Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. timberwolf01
    timberwolf01
    1913, July 13, Amiens, sidecar and cyclecar grand prix, Pouliez on Violet-Bogey, Canoriel on Sphinx-Globe
    Okie Pete and porkshop like this.
  2. timberwolf01
    timberwolf01
    Violet-Bogey gear change: the friction roller G is applied against the plate P driven by the motor. G moves laterally on the ribbed axis A under the action of the triangulation N maneuvered by the pilot using the lever L. The neutral point is obtained when the roller G is in the middle of the axis A, aligned with the center of the plate P. The greatest speed is obtained when G is at the edge of the plate, as for example in the photo. Sliding to the left beyond the center of the board is in reverse. At the left end of the A axle is the sprocket that drives the C chain to the rear sprocket attached to the wheel axle (no differential).
    Okie Pete, porkshop and Ned Ludd like this.
  3. Ziggster
    Ziggster
    Very interesting concept.
    Ned Ludd likes this.
  4. mohr hp
    mohr hp
    from Georgia
    My neighbor had a snapper lawn tractor with that type of arrangement. The flywheel was rubber coated.
    Ned Ludd and timberwolf01 like this.
  5. banjeaux bob
    banjeaux bob
    from alaska
    styled somewhat similar to Jay Leno's Shotwell. Imagine it being powered by a gas engine instead of an electric motor.
    Okie Pete, porkshop and Kume like this.
  6. Ned Ludd
    Ned Ludd
    Most commonly ***ociated with the British GWK light car:
    Okie Pete, porkshop, Kume and 2 others like this.
  7. fredvv44
    fredvv44
    At least try to get the proportions close!! View attachment 6039447
    I've had a couple of Snapper lawn tractors but they both had plane flywheels and rubber coated driven wheels.
  8. timberwolf01
    timberwolf01
    Proper gearbox! :D
  9. mohr hp
    mohr hp
    from Georgia
    Maybe it was the other way around like that. Been over 20 years! It worked. Infinitely variable drive and pretty simple.
  10. banjeaux bob
    banjeaux bob
    from alaska
  11. AnimalGuy
    AnimalGuy
    I have always built odd cars.
    This time around I'm building a Mini G***er using a 37 Ford Legends car and will use a St or CTX1300 engine.
  12. fredvv44
    fredvv44
    That will be cool. I always liked the g***ers and especially the Altered cl***. It was so crazy watching them go all over the track. They looked like a GN racing.
  13. banjeaux bob
    banjeaux bob
    from alaska
    11174646_10206737815352933_591305610054980881_o.jpg "Rocket car", Johnstown, USA.
  14. roadsterlines
    roadsterlines
    SLNSW_FL20815728.jpg SLNSW_FL20815729.jpg SLNSW_FL20815730.jpg 'Single seat Austin racing of David Parry, registration no. 131-901' - Sam Hood Collection, Mitchell Library/State Library of New South Wales
  15. timberwolf01
    timberwolf01
  16. fredvv44
    fredvv44
    Kume and timberwolf01 like this.
  17. roadsterlines
    roadsterlines
    Magnifying the original SLNSW first image, I think it says 'Humber' on the radiator surround. 'Vintage Car Club ... Centennial Park (?) ... ca. 1953' photos by Max Dupain; Mitchell Library, State Library of New South Wales SLNSW_FL14224410.jpg SLNSW_FL14224411 (1).jpg
  18. Ziggster
    Ziggster
    Just came across this on FB. Wonder if any have been fitted to cycle cars over the years. Orig design goes back to the 30s.
    Okie Pete, porkshop, Ned Ludd and 2 others like this.
  19. timberwolf01
    timberwolf01
    Looks like a pre WW1 Humberette tn_DSC_2592_1.jpg tn_DSC_2600_1.jpg tn_DSC_2601.jpg
    Okie Pete, motoklas, Ziggster and 3 others like this.
  20. fredvv44
    fredvv44
    I have often thought about that but the prop shaft would require some machining to fit a flywheel and the crankshaft thrust bearing would be on the wrong side to take clutch pressure.
  21. timberwolf01
    timberwolf01
  22. timberwolf01
    timberwolf01
  23. fredvv44
    fredvv44
    That Sandford is really nice. I've not see one before.
    Ziggster likes this.
  24. How about this :cool:, mobile two stroke invalid chair that was common here in 1950s/1960s. Obviously only for outside use :rolleyes: . Thats me sitting there. Had a ball with that thing before the cops pulled me off the road 30 years ago. No, thankfully i,m healthy.
    Okie Pete, motoklas, porkshop and 2 others like this.
  25. roadsterlines
    roadsterlines
    'A late 1931/early 1932 Morris Minor with a locally built body, Perth, 1932' - State Library of Western Australia slwa_b2646117_1.jpg
    Okie Pete, Outback, motoklas and 5 others like this.
  26. timberwolf01
    timberwolf01
  27. timberwolf01
    timberwolf01
  28. fredvv44
    fredvv44
    I really love that car. I have Bolster's book on building Specials.
    Stueeee, porkshop and timberwolf01 like this.
  29. timberwolf01
    timberwolf01
    Framo 'Stromer': 30390063284_acf8f1c8dc_b.jpg 5148b846f1d8cb8c45bf684c012bafd2.jpg 8a286894dc8858639ced319bb4c0b9e1.jpg framo-stromer-coupe.jpg img004.jpg img005.jpg
    The Stromer, with its racy look, speed, convenience, and economy, is the perfect vehicle for the business man, the discriminating sportsman and the elegant lady.
    40 Olds, Okie Pete, motoklas and 4 others like this.
  30. fredvv44
    fredvv44
    One of my favorites. Also as a roadster.
    Okie Pete and timberwolf01 like this.
