S10 clutch disc same as Astro?
Discussion in 'The Hokey Ass Message Board' started by lt1tyrell, Aug 12, 2013.
  1. lt1tyrell
    lt1tyrell
    from Canada
    Hey, about to do my T5 swap in a 66 c10, but I am having trouble getting a clutch disc around here for an astro van. From what I understand they are a little bit bigger than the s10 but the s10 disc should still work fine right? Does anybody have a napa or any other part number for just the disc for one of these vans? Thanks a lot.
  2. do a t5 swap search here, there are several good threads with part numbers.
  3. gimpyshotrods
    gimpyshotrods
    SACHS Part # BBD4212
  4. Woob
    Woob
    from Falcon, CO
  5. lt1tyrell
    lt1tyrell
    from Canada
    Thanks for the tips...reason I am asking again is because I am still struggling to find just the disc for an astro van in canada. Part numbers can be different and we don't have O'Reilly, Pep Boys etc OK?
  6. lt1tyrell
    lt1tyrell
    from Canada
    Thanks for the SACHS number I will see if any local guys can order that one for me.
  7. fastcar1953
    fastcar1953
    order online. i think oriellys will even ship to home adress . also autozone. or thiers ebay.
  8. cooljralan
    cooljralan
    from nc
    s10 clutch for a 4.3 will be an 11" with the 14 spline. I did the swap couple years ago on my 53 chevy truck. check length of input shaft, some of those are longer.
  9. outlaw57
    outlaw57
    napa had my astro clutch in stock
  10. BobMcD
    BobMcD
    RockAuto should have what you need.
  11. lt1tyrell
    lt1tyrell
    from Canada
    Thanks guys, tried my local napa with no luck because all they will sell is a complete clutch kit, tried some other local parts stores and they said the same thing and I cant find a shop that sells SACHS clutches around here. So I guess I just have to order one from the US and get boned on the shipping! But thanks again for the part numbers and suggestions.
  12. George G
    George G
    Typical HAMB, long on opinions and search nazis and short on specifics.
    You need NAPA Part number cp4212 11 inch x 14 spline x 1 inch from a 1987 Astro with a 4.3 engine. The GM part number is 15551426.
    Has worked 100 % in my AV8 with a T5. The S10 has a 10 inch clutch.
  13. gimpyshotrods
    gimpyshotrods
    Weird. I can't get that in the U.S. catalog.
  14. sc105b
    sc105b
    Rock Auto had 2 lest of the Sachs part # the other day. They had 3 & I bought one.
    Around here they won't sell you just the disc so save some time & just order it & be done...
  15. lt1tyrell
    lt1tyrell
    from Canada
    They might have discontinued that part number because I could not find it on the Canada website or at the local napa.
  16. Mike51Merc
    Mike51Merc
    Rockauto's online catalog is a great source for cross referencing parts.
  17. RMR&C
    RMR&C
    from NW Montana
    Rock auto was the only place I found I could buy just the disc. Everywhere else only listed the complete clutch kit.
  18. lt1tyrell
    lt1tyrell
    from Canada
    I know this is getting old but I literally can not find one anymore anywhere online, rock auto has none left, o'reillys does not and Napa will not sell a disc anymore. I am going to try get ahold of rock auto and see when they will have more in stock. Even Summit racing used to have a ZOOM brand disc but dont carry it anymore...
  19. 2racer
    2racer
  20. X-Farmboy
    X-Farmboy
    Call Brake and Clutch Supply, Waco Texas. 254-752-4307. Bought mine 2 mos. ago, great guy, knows Ed Zachary what you need. $80 + shipping.
  21. gimpyshotrods
    gimpyshotrods
  22. lt1tyrell
    lt1tyrell
    from Canada
    Perfect thanks!
  23. George G
    George G
    Old post. But Speedway motors stocks clutch discs for their T5 to flathead adapter
