Customs finishing off my pre-war cheveee project
Discussion in 'The Hokey Ass Message Board' started by nunattax, Aug 31, 2015.
Tags:
  1. nunattax
    nunattax
    worked on the fan shroud today.after removing the fan shroud i noticed id loosened some paint from the fins getting it out.its a tight squeeze.after removing the front hood latch catch and the top hose it came away ok.so today i removed the bolts holding the fan and set about replacing them with smaller fasteners.and rivets.i placed some cardboard behind the rad to protect it.havnt got it out yet . there is 6 m5 stainless bolts either side holding the shroud and spacers in place.i used m5 studs on top to locate the shroud until i could get a locknut on .all the bolts fitted in ok.plan is to lock***e studs at the bottom as well. then with the nuts loose ill be able to pull it out at top and remove the cardboard.improving the plan as i go.only issue i have now is a 15 mm gap between rad and shroud along the top.three thickness of foam tape should seal this up and steady it up thats the plan ill see whats available.good news is the anode is in very good condition no erosion on it at all. upload_2024-4-20_23-11-58.jpeg .when i made this shroud i tried 2mm but it was light so i added anouther layer of 2mm around the fan.it stiffened it up a lot.maybe next year i will make another similar only folding the edges etc etc now that i know what fits what it will be easier.needs an expansion bottle as well.i ordered a curved vane fan but i got a straight one vender offered $100 dollars cash back so i accepted so not complaining now.kept the fan nearer the top of the rad where the hotter water is.also kept the spal motor above and away from the waterpump pulley
    TFoch, Leakie and tb33anda3rd like this.
  2. pila38
    pila38
    Yo Chris! I haven’t been around for awhile, but have been getting back at it. You’re doing some fancy work here, looking good! Hope is well over there across the pond.
    nunattax likes this.
  3. nunattax
    nunattax
    thanx for the kind words eric.go through phases of activity between hot and cold spells .its cool but not cold here ideal weather for grafting.things here are as good as can be despite sky high fuel prices
  4. nunattax
    nunattax
    knocked up a stand to hold the carb while im working on it.it will fit into an oven tray to help keep anything dropped in the tray.just keep the carb on with wood screws and washers. upload_2024-4-21_1-17-39.jpeg
    TFoch, Leakie and loudbang like this.
  5. nunattax
    nunattax
    f[​IMG]or the studs top and bottom mount ill go for these. with m5 hex head bolts on the other locations .the slot head screws im using are hard to get at near the bottom.1/4 inch drive socket will make it all easier to get to for a professional job.
  6. nunattax
    nunattax
    looks like cam and lifter kit have been located/ordered great expectations here!.it has shipped and gotta tracking no.
    pila38 and Leakie like this.
  7. nunattax
    nunattax
    cam kit is in the country,detained by customs while they conjur up a substantial customs charge for it.plus value added tax,plus any tariff or levy that will take from the enjoyment of my hobby
    pila38 likes this.
  8. Leakie
    Leakie
    Sounds like you’re getting the (cam) shaft. :)
  9. nunattax
    nunattax
    the rip off republic here
    Leakie likes this.
  10. nunattax
    nunattax
    breaking news just in taxes amounted to e93 .call it $100 bucks.= a gallon of beer,grub up and a cab home ffs.
  11. nunattax
    nunattax
    delivered .reasonably priced from summit reasonably delivery costs all considered,taxes ****.from here forward its all new to me .breaking in the cam,removing some springs for break in without removing the heads.all new to me a carpenter looking forward to the challenge.
  12. nunattax
    nunattax
    trying to find time to commence the strip down.but some family matters and a few jobs to get out of the way..presently trying to source break in oil high in zddp.have found 15-50 oil 50e for 5 quarts 10 e to ship.here in ireland through a contact in rally preparation.thanx donal at Healy motorsports and lorcan at Drift 2 for their help and sharing the knowledge.working on an adapter to inflate the cylinder to replace the inner valve springs with heads on..basically a hollowed out spark plug with a motorcycle air valve.courtesy of Tony at Ace motorcycles.just need to magic these together. upload_2024-4-30_14-46-57.jpeg
    Leakie likes this.
  13. nunattax
    nunattax
    upload_2024-5-2_22-53-35.jpeg .finished this one off. timber is sitting in the tray.if anything went down under i can retrieve it.
    TFoch and Leakie like this.
  14. nunattax
    nunattax
    ok so a holley manual operated ckoke will fit on a demon carb after all with small mods.it went on easy after with the help of master machinest mick.i had been doing a little research on the subject.i read some where it would need to be spaced out by 1/4 inch this proved to be the case.mick measured up with his verniers and said we would try 3/8.after mounting with 3/8 spacers he declared we had 1/8 to spare and machined 1/8 off.they fitted perfect of course they did.there was a choice of 3 brackets to hold the cable and 2 arms one cranked to operate the choke. we used the cranked arm and the curved type bracket to hold the cable it bolted to the top of the vacuum cover.the bracket was high so mick machined the top of the curved cover for a flat mounting surface.everything lined up great.all the screw were the same thread 8-32.(edit) we had 6 in total 3 that came with the kit but they were too short with the spacers ,however the 3 we removed from the electric choke were longer and fitted fine the 3 screws for the kit were cut and used to hold the cable mounting bracket..no waste here.the vacuum unit came off easy but we couldnt tighten 1 screw to replace it.drilling a hole in the bracket allowed clearance for an allen key to p*** through.the video i posted earlier was a great help and we looked a few times to be sure to be sure .overall im really happy with how it turned out.now im looking for another diaphram for the vacuum secondaries,.need to find one soon because of the time lag between ordering and the parts arriving .now just need to find the serial numbers so i can order the correct parts
    been busy in the shop as well.fitted up an extra 8ft of worktop and plenty double sockets as well.
    placed an order on amazon for a new gates rad hose gates 20225 will do it.ordered a valve spring compressor and some tools to finish the job.nearly there .tidy down the new bench.should be ready to start rebuilding next week.roll on the summer.
    im not too impressed with the blue /red fittings on the fuel line .but it doesnt leak and its not visible with the air filter back on.the choke when pulled on will raise the idle a little .that will be a real novelty in the colder weather
    Algoma56, Leakie and loudbang like this.
  15. bubba55
    bubba55
    Brother Flea ya one dang good piddler
    Nothing slack about you but yer looks
    Rock on
  16. patsurf
    patsurf
    and i thought 4-40 screws were small!
  17. nunattax
    nunattax
    patsurf edited.slip of the finger after a long day.my gl***es have been located in my pocket.chris
  18. nunattax
    nunattax
    mike im taking that as a compliment
    bubba55 likes this.
  19. bubba55
    bubba55
    The highest compliment a Bubba can give
  20. nunattax
    nunattax
  21. nunattax
    nunattax
    Need something like this #135-4 holley vacuum secondary diaphragm.piddled about today fixing random bits on the bench so i could put them away.then went researching the parts i needed on the computer.carb is an early model with no serial numbers or model numbers i only threw out the box last week so no numbers on the box either.spent an hour on ebay i confirmed it is a road demon 625 cfm VS.traded pictures with a tech ***istant on jegs site.he contacted holley.matt got back to me .holley said i needed holley #135-4.jegs have it in stock $16 . great stuff.
    https://www.jegs.com/i/Holley/510/135-4/10002/-1 .another piece of the puzzle located.
    Leakie likes this.
  22. nunattax
    nunattax
    waiting for a delivery
  23. nunattax
    nunattax
    some parts arrived.comp cams degree wheel,bottom rad hose ,valve compresser tool ,flexible valve holder hose..trimmed the bottom hose and it fitted.overall happy with the parts so far anyway.
    Leakie likes this.
  24. nunattax
    nunattax
    holley #135-4 arrived and is the correct part.fitted excellent.tested it was holding vacuum all is good.the vacuum pod and choke ***embly are competing for space the front screws on the vacuum pod need to be installed in the housing before fitting.kept the allen head screws on the pod they are out of sight and havnt rusted since new. choke bolted up with the 1/4 spacers and looks like it will work.got another choke cable black this time with a black knob.will need to sort out a mounting bracket too.that can wait for a while got more important work to do.the new stainless 8-32 screws are fitting great .m4 stainless lockwashers and washers are in stock and fit perfectly
    Leakie likes this.
  25. nunattax
    nunattax
    stop press. something is incorrect with the fast idle adjustment.the screw is fitted incorrectly through the bracket from the wrong side so take it apart and redo.not a big deal know it off by heart by now..if the holley instructions were any good wouldnt have had any issues.found a much better video . .much better lighting and clearer instructions
    pila38 likes this.
  26. pila38
    pila38
    I knew I liked you Chris, you’re just like me, have to do it twice! “We do it nice because we do it twice!” By the way, did I read that you’re a carpenter?
  27. nunattax
    nunattax
    thanx eric.if at first you dont succeed etc etc.i was following the instructions on the first vid.second vid posted is a much better guide well lit and clear instructions .and yeah man carpenter by trade ,like fixing stuff.many years back when i had my first harley some bits might come loose occasionally ,i bought lock***e and locknuts ,lockwashers .only came loose once.had a buddy with a triumph 750.he carried a bag of tools/washers allways .i carried money, bottle opener and a spare split link.
    pila38 likes this.
  28. nunattax
    nunattax
    mission accomplished. pod is holding vacuum. there were some complications with the incorrectly fitted screw .the inner bracket on the throttle shaft got bent a little i eventually straightened it out but a tricky job due to its shape.reversed the screw and bent the bracket a tad so the adjusting screw ran centre in the high idle cam.3 snags left to do ,1 ideally the choke rod would have a R clip holding it on there is a circlip holding it in place. its a pain to remove and hard to access.a little tip when you get the rod into the choke ***embly stuff in behind it with tissue to keep it there until u get a splitpin or R clip on to locate it.
    2 i have 3 1 3/4 screws holding the choke ***embly in place with a lock washer under head.there is another 1/8 thread available so i need to cut 2 inch screws to 1 7/8 to maximize the threads available.
    3 the c clip on the vacuum post isnt a fantastic fit so a trip to the engineering supplies shop is called for .ill bring the carb for a perfect fit.
    a bit of trial and error but dont need instructions now there in my head
    Leakie and pila38 like this.
  29. pila38
    pila38
    I’m a carpenter as well, or at least I try to be. Glad you got the carb working, did you get the new cam in?
  30. nunattax
    nunattax
    no ,thats next on the list.i started on the choke conversion while i was waiting for parts to arrive.they are all here now.i like to work on one piece at a time then put it away.im off now for a c-clip and an r -clip to finish the carb overhaul off so i can put it away til its needed soon.
    pila38 likes this.
