Hot Rods Top Banana Style Slingshot Dragster- Marty Strode-Chris Kopp.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 7, 2024.
  1. Marty Strode
    Marty Strode
    brEad, Kiwi Kev, Jacksmith and 11 others like this.
  2. AmishMike
    AmishMike
    Where is the 200k 18 wheeler with couple rails, Ferrari to cruise & push car? I am old enough to think tow rail on open trailer then tow car push starts. Sorry old man idea. Love your cab over.
  3. wrenchbender
    wrenchbender
    I towed my dragster many times with a 55 ford wagon never had a push bar on my car but my buddy traveled all over with me in his 57 Chevy wagon and push started it many times with it now he has his own dragster and I’m working on another push car a 62 Plymouth 2door
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Tha Surfers push started their AA/FD with a shoebox... with a 235 inline six.
  5. DDDenny
    Ever notice the 55 Chevy two-tens in the background of drag photos back then.
    chryslerfan55, chriskopp and porkshop like this.
  6. verde742
    verde742
    what will that '56 bring ? Its sweet !!!
  7. Marty Strode
    Marty Strode
    I don't know Bob, It is clearly one of the nicest of the one year only Parklane models. The plating is all new and done at Oregon Plating, when they were in business. I can't say enough about the guy that owns and restored it, as he is a perfectionist. Of the 10 Track Roadsters I built, his was the best in it's finished state.
  8. Marty Strode
    Marty Strode
    I got the rear end mounting brackets and frame plates fit and tack welded. I make it a point to sandwich a thin .050 spacer between the brackets, to allow for paint, and ease of ***embly. The new steering box from Strange showed up, and tomorrow, Chris and I will define it's location and mounting. I have 8 days to have it on the ground and rolling, so I can take it to the Portland Transmission Spring Cl***ic, the best local show anywhere ! IMG_0408.jpg IMG_0409.jpg IMG_0410.jpg IMG_0411.jpg IMG_0412.jpg IMG_0413.jpg IMG_0414.jpg IMG_0415.jpg IMG_0416.jpg
  9. patsurf
    patsurf
    nice tip on that spacer!--beautiful
  10. Marty Strode
    Marty Strode
    I moved the axle plates to the outside, and I think it looks better. We settled on the location and mounting of the steering box. We also moved the roll cage test hoop back an inch and a half, that should making entry and exit a little easier. The area along side the left side of the transmission is tight for my foot, so we decided on removing the Low-Reverse shift fork, and remove the boss from the side. I don't need those gears anyhow. Busy this weekend on the front spring perch, and other items. IMG_0419.jpg IMG_0424.jpg IMG_0425.jpg IMG_0426.jpg
  11. Larry Anderson
    Larry Anderson
    Are you doing any sort of funny car cage work above your head. That’s a lot of noggin exposed dude. I’ve clanged mine a few times and went through concussion recovery. I think I recovered just fine, my ex wife has a different opinion.
    chryslerfan55 and brEad like this.
  12. Marty Strode
    Marty Strode
    It will have a 5 point, SFI spec roll cage, on the order of this. IMG_0430.jpg
  13. Marty Strode
    Marty Strode
    IMG_0431.jpg IMG_0432.jpg I have been sweating bullets, wondering if my friend would be able to shorten and re-spline the transmission tail shaft, due to the hardness. He did a masterful job, so now I can finalize the engine location in respect to the rear end coupler.
  14. AmishMike
    AmishMike
    Did he, or does he need to re-harden? Should you have a spare just in case? Getting closer & look forward to some test p***es. Will you be ready by summer end?
    porkshop likes this.
  15. Marty Strode
    Marty Strode
    Thats the goal.
  16. 1971BB427
    1971BB427
    from Oregon
    Marty, have you seen the 7 day forecast for weather? Sudden change mid week, and supposed to be 87 degrees for PTW show on Saturday! See you there!
    chryslerfan55 and porkshop like this.
  17. Marty Strode
    Marty Strode
    Great weather, bringing both the '29 and the Dragster, going to be fun !
  18. Marty Strode
    Marty Strode
    My friend Dean came today and after we measured the tail shaft and did a mock up, we decided to move the engine another inch forward. On final ***embly I can shorten the coupler a little for a perfect fit. After that, I made some front engine mounts out of 1/4" aluminum. I can now tack weld the brackets to the rear axle housing, and finish the front spring perch I started on yesterday. IMG_0433.jpg IMG_0434.jpg IMG_0435.jpg
  19. Max Gearhead
    Max Gearhead
    from Wisconsin
  20. Larry Anderson
    Larry Anderson
    What time does that shin dig start. Saw one thing online that said 5am and another that 7am.
  21. bymanr
    bymanr
    I heard that if you’re not there by 6 you’ll be parking a long way off.
  22. DDDenny
    True story!
  23. oj
    oj
    Shades of the SPE box, little jewels for sure.
  24. Marty Strode
    Marty Strode
    I never had one of Roy's boxes, but had and steered a few with a P&S boxes. In all reality I should have modified a Crosley gear that would be more appropriate, and I have a couple of those. The good part is, it's a bolt on item, and I could change it anytime.
  25. Marty Strode
    Marty Strode
    Got the adjustable front spring perch done, with the exception of the gussets on the front . IMG_0447.jpg IMG_0448.jpg IMG_0452.jpg IMG_0453.jpg IMG_0455.jpg IMG_0457.jpg IMG_0461.jpg IMG_0462.jpg
    OFT, ratrodrodder, Dean Lowe and 18 others like this.
  26. Marty Strode
    Marty Strode
    I finally got around to fitting the rear motor plate. Rather than trust measurements, I made a sample plate out of .050 aluminum. That way I could get it to fit, by t******* here and there, and transfer it to the actual plate, as one slip could cause a 220 dollar loss and a weeks wait. It went well, and I was able to get the majority of the ch***is welding done, so I can pull it out of the fixture tomorrow. Still want to get the roll cage and steering box mounted before the show on Sat. IMG_0470.jpg IMG_0464.jpg IMG_0465.jpg IMG_0467.jpg IMG_0469.jpg
  27. Marty Strode
    Marty Strode
    The front axle is dropped and it should arrive next week, can’t wait to see it installed . IMG_5778.jpeg IMG_5775.jpeg
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Are you gonna drill it?
  29. Marty Strode
    Marty Strode
    Na, I can’t bring myself to do that.
    Dean Lowe, Oneball, pirate and 3 others like this.
