrong!
    When I first saw the ***le I thought “PFFFFTTT!” That can’t be much, sedan into a roadster?
    Gotta be a hack job, right? But with a Duvall windshield?
    But then Ryan’s post hit!
    OH MY! Not only is your design work amazing, but your ability to turn your idea into metal art is nothing less than what we mere mortals even think about reaching.
    It’s nothing less than supernatural.
    Thank you for sharing your abilities with us!
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. HelminenHotrods
    HelminenHotrods
    from Finland
    Shifter is in stock location on the muncie. I'm going do an bench seat. There is just enough space, because the seat is going to be set as far back as possible. Shifter handle is going to be something like 55-57 chevy bench seat version.
    I have to admit toploader t5 would have been much easier... Not too much of them in Finland, and zero for sale with the s10 tailshaft... And Muncie is Muncie :)
    This type of bench seat could be possibility also :
  8. HelminenHotrods
    HelminenHotrods
    from Finland
    Hello sir ! I did the top myself for chevy. Its done with steeltubing, canvas was made from few pieces, hold together with snap-on rivets and strips. It doesnt fold, just lift off.
    Designing the form with tape:
    Finished top with finished car :
    (Old photos, chevy has been sold years ago)
  9. HelminenHotrods
    HelminenHotrods
    from Finland
    Thank you guys ! Much appreciated !!:)
    continentaljohn and Sharpone like this.
  10. HelminenHotrods
    HelminenHotrods
    from Finland
    Hahah maybe littly risky ***tle, but hopefully draws attention if someone is looking for similar things :D
    And Thank you very much, too kind word !
    -Markus
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    As said In your quote
    Nothing less than what we mere mortals even think about reaching"
    There's the words.
    Thank You hotrodA
    :D
  12. ronzmtrwrx
    ronzmtrwrx
    Man, that is some great stuff. Enjoy watching your progress and problem solving. Loads of nice details.
  13. Sharpone
    Sharpone
    Extraordinary craftsmanship and attention to detail’s -Beautiful- I have some OT stuff from Finland and just love the craftsmanship. Must be the water over there!
    Dan
  14. Ziggster
    Ziggster
    Another great thread I somehow missed. Will have to check out it tonight.
  15. HelminenHotrods
    HelminenHotrods
    from Finland
    Workin on the pedals ***embly.
    Had to shorten the ***embly frame by an inch, to get more clearence for moving it upper, and also to get clear route for speedo wire ( the pushrods support bearing was on the way )
    Then i had to build room for the distributor to be able to lift off.
    Made the brackets and support frame to cowl, im going to ad couple more supports to make the cowl section sturdy IMG_20240507_193250.jpg IMG_20240507_211751.jpg IMG_20240507_193304.jpg IMG_20240507_193321.jpg IMG_20240507_211733.jpg IMG_20240508_210124.jpg IMG_20240508_210159.jpg IMG_20240508_210208.jpg IMG_20240508_210112.jpg IMG_20240508_210242.jpg IMG_20240508_210230.jpg IMG_20240508_212850.jpg IMG_20240508_212945.jpg
  16. patsurf
    patsurf
    BEAUTIFUL 'show and tell'
  17. Outback
    Outback
    from NE Vic
    Wow, so much effort & detail, most of which won't be seen!
  18. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks guys for the support !
    Tow Truck Tom and Outback like this.
  19. HelminenHotrods
    HelminenHotrods
    from Finland
    Continuing with the pedals
    Build an cast look throttle pedal to match the old casted I-beam style clutch and brake pedals.
    Air hammered the surfaces to get that pitted look. Alltough its not an patina car, but i like the look of the old pedals
    Pedal ratio is 2:1
    Made also the mounting frame with stoppers and return spring IMG_20240510_214115.jpg IMG_20240510_223207.jpg IMG_20240510_235321.jpg IMG_20240510_235256.jpg IMG_20240511_174220.jpg IMG_20240511_164153.jpg IMG_20240511_174144.jpg IMG_20240511_174201.jpg
    IMG_20240512_174218.jpg IMG_20240511_214428.jpg IMG_20240512_174130.jpg IMG_20240512_203207.jpg IMG_20240512_203240.jpg IMG_20240511_215021.jpg
  20. Outback
    Outback
    from NE Vic
    Wow, that's beautiful!
  21. brEad
    brEad
    That gas pedal is amazing! So nice!
  22. Max Gearhead
    Max Gearhead
    from Wisconsin
  23. HelminenHotrods
    HelminenHotrods
    from Finland
    Muncie rebuild is ready.
    Started from the cl***ic "straight from driving condition" to actually needing full rebuild.
    Countershaft and reverse gears were toasted, wrongly ***embled parts and even missing the input shaft nut, and couple broken mounts.
    But in the big picture it was decent starting point, and now i know what's inside the muncie.
    It has now all new bearings everywhere ( including 112 loose rollers on the countershaft), new countershaft pin, new sychros, new tailhousing bushing, reverse gears and of course new sealings.
    Heres some random pics i took during the build : IMG_20240524_211014.jpg IMG_20240525_002400.jpg IMG_20240530_211914.jpg IMG_20240601_003411.jpg IMG_20240601_003431.jpg IMG_20240601_003420.jpg
    And small video clip from ***embly :
  24. Grumpy ole A
    Grumpy ole A
    Wow! What a build! Beautiful work. I would hate to see what it would cost to have to pay to get that done.
  25. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks Man ! I have stopped counting hours looong time ago :D Kind of holy grail build for myself !
    Tow Truck Tom, Okie Pete and brEad like this.
  26. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    LQQKS Great! I really appreciate a well thought out under dash cage.........:)
  27. HelminenHotrods
    HelminenHotrods
    from Finland
    Long time no updates here, lets chamge that !
    Starting with steering parts.
    Steering box is borgeson vega. Mounting it with diy bracket IMG_20240630_152356.jpg IMG_20240630_152551.jpg
    Tacked in place.
    I placed the steering box close to same 7° angle as the front axle. Seemed to work best with everything in same angle, when turning full motions left to right.
    And there is no space issues etc for me not to do so.
    First support bearing in place
    IMG_20240821_211741.jpg IMG_20240826_190500.jpg IMG_20240826_190505.jpg IMG_20240826_192140.jpg
    And of course adding some personal Helminen Hotrod style to it.
    Stainless steel support bearing mount
    IMG_20240826_193648.jpg IMG_20240826_193634.jpg IMG_20240826_193629.jpg IMG_20240827_185204.jpg IMG_20240827_185414.jpg IMG_20240827_185130.jpg
  28. rod1
    rod1
    So glad you're back. This build is Pure hot rod to the 10th Degree. Doane Spencer would be proud.(other than the chevy motor);).Mr. Detail.
  29. brading
    brading
    Just been through the whole of this thread and the detailing is amazing.
  30. HelminenHotrods
    HelminenHotrods
    from Finland
    Thanks you sir ! Sorry for the chevy motor :D it's for financial and availability reasons, rather than personal favour of choise.
    It actually goes back in the 1928 chevy 4-banger days. It was really frustrating when nothing was available for it. When the rear axle broke it took whole summer to even get the parts. After that i thought next car is going to be sbc and basic gm drive train :)
    At least its followed by manual trans !
    (Im having second thoughts... why didn't i get oldsmobile rocket :D:D)
