Hot Rods 57 FORD Build #2... Glutton for Punishment.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Oct 20, 2021.
  1. RmK57
    RmK57
    Not going to use a front bumper? 40-50 lbs. off the front anyways.
    Thor1, warbird1, Jeff Norwell and 2 others like this.
  2. Oneball
    Oneball
    Is that the stock sway bar on the front?
    Sharpone and Jeff Norwell like this.
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No Tim.. an aftermarket unit...
    lothiandon1940 and Sharpone like this.
  4. Oneball
    Oneball
    Is it an Addco one? I’ve got some of theirs on the Vette but I think I heard they’d gone out of business.
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No Tim.I got it from SW T-Birds,Its the biggest offered.1-1/8.
    the factory sway bar (IMHO) is pretty much useless.
    I have them on both cars and there is a m***ive difference in handling and deep cornering.
  6. 05snopro440
    05snopro440
    Over-traveling the clutch pedal in a hydraulic throwout bearing setup can over-travel your throwout bearing so it comes apart and hangs against the clutch fingers. The clutch pedal stop makes it so that can't happen.
  7. bobss396
    bobss396
    I have their bar on my car, handles like a Lotus....
    Oneball, Sharpone and Jeff Norwell like this.
  8. atch
    atch
    What's the actual name of the company? I've Googled "SW T-Birds" and many variations thereof and nothing shows up that sounds like what you're referring to. Maybe I'm just not smart enough to find what you're talking about. Many times my searches don't turn up what I'm hoping for.
  9. Ford blue blood
    Ford blue blood
  10. ronzmtrwrx
    ronzmtrwrx
    Just catching up with your thread. It’s looking great. That thing sounds perfect. Love the tone.
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Sorry Mike..... Bill,Below has the the proper Link!
    Thanks Bill!
    Thanks very much!
    loudbang and lothiandon1940 like this.
  12. Jeff Norwell
    Jeff Norwell
    MODERATOR
    So.got a few DM's about the sway Bar......
    Not sure if SW T-Birds carry them any more..... best to call.
    I did find Larry's T-Bird does have them... but the price has nearly doubled....
    Anyhow..... seems they are getting harder to find.
    Oneball and lothiandon1940 like this.
  13. 51pontiac
    51pontiac
    from Alberta
  14. Jeff, I just went to this web site and the listing is as you posted and does not have 57 - 58 in the covered year vehicles. Is that number A5482E the exact one you installed?
    Jeff Norwell likes this.
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes. that's the unit.. its as simple bolt in.... less than an hour for the installation.
    I would place a phone call.
    Reading a bit more into it... they say they are designed for 54-59 Ford P***enger cars.
    Pist-n-Broke, Just Gary and bobss396 like this.
  16. guthriesmith
    guthriesmith
    Sounds good Jeff! :cool:
  17. bobss396
    bobss396
    I had to call them up and ask about it. The bar is not on their web site. I forget how much it was, it was reasonable.
  18. bobss396
    bobss396
    This is what I did. The install was real easy. I was working alone and removed the old bar with a cutoff disc.
    brEad and Jeff Norwell like this.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Out in the sun.... let it idle for 45 minutes in 80 degree weather.. stayed constant at 180.
    I am happy
    Nothing Leaking.... I am happy
    side gl*** installed. and the operation is flawless.
    I am happy
    Now waiting for my interior guy to install the headliner so I can install the from and rear gl***.
    Hurry up and wait.
    ha ha
    Very happy with the sound and idle.... very crisp and fresh.
    brEad, GordonC, Okie Pete and 21 others like this.
  20. Jeff Norwell
    Jeff Norwell
    MODERATOR
    So. I have a ton of used interior pieces.. the rear seat is in great shape. so I hit it hard and is gonna come out clean....Gonna rent a steam cleaner to hit the fabric..... The rear quarter side panels came out mint...
    So while I wait for head liner.I will do the flooring and side panels....
    brEad, GordonC, Okie Pete and 13 others like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    I bet when they told you that you were going to clean up in the old car business , this wasn’t what you had in mind …Lol
    brEad, GordonC, enloe and 6 others like this.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hahahah..... yea. cleaning up 65 year old DNA was not what I had in Mind Mark.
    ha ha ha
    Hence. the rubber gloves.
    Okie Pete, enloe, 57 Fargo and 3 others like this.
  23. Texas57
    Texas57
    That cleaned up great, Jeff...what are you using for carpet?
    enloe and Jeff Norwell like this.
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I have factory carpet Rich.
    enloe likes this.
  25. Oneball
    Oneball
    That sounds fab!
    What oil do you use? I need to change the running in oil out of mine.
  26. Roothawg
    Roothawg
    What could have possibly happened in the back seat of a full sized Ford? Ewwwwwwwws
  27. 41 GMC K-18
    41 GMC K-18
  28. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I was using a Brad Penn green 10w-30 Tim...... but it is hard to find around here.. so I am now using the Lucas Hot Rod oil.... a 10w30 or 40.....
    It's a non detergent that is somewhat affordable.(if you can even say that today)
  29. Oneball
    Oneball
    Thanks Jeff. That’s what I was thinking of using too as it seems readily available here as well.
    Really like the look of your two ‘57s, never paid them much attention before your threads.
  30. Jeff Norwell
    Jeff Norwell
    MODERATOR
    1.jpg 1a.jpg 2.jpg 3.jpg Well...... Progress continues in the Neater Beater....
    Junk yard rear seats in and cleaned...(more to clean later).. Q-panels in test fit the free carpet.... final install and smooth out any bad wrinkles, Unfortunately there is a small tear in the base rear seat but ehh... I don't care... One day. there will be a new fresh interior... but not this year..... installed the Sills and used some old free expired Race belts... I think they suits the car.
    Threw the bench in..... if I can't find any door cards to match.I will make my own in Black....
    Headliner to be installed this weekend ,then the front Windshield and rear gl***..
    This is drawing close to getting finalized.
    Oh yea. Safety third..Threw in a Fire extinguisher..... Seen too many cars burn to the ground.
    Stogy, brEad, GordonC and 13 others like this.
