Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. choptop40
    choptop40
    cleaned up the interior , ripped out the old wiring and underdash heater and duct work..old firewall padding.....getting ready to install later model steering column C3C45814-9E99-4F89-8AD6-73A5259E1731.jpeg
    j hansen and mad mikey like this.
  2. choptop40
    choptop40
    Stripped out the rest of the dash .. Gauges .. etc.... pretty cruddy back there.... 74 years worth .....content with todays progress.......
    alanp561, BigRRR, loudbang and 3 others like this.
  3. Bad Bob
    Bad Bob
    from O.C. Baby
    Drive the Coupe to work.....again!
    Last saturday, I put a 1/2" spacer above the front spring, cause it was too close to the frame. I didn't want to notch the frame.
  4. DDDenny
  6. vtwhead
    vtwhead
    after weeks of delays and issues I am getting ready to run this Olds on the stand, I hope!
    Stock Racer, WilliD, rod1 and 15 others like this.
  7. Pass The Torch
    Pass The Torch
    Dropped the 7 off at the exhaust shop - the one task I despise doing. Whilst she was away, got busy with the hood. Louvers are cool until you have to strip and sand around them.
  8. choptop40
    choptop40
    made template for gauge panel , fabricated ignition and radio delete plates , mocked up steering... E6B12226-2A3D-44DC-981F-DF957C859454.jpeg D19C6694-53A0-4294-B572-4354D519CB37.jpeg 652D907D-84FD-4E97-8FD0-6D9907382AD9.jpeg
  9. vtwhead
    vtwhead
    Took my new to me '68 top loader apart for a rebuild and cleaning. learning as I go, took me three hours and a few cuss words.
  10. mgtstumpy
    mgtstumpy
    I finally put all the new window run channels in the doors and rears 1/4s, installed the new gl*** and my NOS vent shades. I had to install the 1/4 gl***es and accidentally broke one so off to the local shop to have one cut using the other one as a template. Then install the 1/4 gl***es with those small PITA hollow rivets, these aren't that easy to locate! Then they need to be carefully peened over.
    Then drop the gas tank off to be 'Deep' cleaned by the gas tank guy. It had been [Poorly] sealed at some time previously, there was no way I'd use it in current {internal} condition although on the outside it looked fine. Once cleaner it was time to line it with Red Kote polymer liner making sure I get a nice even coat on all surfaces including seams, corners, filler neck and pressings. Then hang it up to drain and dry. This is a local product manufactured in Ohio and better than many other similar products on the market.
    Tank is all set up now for in-tank pump, all I need to do is adjust sender float and then the tank's off to be painted silver frost / galvinised finish. 393168122_8073191769374637_183641832600698800_n.jpg
  11. TA DAD
    TA DAD
    from NC
    My radiator sprung a leak (there was a slight crack at the top seam) So I pulled it out to solder that up. So it only takes a few minutes to remove the hood , then remove 6 bolts and flip the front out of the way for easy service. IMG_1344.JPG IMG_1343.JPG IMG_1354.JPG
  12. 34Phil
    34Phil
    cut the fender mount arms and sheetmetal off a '40s GM radiator surround and narrowed it to fit a '38 Chevy radiator in a '39 Olds. (not original frame so no pics)
    j hansen likes this.
  13. choptop40
    choptop40
    removed an old boiler at work..the shell was exactly the same sheet metal gauge as the 50 Desoto and had curved ends..great fab material...got the front , back and both sides.....free to boot 9D24FAF1-52E6-46D2-9AD0-2C3DA362F6CF.jpeg
    j hansen, alanp561 and RMcCulley like this.
  14. nobby
    nobby
  15. choptop40
    choptop40
    Got home and fabbed up sheet steel template from boiler cover.. Next.transfer to aluminum ….Finalize gauge and switch layoot image.jpg
    osage orange, j hansen, X-cpe and 3 others like this.
  16. swade41
    swade41
    from Buffalo,NY
    I did nothing today, went out and shut the door between the two halves since the temperature dropped enough for the heat to kick back on in the back half.
    Probably why I ache so much, stupid weather.
  17. dln1949
    dln1949
    Well yesterday I loaded up “ol every day” and took my Tudor body to my favorite upholstery shop to do the top and headliner before I set the body back on the ch***is. Doesn’t seem like much when I look at what others get done, but then I’ve done the patch panels and hammer dolly ****, oh yeah and the sanding. A retired painter friend sprayed it, we keep him locked away. Ch***is is done, starts , runs and stops. This is the second build for this sedan, first in 1974, now 2024. Yep same car, same owner 78A38845-0B39-493B-932C-1408E169C3D9.jpeg F9C3A329-7743-4541-92BC-53F8009CE43F.jpeg
  18. rusty1
    rusty1
    ^^^ nice tow truck!
    guthriesmith likes this.
  19. natrlgas49
    natrlgas49
    Covered the hole in the door not a professional job IMG_1482.JPG but I am not professional and i think it looks good enough
    TA DAD, swade41, loudbang and 3 others like this.
  20. RICH B
    RICH B
    @nobby If you don't want to use blocks under your tires, you could drop the legs on your hoist so it gets along with the dropped axle. Saved this picture showing how someone did it to a modern lift. When I built my cherry picker back in ancient times, I made it low for the same reason.
  21. Pontmerc
    Pontmerc
    from Finland
    Changing winter studs for summer whitewalls.
    Also remowed rear brake drum first time in my ownership and noticed backwards installed shoes.
    I pretend i didnt notice it and put tires in place.
    No eonder it didnt stop very well.
    Gotta take time and put those things in correct orientation. 17145815326961198659667997022315.jpg
  22. Pontmerc
    Pontmerc
    from Finland
    Also did little "check the ranch" cruise. 17145868893798447311558462783381.jpg
  23. nobby
    nobby
    I can just about jack the front up on the axle to get the lift under
  24. RICH B
    RICH B
    Dropped axle and small tires require a different approach at times.
    I like my low clearance cherry picker because with the tires on the ground I can also roll the car back when pulling engines. Seems more stable than the engine swinging around when the hoist is rolled back.
    On the other hand when I want to jack up my hot rods to work on stuff, I usually have to jack up one side and put a block under the tire to be able to get my jack under the middle of the axle.
  25. mgtstumpy
    mgtstumpy
    I finally located the roll of bitumen board, made some templates and cut the required patterns after I masked the areas up for some spray glue. A PITA to install between skin and frame however it's OEM and better aesthetically than using dynamat. I also did the gas tank sender. 440807765_1197415984966631_1791483315715049686_n.jpg 440985092_1197415968299966_8975734627448944207_n.jpg 440807719_1197415904966639_6163097377771434398_n.jpg
    Jeff34, X-cpe, '28phonebooth and 7 others like this.
  26. dln1949
    dln1949
    Well made I to the upholstery shop last Tuesday, and back again on Wednesday. Got the top done the headliner, and some old style wind lace for the doors. The Hidem is on it’s way, some where’s in the postal world. Hope to finish up the rest of interior trim this week and get the body back on the ch***is. A33BB7D7-CC07-4488-BD9D-51A33496302F.jpeg 917755B0-C9F9-42B6-9A76-705FF3CF1B8B.jpeg
    BigRRR, LAROKE, loudbang and 6 others like this.
  27. 67drake
    67drake
    from Muscoda WI
    Taught my 16 year old how to seat rings after an engine rebuild. IMG_1338.jpeg
    nosford, loudbang, j hansen and 2 others like this.
  28. jeepster
    jeepster
    from wisconsin
  29. davidvillajr
    davidvillajr
    Charging the battery - some tire money is coming soon and I want to be able to drive there instead of taking just the wheels.
  30. kustomfordman
    kustomfordman
    Working on getting an early Chrysler style alternator mounted onto the 354 Hemi. No options with the Cragar 4x2 intake. So, a grinding and a welding I go. PXL_20240507_012222423.jpg PXL_20240507_012235167.jpg PXL_20240507_012302798.jpg
    TA DAD, Max Gearhead, BigRRR and 4 others like this.
