Technical Chevy 283 PCV.....
Discussion in 'The Hokey Ass Message Board' started by Chev63, May 5, 2024.
  1. Chev63
    Chev63
    I've purchased a 283 the had the PCV fittings plugged with RTV!.....Can I change this fitting for the earlier type?
    chevy57dude likes this.
  2. Chev63
    Chev63
    Like this....
    X-cpe likes this.
  3. Chev63
    Chev63
    And do I need to fit a baffle?
  4. '29 Gizmo
    '29 Gizmo
    from UK
  5. Chev63
    Chev63
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Not sure. I thought all 283s had a draught tube.
    chevy57dude and Chev63 like this.
  7. SS327
    SS327
    If you go to a road draft tube you will definitely need the in block baffle.
  8. 427 sleeper
    427 sleeper
    The answer is yes to both of your question's. You have to install the baffle and you can use the fitting shown. Not sure why the baffle was removed in the first place. :confused:
    Chev63 and chevy57dude like this.
  9. Bob Lowry
    Bob Lowry
    I always did/do a pcv system using what Chevy offered...
  10. blue 49
    blue 49
    from Iowa
    The virgin '64 283 I tore down last year had the hose ****** in the road draft tube hole, baffle and an inline PCV valve. It will go back the same way, if I ever get it back from the machine shop.
    Gary
  11. squirrel
    I think 62 was the last year for road draft tubes. The fitting you show in your second post is what you want to run PCV. You also need to have another opening, hopefully there's a tube sticking up at the front of the intake manifold, with an open breather cap on it?
    Just because someone had a 67 with a draft tube, doesn't mean that's how the car was originally built.
    oh-- i looked in the Chevy parts book, 1962 was indeed the last year for the draft tube, it's part number 3776635 in group 1.762 if you want to look it up yourself.
  12. jimmy six
    jimmy six
    Stock 283-327’s from 62-up used the little teapot fitting and internal baffle until they went to the valve cover system and changed the blocks.
    The PCV valve screwed into a 90* fitting at the rear of the carb base. The early valves were cleanable the replacements are not. A Standard V100 is readily available and will work fine on almost all engines with a threaded fitting.
    These parts were used on a y-block Ford with dual quads. A 3/8” hose with many bends is available at Auto Zones at the back of the store near all the “Help” products…none of this is rocket science. The valve is a serviceable NOS found at a swap meet. IMG_3647.jpeg IMG_3651.jpeg IMG_3640.jpeg
  13. '29 Gizmo
    '29 Gizmo
    from UK
    I think there is some confusion. There are three breather systems used in the 60s. The original draught tube that vented to atmosphere down below the motor, this evolved into a vent that connected to the air cleaner housing so vented back into the top if the carb and the third type that is actualy a PCV that uses manifold vacuum.
  14. squirrel
    There are "open" and "closed" PCV systems. The open ones have an open breather cap. The closed ones vent to the air cleaner. They both use vacuum and a PCV valve.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    20240505_112031.jpg The PCV valve setup on a Rochester 4GC from a '64 327 .
  16. DDDenny
    My 327/325 hp (same as 350 hp).
    66/67 style.
    The odd one is the 1965 Corvette that most people outside the Corvette group do not know about, it did not use a pcv, instead, it had a metered orifice in the carburetor body.
    Algoma56, Chev63 and jimmy six like this.
  17. pprather
    pprather
    Chev63 likes this.
  18. 327Eric
    327Eric
    You definitely want the baffle in the lifter galley at all times. As for the pcv fitting, I have a rubber valve cover grommet in the back of the block on mine.
  19. Mr48chev
    This and what Bob Lowry showed. in post 9.
    Soon after Chevrolet (GM) switched from road draft tube to PCV valves you could buy the kit that Bob showed at the Chev garage parts counter and maybe through local parts houses. I installed a few of them in 64/65 in high school auto shop when someone brought one in and had us install it and word got out that you could have it done to your small block and get rid of the fumes from the road draft tube. Guys in their 70's and older can remember those cars with blow by pulling up beside them at a light and having a cloud of blue smoke come out from under the car.
    That grommet will work if you have the baffle in place and working but if you don't have the baffle oil tends to get splashed to the PCV valve.
    I've also cut a few road draft tubes off and set them up to run a PCV valve setup. Easy to do but can look a bit clunky if the engine is out in the open.
    Algoma56 and Chev63 like this.
  20. 26 T Ford RPU
    26 T Ford RPU
    What carb do you intend using? If it is one with the fitting for PCV you can't just plug it and run a draught tube, the carb is metered for this air and a PCV system must be used. JW
  21. 1934coupe
    1934coupe
    Where are you located? I have some of that stuff you can have.
    Pat
    Chev63 likes this.
  22. enloe
    enloe
    from east , tn.
    I need these pieces for my Corvette my rubber piece is broken. I would also like to get the kit that is pictured above. Does anyone know where I can get these pieces and what the part numbers are? IMG_7606.jpeg IMG_7607.jpeg
  23. Chev63
    Chev63
    I'm not sure why the baffle was removed either?....Perhaps to fit an aftermarket intake manifold?
    26 T Ford RPU likes this.
  24. Chev63
    Chev63
    Thanks!.... PM sent.
  25. 26 T Ford RPU
    26 T Ford RPU
    I dad to modify my baffle when i swapped on a Edelbrock Street Master, leaving it off was not an option. JW
    Chev63 likes this.
  26. Chev63
    Chev63
    I'm thinking I'll fit a small Holley, something like a 390 perhaps?.....And yes, I want to run the PCV system.
  27. 26 T Ford RPU
    26 T Ford RPU
    Cool, the PCV systems are easy to set up correctly if you know how they work and what not to do and to then pretend they do. JW
  28. Chev63
    Chev63
  29. enloe
    enloe
    from east , tn.
  30. Chev63
    Chev63
    I'd like to use an Edelbrock performer 2101 intake (because I already have it), is it possible with the oil baffle in place?
