Hot Rods Rear Hot Rod Tires
Discussion in 'The Hokey Ass Message Board' started by A Boner, May 2, 2024.
  1. A Boner
    A Boner
    Would these tires be suitable for rear tires on a Model A traditional hot rod? Not seeking a lawyer’s opinion, or DOT opinion, but just a common sense opinion, from someone with actual hot rod experience. The “E” load range are quite stiff, but running with lower tire pressure usually seems to be help, some. The speed rating is quite low, but is that measured with a heavy load…way heavier than any Model A hot rod. Not talking any racing stuff, more for just cruising. They sure have the old Dry Lakes look!
    pecker head, Sharpone, Deuces and 2 others like this.
  2. Jalopy Joker
    Jalopy Joker
    the stiff sidewalls will not help comfort of ride
    Sharpone, Deuces, clem and 3 others like this.
  3. A Boner
    A Boner
    The stiff sidewall can somewhat be countered by running a lower tire pressure. Actually I’m more concerned about the somewhat low speed rating…comfort, not very worried!
    Sharpone and chryslerfan55 like this.
  4. Dan Hay
    Dan Hay
    Dang, 10 ply, they'd last forever. But yeah, stiff ride. I think Big Ken was the one I was thinking that would get the Chinese trailer tires for his 34 pickup.
  5. sidevalve8ba
    sidevalve8ba
    10 ply ratings will ride like a buckboard.
  6. Mr48chev
    Good lord, those would ride rough as hell on my car trailer. They are for a 10,000 lb rated trailer with 4 tires. Plus the manufacture says not suitable for light trucks. Screenshot (98).png
    Sharpone, Almostdone, Deuces and 6 others like this.
  7. BamaMav
    BamaMav
    from Berry, AL
    Hell, with a 10 ply, you wouldn't even need air in them to hold up an Model A! :eek::eek::eek:
  8. krylon32
    krylon32
    from Nebraska
    They are trailer tires not meant for p***enger car or pickup use. I understand money can be tight and getting tighter but the safety of your self and family are more important than not getting the right tires. Tires are no place to scrimp.
  9. A Boner
    A Boner
    How about these? 7:00x 15…29.5 diameter, load range D
    Deuces and oliver westlund like this.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I would not venture out in the rain. The tread is meant to just 'tail' along not transfer power.
    Not being bossy bu ut,, Keep looking
    Sharpone, twenty8 and mad mikey like this.
  11. A Boner
    A Boner
    These are listed as light truck tires…load range D…but only 15”…seems like 16”are all load range E…30” diameter
    Sharpone likes this.
  12. RMR&C
    RMR&C
    from NW Montana
    Do you need 15s or 16s? Those are 2 different sizes
    oliver westlund likes this.
  13. dodge35
    dodge35
    from kentucky
    The picture he posted were 16" tires.
  14. caprockfabshop
    caprockfabshop
    Those are still 8 ply, meant for semi trucks and box trucks. Way overkill for a hot rod, and even with low pressure will be overly stiff.
    Here are some more "budget" oriented tires I'd recommend in 16" diameter:
    https://www.cokertire.com/tires/700-16-firestone-blackwall.html
    https://www.cokertire.com/tires/pirelli-stella-bianca-600-16.html
    https://www.cokertire.com/tires/avon-tourist-600-16-86l.html
    https://www.cokertire.com/tires/650-16-garfield-blackwall.html
    https://www.cokertire.com/tires/650-16-excelsior-black.html
    mad mikey and A Boner like this.
  15. Sharpone
    Sharpone
    I looked on the Discount Tire site they have several 225 75 16 tires from $140 to $300 , black walls and letters ,AT to highway tread, a 75 aspect ratio won’t be as tall as a 90 however I think they’ll look ok. Coker has tradition tires but they’re pricey
    Dan
  16. A Boner
    A Boner
    Would like 16”, but like I said only load range E offered with 16”,
    and only the 15” offer load range D
  17. A Boner
    A Boner
    No way…8 ply tires are never used on a semi-trucks or box trucks (except maybe a Chevy Luv box truck). They are more appropriate for 3/4 ton pickup trucks, or maybe heavy duty half tons.
    The modified in my avatar pic has 15” tires with load range D rating, and it rides great! Only pump rear tires to 18 lbs. though.
    The 6:00 X16 tires aren’t tall enough for my application.
    Oh, and Coker tires aren’t what I would call my go to brand!
    MMM1693 and SS327 like this.
  18. caprockfabshop
    caprockfabshop
    Same here, too many stories of premature failure and wear, and then when complaining Coker claims that they're tires are meant for display/parade use only or some other thing to avoid having to pay for replacements. I just use their site for identifying brands and sizes I'd like and then see where I can buy them. I've used kelseytire.com as well as widewhitetires.com both great companies.
    Oh, and I guess I meant those 8-plies would've likely come on vintage heavy trucks and semi's, not modern. Obviously loads are heavier nowadays and speeds higher
    ~Peter
  19. jimmy six
    jimmy six
    Trailer tires don’t say “trailer” on them for no reason…
    duecesteve, Sharpone, twenty8 and 5 others like this.
  20. justpassinthru
    justpassinthru
    So, just what make it unsafe, to use a trailer tire on a car?
    Trailers are going at highway speeds all the time.
    Sure the ride will be rougher.
    I cant see the wet traction being any worse than a bias ply.
    There must be some other reasons, other than they are just not DOT approved for cars and light trucks.
    Bill
    pecker head and oliver westlund like this.
  21. Zax
    Zax
    Sharpone and swade41 like this.
  22. tubman
    tubman
    I kinda agree with this. Some of you guys would be amazed at what we would run back in the "traditional" days.
    We ran implement tires on the dirt track because they were cheap and looked like real front end "race tires". (They were rated at 25 mph max.)
    caseywheels and oliver westlund like this.
  23. Is this some sort of skill testing question?
  24. alanp561
    alanp561
    In reference to your comment, "I can't see the wet traction being any worse than a bias ply". It's obvious that you've never had a trailer try to p*** the truck you're driving when the road is either wet or iced.
    twenty8 likes this.
  25. justpassinthru
    justpassinthru
    I've pulled my car trailer that has trailer tires, in sun and rain and snow at highway speeds and it has never tried to p*** me up.
    I'd like to know what is actually different in the construction of the tire that makes them unsafe to use on a car?
    I don't think the ply rating of the tire is the only factor.
    He'll I have run 8 ply Mickey Thompson Sportsman bias ply front tires on my BBC street/strip Nova for years without issue.
    Aside from the somewhat flat tread pattern on many trailer tires, compared to an old fashion bias ply, the tread patterns are very similar.
    Bill
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Would those tires be any harsher than todays big-inch rims with rubber band tires? I see them on hot rods.
    wretch
  27. A Boner
    A Boner
    Just trying to find some traditional looking Hot Rod tires that preferably:
    1. Are round
    2. Fit on 16” rim
    3. Last more than 10,000 miles
    4. Cost under $150.00 each
    5. Actually look traditional…no billboard lettering, or fancy **** on the sidewalls
    6. Ride ok… not ridiculous, but don’t have to be silky smooth either
    7. 30”to 32” diameter range
    8. Fit on 5”- 7” wide rims
    If you locate some…post them here, as hopefully you have noticed, the normal world has gone to low & lower profile tires, and tall skinny tires are becoming quite rare, and hard to find.
  28. SS327
    SS327
    I would try to run them, just air down like you said. Not like you’re going to race it as you said.
  29. A Boner
    A Boner
    They are actually only 1” different…actually 1/2” different at the top and 1/2” different at the bottom!
    crazycasey likes this.
