Hot Rods Small cap distributor options in 2024
Discussion in 'The Hokey Ass Message Board' started by Little AH, May 5, 2024.
  1. Little AH
    Little AH
    I need a small cap SBC distributor due to firewall clearance. Currently using a Mallory.. are there any other options without cutting firewall?
    I wish I could use a stock points delco but do not have room. Help.
  2. blue 49
    blue 49
    from Iowa
    Fake magneto?
    Gary
  3. RodStRace
    RodStRace
    90 degree drive?
    tractorguy likes this.
  4. Weren't the first gen (1955-6) distributors slightly smaller in diameter?
    Big Al and anthony myrick like this.
  5. Mr48chev
    I see small cap Chevy V8 distributors advertised but haven't paid a hell of a lot of attention to them. Screenshot (129).png
  6. Kerrynzl
    Kerrynzl
    MSD Crank trigger!
  7. Here’s the difference between early and later sbc points caps
  8. Cali4niaCruiser
    Cali4niaCruiser
    I used an MSD pro billet, but replaced the factory (red) male cap with a black female style cap.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What’s wrong with the Mallory?
    2OLD2FAST and Moriarity like this.
  10. 19Eddy30
    19Eddy30
    from VA
    Witch Mallory ???
    Msd 85701 for sbc/bbc is smallest round cap made , smaller round then Vertex Mag , unless you make your own , distributor top with cap witch requires cutting off above clamp welding & fabrication thinking outside the box,!!!!!
    There is a small 2 wire china knock off for $50ish The module that is in the blue circle can be cut off and relocated wherever you want by extending the wires, MSD $400
    Just cap on right is cap for 85701 MSD
    Algoma56 likes this.
  11. 19Eddy30
    19Eddy30
    from VA
    Or this rought
    off the front
    Tim likes this.
  12. Little AH
    Little AH
    Great responses thank you all. It’s a unilite with a Petronix module. I’m thinking maybe the 55/56 Chevy distributor would work.
    Also wanting something with vacuum advance
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Beware that 55 & 56 needs to be dropped in correctly or you’ll loose oil down the right oil galley for the lifters. Also the oil hole in the oil groove of distributor needs to plugged when used in later engines with full oil pressure to the lifter oiling galley’s. (See “Oil In” below right) IMG_1917.jpeg
  14. 51504bat
    51504bat
    I have a Bubba converted Chevy distributor in my 8ba flathead. Don't like the looks of the window cap on the Chevy. A friend gave me a small cap Accell dual point that I thought about having converted. Then I looked into buying 2 new sets of points, a new condenser, and a cap and rotor plus the cost to modify. Now the look of the window cap no longer bothers me.
    Tim and 2OLD2FAST like this.
  15. banjorear
    banjorear
    What about one of the crab capped Mallorys? I think they were used in SBC powered boats.
  16. alchemy
    alchemy
    I think the smallest I’ve seen is an old Mallory two piece cap style.
  17. Little AH
    Little AH
    Maybe I’ll just try my best to live with the Mallory.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ve run a dual point Mallory with only one points set. Just saying.
  19. RodStRace
    RodStRace
    @Little AH PM sent a while back. That's the thing that looks like a letter at the top right of the page.
