Projects New project 1950 Buick
Discussion in 'Traditional Customs' started by CGkidd, May 5, 2024.
  1. CGkidd
    CGkidd
    Well I picked up another project. Like I really needed it. 1950 Buick Special Sedanette. Car is in great shape. Original straight 8 with three on the tree. I’m in the process of rebuilding the engine last shop really screwed it up. I already picked up a factory dual carb/dual exhaust manifold. Took .050 off the block and head to get the compression up a little. I installed 2.5 drop coils on the front with a disc brake conversion. I have a set of 3” drop coils on the way for the rear. I picked up a rearend from a 55 super so I’m going to use the center section with 3.58 gears and the larger brakes on the rear. Plans are to just make it a clean mild custom.
    rockable, bobss396, SS327 and 27 others like this.
  2. Rand Man
    Rand Man
  3. CG, something strange about your car! Front fender script does indeed say Special.. But the one piece windshield says Super.
    Neat car, but then I MAY be biased.
    Ben
    1oldtimer, guthriesmith, BJR and 3 others like this.
  4. Also like and also MAY be biased
    firstinsteele likes this.
  5. Acres
    Acres
    from Sweden
    Nice
    Keep us posted
  6. Black Panther
    Black Panther
    from SoCal
    Great car...those have beautiful lines.
  7. tubman
    tubman
    I had one of these as a DD in the late sixties, In addition to being a great looking car, it was very tractable in an everyday role. I would have another in a minute if it were available,
  8. e1956v
    e1956v
    Alliance Vendor
    She's a beaut.
  9. 283john
    283john
  10. hrm2k
    hrm2k
    SCORE !!!!!
  11. choptop40
    choptop40
    Very Nice....
  12. SS327
    SS327
    I’d cruise the hell out of it!
  13. BJR
    BJR
    If you look at the inside picture, the center trim clip has a cutout for the division trim for the 2 piece windshield. So the windshield has been changed. Good eye.
    Welcome to the Buick club. Beautiful car.
    guthriesmith likes this.
  14. guthriesmith
    guthriesmith
    Very cool! I’m also somewhat biased toward 50 Buick’s after having one recently. I’ll be following along as you make progress. :cool:
  15. A couple more pictures would be great. Drivers side engine and the Fisher body data plate.
    Ben
    Acres likes this.
  16. In_The_Pink
    In_The_Pink
    Um, that's gorgeous.
  17. Looks like a 46S with a 56S windshield. I had a Super with a broken Dynaflo. The compound carb unit off a '41?. does it have hood release cables or the key slot inside the ports on the hood?.
    The straight 8 is torquey.......don't forget to post the build process.
  18. Fat47
    Fat47
    Good eye BJR. Yes, it looks like someone replaced the windshield with one piec gl***. Much like you could do with early 50's chevys with an Olds windshield.
    BJR likes this.
  19. CGkidd
    CGkidd
    Sorry for the delay on progress info. It does have the exterior slots to latch and unlatch the hood. Good to know model 56S for one piece window because I broke mine installing the wiper ***embly in the new rubber. But got it fired up for first time last Friday and moved under her own power.
  20. CGkidd
    CGkidd
  21. CGkidd
    CGkidd
  22. Acres
    Acres
    from Sweden
    Dual carbs NICE!!
    Is that an older intake from the 40s?
    Dig the whole car, 2door lowered jetback, any more plans?
    CGkidd and guthriesmith like this.
  23. glendale
    glendale
    looks like you are off to a great start!
    CGkidd likes this.
  24. CGkidd
    CGkidd
    Not really anything major just plan on it being a cruiser. My 46 Chevy is more of a custom.
    Acres likes this.
  25. F-ONE
    F-ONE
    from Alabama
    Nice!
    CGkidd likes this.
  26. patsurf
    patsurf
    CGkidd likes this.
  27. 50 Merc Man
    50 Merc Man
    Great start !!!! That’s for sure!!!
    CGkidd likes this.
  28. CGkidd
    CGkidd
    Anyone know what year and model this from? I’m looking for the matching water temperature and amp gauge cluster. Any help is appreciated.
  29. '51-'52 Buick and I believe '53 Buick Skylark
  30. Fat47
    Fat47
    loldtimer may be correct. The guage design looks the same as the one in my 49 Sedanette with the exception of the all black back ground. The 49 has the 3/4" circular ring in silver. It is 3 3/8" wide. So, probably the size and design is the same with a minimal change in background color. So, if you can't find the single guage you are looking for you could switch out both it and the temp/amp one from a buick of this era.
