Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. From Six Ball:
    Your '35 was also in the background of Ryan's coverage of the L.S.R.U.
    snoop74 and Six Ball like this.
  2. Jay Altemus
    Jay Altemus
    Yes. I’ll put a slotted hole in it like the original.
    nunattax and Six Ball like this.
  3. snoop74
    snoop74
    This is bad ***, the guy driving that car helped me tarp my car. Where did Ryan post this?
    31chevymike likes this.
  4. Jay Altemus
    Jay Altemus
    Cleaning up my driver side door. Today I removed primer sprayed by someone else. Didn’t find any body filler. Lower flange is intact. Tiny tiny dents at the front edge just below the body line bead. I’m very fortunate that my doors are in such good shape.
    TFoch, Six Ball and tb33anda3rd like this.
  5. tb33anda3rd
    tb33anda3rd
    don't be surprised after you clean the inside of that door bottom you find some pin holes
    snoop74 and Jay Altemus like this.
  6. I was scoping the Traditional Forums and found the thread that he started, showing his coverage of the Round Up. That photo was enlarged and used at the top of his thread and instantly saw your hot rod in the background - VERY COOL HUH?
  7. Wouldn't Jay benefit if he added some drain holes to the bottom of both of his doors, in case he gets caught in a rainstorm? If I might add, before Jay gets her back on the road, coat the entire bottom of both bottoms of the doors with black POR-15.
  8. tb33anda3rd
    tb33anda3rd
    the doors originally had a relief at the ends of the filler board that went against the outer tin to drain any water that got inside.
    probably best to sand blast the rust off than to rely on the chemical hocus pocus.
    31chevymike and Six Ball like this.
  9. Chuck Craig
    Chuck Craig
    from Ocala FL
  10. Chuck Craig
    Chuck Craig
    from Ocala FL
  11. brokedownbiker
    brokedownbiker
    I'm getting close to putting my '31 coupe on the road (not done by any stretch of the imagination but driveable). A buddy stopped by and we got to talking about door garnishes and metal parts on the doors. The top of my doors (the part that points at the sky when open) are bare wood, he says there should be a metal strip up there- makes sense, all the wood is protected by metal on the rest of the car. I got this car as an empty shell and a bunch of boxes so I've never seen it complete.
    Does anyone have a photo of that area or of the part that should be up there?
  12. brokedownbiker
    brokedownbiker
    Chuck it looks like the one on my ‘41 Chevy sedan
  13. Shitbox
    Shitbox
    from Nor Cal
    I’m 98% sure there isn’t a metal cover for the top of the doors. I’d have to put together an old computer to confirm, but went through my door parts and interior parts and there’s none. Pretty sure it was just painted wood tacked to the shell with a small gutter cut into it.
    You might try hitting up @31chevymike to confirm. There’s a few 31 bowtie builds here if you use the search function(also in the sticky build thread).
    31chevymike, 31 B'ville and Six Ball like this.
  14. tb33anda3rd
    tb33anda3rd
    my first thought also that both the top and bottom had exposed wood. painted to match the metal.
    31chevymike, Six Ball and Shitbox like this.
  15. I just took these tonite and saw no metal covering the wood on top of the doors. The latest door I picked up recently is just like yours, with no wood in it. When you're ready for the upholsterer, the shop can take care of covering the wood altogether.
    IMG_ 20240501_214751.jpg IMG_ 20240501_214925.jpg IMG_ 20240501_214952.jpg IMG_ 20240501_215039.jpg IMG_ 20240501_215200.jpg IMG_ 20240501_215315.jpg
  16. brokedownbiker
    brokedownbiker
  17. You're welcome - have you started a thread yet? If you don't plan to, let's see some detailed pics!
    Shitbox, snoop74 and Six Ball like this.
  18. Jay Altemus
    Jay Altemus
    Bead roller was on special. Bought extra dies because I plan to try some difficult bends to make new rocker panels. At the very least I’ll be able to make floor panels.
    Pretty happy with it. Better ones on the market but for 5X the money.
    This was just a test on 20 gauge galvanized steel.
    IMG_5617.jpeg IMG_5618.jpeg IMG_5621.jpeg IMG_5622.jpeg IMG_5623.jpeg IMG_5624.jpeg IMG_5625.jpeg
    GuyW, TFoch, Six Ball and 2 others like this.
  19. snoop74
    snoop74
    buddy of mine bought one and we plan on using this for my inner door structure
    Six Ball and 31chevymike like this.
  20. snoop74
    snoop74
    IMG_8976.jpeg IMG_8977.jpeg IMG_8965.jpeg IMG_8978.jpeg Rear main seal been leaking.. had to drop the pan and put in these stupid tabs on the main cap
    TFoch, Six Ball and Jay Altemus like this.
  21. Jay Altemus
    Jay Altemus
    Stripped everything out of my p***enger door. I often wonder how shocked a 1934 factory ***embly line worker would be if he knew what we would do to these old cars 90 years later.
    1934 Chevy Master coupe
    IMG_5635.jpeg IMG_5634.jpeg IMG_5631.jpeg IMG_5641.jpeg IMG_5643.jpeg IMG_5645.jpeg IMG_5657.jpeg IMG_5656.jpeg IMG_5653.jpeg
    TFoch likes this.
  22. brokedownbiker
    brokedownbiker
    Not yet, I'll try to get one going as soon as things settle down around here.
    Six Ball likes this.
  23. Six Ball
    Six Ball
    from Nevada
    Is that just oil lines on the bearing?
  24. snoop74
    snoop74
    yeah lol once I wiped it down it was fine. I realized that when I took the pic hah
  25. Sounds good, I have an extra p***enger side door, a nearly perfect original steel gas tank apron (which I had painted Tangerine from an auto body shop), the bottom seat spring for the rumble seat (reproduction - never used), the original fuel tank and other parts if needed.
  26. Six Ball
    Six Ball
    from Nevada
    You scared me!:D
    snoop74 likes this.
  27. Jay Altemus
    Jay Altemus
    Did some media blasting of my p***enger door. There will be some pin holes along the bottom 3 inches. Oh well. Rest of the door is cleaning up nicely.
    TFoch, snoop74 and Six Ball like this.
  28. Six Ball
    Six Ball
    from Nevada
    Looks good! My life would be a lot easier if I could run a compressor big enough to do that.
    snoop74 likes this.
  29. Jay Altemus
    Jay Altemus
    Both doors are sanded.
    1934 Chevy Master coupe.
    Primer soon.
    What can be applied to the bare metal to deter flash rust until I put primer on? What do y’all recommend?
    Also, added 2”x 2” square tube to the bead roller plate to reduce plate flex. It’s a common upgrade shown on dozens of YouTube videos.
    Before I added the 2” tube I could flex the 1/2” steel plate with thumb pressure because of 19” of leverage.
    Now, same 19” but I can’t flex the plate.
    Countn'Carbs, TFoch, GuyW and 3 others like this.
  30. Jay Altemus
    Jay Altemus
    I’ve been gathering the necessary tools to fabricate repair panels. Bead roller, sheers, and now a stretcher and shrinker set. Gotta build a stand for them with foot pedals.
    This weekend I hope to work on the frame too. Got both doors stripped and interior metal in primer. Y’all have been quiet.
    tb33anda3rd and Six Ball like this.
