Projects 31 Plymouth Business Coupe
Discussion in 'Traditional Hot Rods' started by 340 Power, Nov 13, 2014.
  1. fordcoupeguy
    fordcoupeguy
    I am into the 70 style too 364016976_1028361731672712_7589233537895001198_n.jpg
  2. Duster418
    Duster418
    31chevymike likes this.
  3. 340 Power
    340 Power
    from NW PA
    Pulled the body, engine and transmission, and prepped and repainted the frame and underside of the car this weekend. That's the kind of thing that happens when you take 8 years to build a car I guess. Atleast it's one step closer. 20240428_133658.jpg 20240428_133723.jpg 20240428_133750.jpg
  4. Bearing Burner
    Bearing Burner
    from W. MA
    Do you have original engine ? Would you sell all or parts?
  5. 340 Power
    340 Power
    from NW PA
    I didn't get an engine with the car when I bought it.
    31chevymike and chryslerfan55 like this.
  6. 340 Power
    340 Power
    from NW PA
    Once again doing something twice because it's been so long since I started this build. The hemi got a new coat of paint. Messenger_creation_7aca1513-511d-4ec0-bfd6-f0a64641d94c.jpeg Messenger_creation_f245890d-507e-42ed-93df-ccba073c95a1.jpeg Messenger_creation_3a188e3d-c560-4119-8672-4aa9554b046c.jpeg
  7. Nice job sir!
    340 Power likes this.
  8. 1962 dodge lancer
    1962 dodge lancer
    from joliet, il
    super nice mopar keep up the good work.
    340 Power and 31chevymike like this.
  9. 340 Power
    340 Power
    from NW PA
    Not much work getting done due to the holiday. We did however reinstall the hemi. Then FedEx dropped off my hood 3 weeks early. Rootlieb did a great job!! 20240525_105513.jpg 20240525_105721.jpg
  10. 340 Power
    340 Power
    from NW PA
    Bolted the body on for the last time after fastening brake and fuel lines to the frame, and plumbing the air shocks. Set the grill shell to make sure the new hood lines up. Had to shove it outside and take a couple pics. 20240615_171918.jpg 20240615_171939.jpg
  11. Nailhead A-V8
    Nailhead A-V8
    saw one last week $40. cdn.
  12. You have to be psyched with your latest progress! I'm almost there myself, preparing to drop my hemi and 700R4 together with new seal kits. My specific bolt kit for my trans adapter from Hot Heads is arriving early next week. I am just thrilled beyond words to see a behemoth hemi within my rails!!!
  13. 340 Power
    340 Power
    from NW PA
    Spending some time making the mounts to attach the hood. Having long since turned my garage into a wood shop the pic is what I get for building a car in my barn. Sent it to my 2 oldest son's and hotrodderhaag called it "Chicken Coupe". Looks like that name will work just fine for her. 20240626_173314.jpg
    bostonhemi, RMR&C and Okie Pete like this.
  14. 340 Power
    340 Power
    from NW PA
    Finally a little color. Just the windshield frame. Messenger_creation_267919c3-75a3-46f4-b7e3-891b6a8def58.jpeg Yes I changed it. This is the 4th time. I think I like it.
  15. I agree with you on your choice of color - go for it!
  16. 340 Power
    340 Power
    from NW PA
    Today with my wife's help I set the windshield gl*** in the frame. I measured the channel width and gl*** thickness to determine which thickness of tape to buy. Ended up using 0.30 tape. After putting the tape on and using small pieces of masking tape to hold it in place, I coated the frame channel and rubber tape in dawn dish soap. A couple 4x4's screwed to plywood held the frame upright. It took both of us to guide it into the channel on both sides. I made sure not to seat it in the bottom until I had the frame top back on, then used a small block of wood and a mallet to seat the gl*** till the holes lined up to screw the top back on. My plan worked pretty well. It was way easier than I thought it would be to put together. 20240707_122012.jpg 20240707_135154.jpg
    bostonhemi, Okie Pete, slayer and 5 others like this.
  17. 340 Power
    340 Power
    from NW PA
    Wow!! 2 1/2 months since my last post. Windshield is in for the last time. Battery cables run and put the seats, dash, and column back in. Going to start wiring soon. The plan is to get it running, make sure all is good with a couple test drives then it gets painted. 20240925_155737.jpg 20240925_155235.jpg 20240925_154956.jpg
  18. Rickybop
    Rickybop
    Awesome. I love it.
    Especially since I just bought one fer ma-self.
    Naturally, I'm researching the car and it brought me right back to the HAMB and your thread.
    Good luck with the rest of your build. I may have questions.
    340 Power, hallrods and 31chevymike like this.
  19. indianmark
    indianmark
    Glad to hear you got yourself a Plymouth. Best of luck with it and if I can be of any help please reach out.
    Mark
    340 Power, 31chevymike and Rickybop like this.
  20. 340 Power
    340 Power
    from NW PA
    Spring is here so it's about time I get back to work on this thing. Finally mounted my tailights today. Next on the list is to start wiring this thing. 20250330_122816.jpg 20250330_133709.jpg 20250330_151821.jpg
  21. EZ Wiring kit from Florida? Keep at it @340 Power!
  22. 340 Power
    340 Power
    from NW PA
    This was a 12 circuit harness from Speedway.
  23. Same kit style as mine - what I like the most is that the wiring is done at the box, all ready to lay out in the car and measure/cut to the proper length and install one area at a time. I'm new to the wiring part of the build, so it'll be a HUGE learning opportunity for me - keep up your progress 340 Power, we'll both fire up our hotrods THIS YEAR!!!
  24. Rickybop
    Rickybop
    I love how the trunk lid extends all the way down to the tail pan on these cars. There are people who've done a lot of work to make theirs like that.
