Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. pila38
    pila38
    Ha…an adept eye picks up on all the changes in a project. Yes, I have switched to champagne. What can I say I have fine tastes. I’ll update when I can, chances are, you’ll finish yours before me.
  2. nunattax
    nunattax
    hi eric every little bit helps.i watch along the carter auto restyling channel on youtube the guy is canadian and does some mighty fine work on rusty lost causes. well worth a watch.dont give up chris
  3. pila38
    pila38
    Hey Chris! I’ll have to check him out. Don’t worry, I’m not giving up. You should be used to this by now!
  4. swade41
    swade41
    from Buffalo,NY
    What were those headers made for ?
    Kinda reminds me of my sbc days in my 41 but those headers you have look like they might work on my 57 pickup better than the tri-fives I have.
  5. pila38
    pila38
    They’re for a 67-87 Chevy truck. Schoenfeld makes them, part# 1346. 1 3/4” primaries and 3.5” collectors. They make them with bigger tubes as well. They fit pretty well, but the two highest tubes hit the fender, so yeah, I’ll be cutting the fenders up. Small price to pay for being an awesome mother f*****r.
    swade41 likes this.
  6. nunattax
    nunattax
    eric can you just trim the inner fenders?.i was considering making new inner fenders for mine.they were bent up especially the louvers.but i reworked them and they turned out well.however in the summer time the firewall gets very warm and could benefit from more ventilation through to the fenders.i have a 2inch dimple die and may well drill some more holes in them and dimple them to stiffen them up again chris
  7. nunattax
    nunattax
  8. pila38
    pila38
    The inner fender wells will be completely gone. I’m going to have to nibble part of the actual fender itself. Not much, maybe a 2”x8” area. I’m going to go with fibergl*** fenders in the front anyway, so it won’t be any great loss. And I will have to get creative to make a little extra support for the fenders.
  9. swade41
    swade41
    from Buffalo,NY
    Aren't the gl*** fenders tough to find now ?
    When Superior Gl*** burnt and all the molds with it, it really hurt the Chevrolet fibergl*** reproduction parts availability.
  10. pila38
    pila38
    Hmmm…hadn’t thought about that. Shoot.
  11. pila38
    pila38
    Looks like Speedway still has them
    swade41 likes this.
  12. pila38
    pila38
    Got one seat riser close to done, just needs a little more hot glue. Pics are a bit out of order. 2DAA7CC5-55C2-4B8C-9E9A-FD4BB6A3E336.jpeg D71409E3-218D-40BB-8B7C-4BE4F0943D26.jpeg 0475916D-8943-4890-8AE0-07AB20490AC9.jpeg D2910B8E-3D33-4958-B76D-7A6E86037F11.jpeg 04C844C1-9FB5-4792-9FF2-7E5079942C50.jpeg 14DE58B2-EEF1-4DC4-BF5D-23DAA24F690C.jpeg .
  13. pila38
    pila38
    IMG_4676.jpeg IMG_4678.jpeg IMG_4681.jpeg IMG_4682.jpeg IMG_4684.jpeg IMG_4687.jpeg One year later; I finally finished it! The seat issue that is.
    Chucky, swade41, LAROKE and 3 others like this.
  14. bubba55
    bubba55
    Nice work Eric - keep at it - ya doing it
    vic van leeuewn and pila38 like this.
  15. Toms Dogs
    Toms Dogs
    from NJ
  16. pila38
    pila38
    IMG_4705.jpeg IMG_4701.jpeg IMG_4702.jpeg IMG_4703.jpeg Master cylinder mounted up. Made an 1/8” plate for between the pedals and firewall. Will add 3/8” rod from the plate to the dash later.
    swade41 likes this.
  17. pila38
    pila38
    Got some work in on the floor and pedals. Getting close to blowing it apart for prime. Also, got the engine block at the machine shop. Maybe this pile will make noise someday.
    And be careful with those wire wheels, they get stuck in the darndest places.
    loudbang, swade41 and tb33anda3rd like this.
  18. tb33anda3rd
    tb33anda3rd
  19. Wanderlust
    Wanderlust
    Whoa seconds from disaster
    pila38 and loudbang like this.
  20. swade41
    swade41
    from Buffalo,NY
    Almost took the fuzz off your nuts !
  21. pila38
    pila38
    Haha…they could use a little dusting off anyway!
  22. Joe H
    Joe H
    I found after driving my '37 for a couple hours, my legs were going to sleep. I raised the front of the bottom seat for more support, ( factory bench seat ), it made a huge difference in comfort. Setting straight up with no leg support gets pretty old real quick
    If you are keeping the old style steering box, up grade to a '41 - '46. They have roller balls and a slower gear ratio, its not quit power steering, but a heck of a lot better then the one they came with. I cut the steering shaft on my '37 and welded it to the '41 gear box so I could keep the '37 wheel and column. The later trucks had a dished steering wheel, which in the '37 puts it right in your face.
  23. pila38
    pila38
    Thanks Joe. I’ve been sitting in it quite a lot and it seems pretty comfortable. If needed I could always add a block to my seat frames if they need to be raised. The way it sits now, the seats are pitched forward so my legs are pretty straight.
    I do have a 41-46 box in it right now, I already rebuilt it as well.
  24. Joe H
    Joe H
    Not having a hump in the floor will help. I put a T350 automatic in mine, the hump is right where the throttle needs to be, so I'am kinda cramped. Lookin good so far.
    Joe
    pila38 likes this.
  25. pila38
    pila38
    Got the old girl outside to blow the dust off and took some beauty shots. So far…I like what I’m seeing, but I’m bias.
    IMG_4771.jpeg IMG_4772.jpeg IMG_4773.jpeg IMG_4774.jpeg IMG_4775.jpeg IMG_4776.jpeg IMG_4777.jpeg IMG_4778.jpeg IMG_4779.jpeg IMG_4780.jpeg IMG_4781.jpeg
    nunattax, LAROKE, tb33anda3rd and 2 others like this.
  26. pila38
    pila38
    Been doing a lot of cleaning and prep….boring stuff. Shot some prime on the floor pieces today so I can keep moving on.
    Did a little layout on the dash too.
    LAROKE, Wayne67vert and nunattax like this.
  27. nunattax
    nunattax
    pila38 likes this.
  28. pila38
    pila38
    Thanks Chris. Been trying to keep at it for real this time. Getting the engine to the machine shop was very motivating
  29. nunattax
    nunattax
    im in the middle of fitting up a nice mild cam at the moment hopefully with more economy compression vacuum and plenty off idle and midrange power.time will tell slan chris
    pila38 likes this.
  30. pila38
    pila38
    You’re going the opposite way of me! I had a nice cam here and ready to go. Decided I wanted something wilder. So the solid roller is on its way to me.
