Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. A-****ing-men!! I hate those wheels! I've counted over a thousand sets of those wheels at Bowling Green before
  2. swade41
    swade41
    from Buffalo,NY
    No idea why so many people put those damn things on their cars, they're f'n everywhere though.
  3. swade41
    swade41
    from Buffalo,NY
    I pulled the spacers and put a thick steel core cork gasket on, I did order another 3/16's thick cork gasket and will glue them on top of the others, not t******* those drippers just yet lol
    Touched up the paint on the lower fenders I trimmed on the henry J and have them bolted in place permanently, the to do list is short now.
  4. saltflats
    saltflats
    from Missouri
    Well this has been an education. At least knowing what I know now the next one should be a breeze.
  5. HOTRODNORSKIE
    HOTRODNORSKIE
    Checked the valve to piston clearance last week called Tony with the specs not going to work the pistons need to be notched. I didn't want to notch the Egge pistons so I'm ordering forged from Tony and having him notch them
    So out came the pistons for the third and hopefully last time. This is on my 303 rocket. 20240504_093417.jpg 20240504_093437.jpg
  6. choptop40
    choptop40
    Desoto dash panel done..made it from steel instead of aluminum...next.. trim ...gauges , switch layout....column drop cover...rained all day ....at leaat winters over..... image.jpg image.jpg
  7. swade41
    swade41
    from Buffalo,NY
    A year ago almost to the day I quit working on this mph scoop, it was a bad casting that someone filled with bondo.
    I milled it out with a hole saw in my drill press and then jumped to the same process on those valve covers that I recently finished after sitting a year. Do you detect a theme here ???
    Screenshot_20240505_181424_Gallery.jpg Screenshot_20230516_184443_Facebook.jpg
    I started whittling away at it with hand tools today, it's beginning to look like something on the one side.
  8. vtwhead
    vtwhead
    Curious what lift you have in your cam that you have clearance issues? Just went thru this with Tony myself but i was OK with my flat top pistons and his cam in my 324.
  9. atch
    atch
    Gene, as you well know that's some of the hardest work you'll ever do. Glad you got it done.
  10. choptop40
    choptop40
    some primer to see what the dash looks like... F2918823-8FF5-40E2-BD38-BC653BC3F266.jpeg
  11. saltflats
    saltflats
    from Missouri
    Well 80 mile round trip and 55 bucks I got new seals for the rams for my lift. Man this piston seal is made of hard rubber of sort. Had to put it in some boiling water to get any stretch to install it. Was like stretching a nat's *** over a hoe handle. 20240506_171541.jpg
  12. swade41
    swade41
    from Buffalo,NY
    Finished the other side, I'll bead blast the spots I "milled" out and polish the rest, it's not perfect but much better than it was.
  13. fastcar1953
    fastcar1953
    Switching external alt to single wire alt.
  14. TA DAD
    TA DAD
    from NC
    The journey continues. It has been several decades since I have built a Dana so the going is slow. I am using a case spreader so that makes things a little easier and right now the carrier is empty so that helps a lot also. IMG_1371.JPG IMG_1370.JPG IMG_1372.JPG
  15. vtwhead
    vtwhead
    went to the local yard and was surprised to find a 78 CJ that had the T150 shifter I need for my top loader. Took me about 40 minutes to get it removed from the jeep. The best part is that they only wanted $20 bucks for it. I smiled all the way home:)
    chryslerfan55, rod1, lumpy 63 and 7 others like this.
  16. fastcar1953
    fastcar1953
    Finally got the tilt wheel installed in wifes nova.
    atch likes this.
  17. kustomfordman
    kustomfordman
  18. swade41
    swade41
    from Buffalo,NY
    Finished the scoop today, no fingerprints left and could probably crack a safe with how tender they are lol
    How it was and where it is
    20230414_162154.jpg Screenshot_20240505_181354_Gallery.jpg Screenshot_20240505_181424_Gallery.jpg 20240508_173943.jpg 20240508_173827.jpg 20240508_173835.jpg
    raven, sbarrett, pila38 and 18 others like this.
  19. choptop40
    choptop40
    Nice modification on the scoop....never would have thought about a hole saw to mill aluminum....
    enloe, 427 sleeper and swade41 like this.
  20. Dick Stevens
    Dick Stevens
    I think I would try using a Rotabroach instead of a hole saw, probably give a better finish to work with and they aren't that expensive.
    chryslerfan55 and enloe like this.
  21. swade41
    swade41
    from Buffalo,NY
    I think it does a pretty fair job, especially in this old *** Craftsman drill press, I kinda enjoy figuring out how to make whatever I have on hand work, I'm not a professional here.
  22. Tim kerns
    Tim kerns
    from Ohio
  23. Tim kerns
    Tim kerns
    from Ohio
    chryslerfan55, Oneball, enloe and 9 others like this.
  24. Dick Stevens
    Dick Stevens
    It was just a suggestion to make it easier and work better by giving a smoother finish that woudn't require so much sanding time.
  25. HOTRODNORSKIE
    HOTRODNORSKIE
    Sorry I didn't get back to you sooner I haven't looked at this thread for awhile the camis a solid roller lift at .357,duration at .243 lobe center at 112 so it's not to big but a had a clearance of .065 Tony needed .100 on EX.
  26. HOTRODNORSKIE
    HOTRODNORSKIE
    Painted my headers and ladder bars white this winter so today was nice for a change and I decided to fire the fairlane up and burn in the paint not much smoke held up well but gave it a 20220820_135531.jpg 20240511_131140.jpg antique look kind of like it the paint I used was barbecue paint. Two pics the old gold and the new white
  27. choptop40
    choptop40
    Packed up the original 1950 Desoto dash gauges and dash trim , other miscellaneous parts to ship off to a club memeber in Colorado...Hes 76 and still restoring cars....Pics of Desoto dash with new insert and gauges coming soon....
  28. Making drivers floor panels in the Belly Tank project. JW
    pila38, chryslerfan55 and rod1 like this.
  29. dirt t
    dirt t
    JW Looking great. If I can pickup parts and ship to you PM me.
    Terry
    26 T Ford RPU likes this.
