SBC Short vs Long water pumps
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Nov 23, 2009.
  1. mgtstumpy
    mgtstumpy
    Reverse flow (above), standard flow (below). Different impellors
  2. aaggie
    aaggie
    Just a hint for maybe someone that is wondering if they have a short or long pump. If the timing cover almost touches the back of the pump it is short. If you can almost stick your finger between the cover and pump it is long. Handy to know if you are looking under hoods at a junk yard.
  3. 52lomofo
    52lomofo
    Where did the upper bracket attach?
  4. pprather
    pprather
  5. 52lomofo
    52lomofo
    thanks PPrather thats what im looking for guess i could use some spacers to work with long water pump
  6. RodStRace
    RodStRace
    Yep, the timing tabs moved around (along with the balancer groove) with the long pumps too.
    When you have a basic engine used for decades that is "the same", there often are still a bunch of small differences.
  7. 1971BB427
    1971BB427
    from Oregon
    I went with a short pump on my SBC in my '39 and the old pulley worked great. I bought the pump new, but don't recall what the application was as I just searched "short water pump SBC". I only have one accessory, the alternator, so no double pulleys, or issues lining it up. I used a chrome adjustable alternator/gen. bracket that slides back and forth and bolts together to hold the placement. It straddles #1 exhaust tube on my headers.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If you are going to run a blower, I would get the blower and mount it on your engine before trying to decide what pulleys and pump you need. The blower may dictate what you have to use......maybe/maybe not. Not so much of a problem here in the US where the parts are more common, but in your location it's probably more costly.
    I saw an episode of Bitichin Rides where they had a tool that was used to send a lazer beam from one pulley to another, so they could get them aligned properly. The tool was quite expensive. Digging a little further I found that there is a lazer tool for bore sighting guns. It's shaped like a bullet and I plan to lay it in a pulley groove and point it at the other pulleys to get them spaced properly. I'm adapting a blower to a Cad engine and all the pulley locations will be custom because I'm using a fluid filled balancer and a crank trigger. I'd get the blower in position first and see what you need to make everything work spacingwise.
    Go to Amazon and search for Lazer bore sight..........
  9. I always go short for extra room. Of course the only accessory I ever run is the alternator lol
  10. Splitbudaba
    Splitbudaba
    PXL_20240426_183558565.jpg PXL_20240426_183545784.jpg Decided on the short style, clearance decided it really!! Bought an old 265 from a 57 Chevy truck complete with all pulleys and generator. Made it easy!! Even have the original 6 blade steel fan, cut it down and balanced it on my tire bubble balancer. So far she stays at 180 degrees all the time. Free catch can. Shroud helps a ton. Plus with the short pump, you can always add a spacer or two between the water pump pulley and the fan to get the fan in the sweet spot!
  11. pprather
    pprather
    I think that 72 Chev pickup alternator bracket is for long water pump.
    The short pump had been phased out in the late 60's.
  12. Wayne3207
    Wayne3207
    from WestTN
    My 72 Chevy truck came from the factory with a short water pump.
  13. pprather
    pprather
    I stand corrected. Thanks.
  14. jimmy six
    jimmy six
    Looks like a circle track fan shroud kit turned verticle. Did one like it on my son’s 40 Chevrolet. I think it cam from summit or speedway.
  15. Splitbudaba
    Splitbudaba
    I think it was Speedway. I modified the ring so I can remove the ring first, that makes getting the fan out first a piece of cake.
  16. fastcar1953
    fastcar1953
    My 72 also has short pump.
    I'm more interested in the fact it runs 180 at the t stat housing. Mine runs 140 there and 175 at the head.
    I guess aluminum heads make a big difference. I don't run a fan or shroud. 334946226_765356218442145_1178234960448717027_n.jpg
    Splitbudaba and The Chevy Pope like this.
