Just a general question about paint for metal
Discussion in 'The Antiquated' started by Roothawg, Apr 29, 2024.
  1. Roothawg
    Roothawg
    IMG_3578.jpeg I am looking to paint a new gate I built for the Dust Bowl Speed Shop World Headquarters. What is a decent exterior type paint that I can paint the gate with? I want something that won't fade. Spray paint just doesn't last these days.
    Just a semi gloss black. Implement paint? Just an enamel paint? It's bare metal, unprimed.
  2. Roothawg
    Roothawg
  3. BamaMav
    BamaMav
    from Berry, AL
    I’ve used it before with good results on bare metal. I’ve also used the stuff Tractor Supply sells in the tractor paint aisle. Black seems to hold up pretty good, red usually fades after a while.
    SS327 and Roothawg like this.
  4. RMR&C
    RMR&C
    from NW Montana
    I like Valspar enamel. Nothing will last forever outside in the sun.
    jimmy six and Roothawg like this.
  5. Roothawg
    Roothawg
    It will have wood on the facing, so you won't see much of it, but I worry abut water getting trapped between the two.
  6. Whoamel
    Whoamel
    from So Cal
    I have a wrought iron gate with a metal mesh on it. (Sounds strange but it looks okay) I used Rustoleum spray paint on it, and the rust would always come back on a yearly basis. After doing this about three times, I ordered a quart of automotive acrylic enamel. You do need some hardener, reducer, and a spray rig. It's held up at least ten years now, and I live about a mile from the beach.
    I sometimes use spray paint on very small parts, and it generally does okay if the part is clean and primed, but it just didn't hold up on the outside gate.
    Roothawg likes this.
  7. Okie Pete
    Okie Pete
    Van Sykle implement paint if You can find it . Go to an oil field supply and get some tank steel paint and primer . Those oil patch guys use some good stuff .
  8. We used some PPG water based industrial paint a while back on a sign.
    It was a new metal sign cut from hot rolled steel.
    We used an acid to remove the blueing
    Then used their primer and paint
    It’s been in that outdoor sign for close to 10 years
    Pitt-Tech is the name
    There’s also a DTM water based version
  9. clem
    clem
    Etch primer then top coat, to answer your question.
    Although if not using tantalised wood, have you considered hot dip galvanising it, use it unpainted for 6 to 12 months, then paint it as it will then last for a very long time.
  10. Beanscoot
    Beanscoot
    What in tarnation is "tantalized wood"?
    Is that a New Zealand thing?
    SS327 and down-the-road like this.
  11. clem
    clem
    T****ised , not tantalized - spell check auto correct. Sorry.
    CCA treatment - copper, chromium, ****nic treatment
    Might be a New Zealand thing !
    down-the-road likes this.
  12. Roothawg
    Roothawg
    I just bought a quart of Rustoleum. It should suffice. I put a coat on. Just waiting to recoat.
  13. Beanscoot
    Beanscoot
    Yep, T****ised still is a new word to me.
    I sure wouldn't want to be T****ised.
    SS327 likes this.
  14. Roothawg
    Roothawg
    I dated a dancer once that could do that.
  15. clem
    clem
    No one would ! - you wouldn’t actually survive the process……….
