Technical ***May 2024 Banger Meet Thread - Remember your Mom this month***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 2, 2024.
  1. Jiminy
    Jiminy
    Link to previous month: April 2024 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    May 26, 2024 4 Ever 4 Antique Nationals at Irwindale Raceway in SoCal.
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    302GMC and GuyW like this.
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
    WOW! Never been 1st before…!
  3. 62pan
    62pan
    I'm here
    winduptoy likes this.
  4. Crazydaddyo
    Crazydaddyo
  5. Fabber McGee
    Fabber McGee
    Wow, Daddyo, that looks like really high compression. Will you have to round over those sharp edges to prevent hot spots and pre-ignition? Cool ****, my man.
  6. denis4x4
    denis4x4
    from Colorado
    Was hoping to get the A running this weekend, NAPA let me down on delivering some key parts.
  7. Airborne34
    Airborne34
    from Texas
    Checking in!
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    Anyone heading to Bakersfield for the swap meet on Saturday…? I’ll have a spread of Winfield and Buffalo goodies set up. Don’t recall the space number off hand, but know I’ll be near the back fence with all the other prewar crew:cool:
  9. 29Sleeper
    29Sleeper
    from SoCal
    Antique Nationals
    Outback, Crazydaddyo and winduptoy like this.
  10. 4BangerDean
    4BangerDean
    Checking in, Got the later ge****t in the B box. It’ll be running soon.
    Outback, 51 mercules and winduptoy like this.
  11. alchemy
    alchemy
    I’ll be doing that on my current project. Do they fit the same as a later V8 case, or do you need to do the drop the cluster thingy?
  12. 4BangerDean
    4BangerDean
    It’s the first time I’ve ever taken a transmission apart. It really wasn’t too difficult but I learned quite a bit. From my understanding if you’re putting the ge****t in the correct case, the front retainer bearing is pressed on the main shaft before ***embly. On the B case the bearing needs to be pressed on with the input shaft in the case. I guess in some instances the B case needs to be clearanced for the cluster gear. My case didn’t require this.
    51 mercules, winduptoy and alchemy like this.
  13. Savage Coupe
    Savage Coupe
    from Washington
    Outback, GuyW, 29 Speedster and 4 others like this.
  14. Dan from Oakland
    Dan from Oakland
    More pics please and a little history!!!!!
    the grumpy.o.b likes this.
  15. Stovebolt
    Stovebolt
    A deal that was in the wind since forever finally came off (in part) for me last weekend.
    I got 'paid' for a bunch of stuff in the form of a repop stromberg 81.
    The dealer out here agreed to swap an unopened 97 for another 81.
    My friend and I drive over to purchase one 81 and swap over the other one ...... and they only have one 81.
    So my plan to set up my twin carb intake over our winter incurred an indefinite delay.
    Oh well, I'll just have to sit back and read the banger threads until it arrives
  16. BLACKNRED
    BLACKNRED
  17. winduptoy
    winduptoy
    Checking in.....
  18. wuga
    wuga
    May the four be with you.
    Warren
  19. Crazydaddyo
    Crazydaddyo
    Still scratching my head on this one. This is a "one of these days" projects. The pistons have room for improvement.
  20. CDO
    we should chat about this in the future
    I may have some pistons that came from this setup
    J
    Crazydaddyo likes this.
  21. 29Sleeper
    29Sleeper
    from SoCal
  22. Kevin Pharis
    Kevin Pharis
    from Califunny
    Not sure why I bought it… but the price was right! Hell, I don’t even own a model A;)
    Anyone have the drawings to machine this thing…?
  23. 4BangerDean
    4BangerDean
    Looks very interesting. I hope it can be identified. I haven’t seen much Bsnger speed equipment here in Illinois.
    winduptoy and Outback like this.
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    It’s a pretty rough casting and also has a touch of corrosion on one corner. There are also some small welds here and there to fill imperfections and voids. I believe the corrosion will be removed during machining and it should hold oil when done. Don’t know if I need to keep it, but would definitely like to finish the machine work either way…
  25. Dan from Oakland
    Dan from Oakland
    Musta been made for a heck of a stroker with those pads on the sides for rod clearance!!
  26. 25mercury
    25mercury
    DSC05159.jpeg Hey Kevin, You can borrow mine.
  27. joemac05
    joemac05
    What is that, an oil pan, please advise... ??? :eek:
    Outback likes this.
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    Wowza Mike! Yours has a muuuch nicer mold quality than mine. Interesting how several of the pan bolts were abandoned due to the rod clearance. Mine is not relieved under the front oil seal, just a big hunk of aluminum. At first I thought this was a ****py copy of someone’s work of art, but the sand mold would have required several cores and mold inserts that would not have been easy to fake on the fly. Someone spent a lot of time making the patterns for this thing… then never finished it:rolleyes:
  29. 25mercury
    25mercury
    phr-1964-jg-4copy.jpeg Kevin, I had a rough casting like yours and sold it to the late Bob Lee 35 years ago. I bought it from a fellow who had a lot of Gemsa stuff and he told me it was Gemsa. I wonder if that's the casting I sold Bob. The pan in my photo is an older Dan Price piece, who told me he cast it from the Rutherford patterns that he had. Note that there is no provision for an oil pump, you must run a pump off the front timing cover. The magneto cross drive cover in my picture is an Evans with a dry sump pump. You're welcome to borrow my pan if it will help with machining.
  30. Outback
    Outback
    from NE Vic, Oz
    You just never can tell what cool parts turn up each month!
    Oh yeah I'm here :)
