tech week 6-71 Blower rebuild
Discussion in 'The Hokey Ass Message Board' started by Rob Kozak, Jun 2, 2009.
  1. squirrel
    About 50k since it was last overhauled by BDS
    rod1 likes this.
  2. rawcjw19
    rawcjw19
    Wow. Does it have many scratches?
  3. squirrel
    yeah, but from what I can tell they're mostly old scratches. Also looks like some dents in the rotors were welded up long ago.
  4. landseaandair
    landseaandair
    from phoenix
    One thing that may not have been mentioned and to watch out for especially on dis***embled core blowers is never remove the rotors from the rear bearing plate by pressing or tapping in the center. Both rear shafts are hollow and have pressed in plugs that will fall in. Make or find a tool that registers on the outer edge of the shaft, a socket will work.
    shawn ramsay and Kan Kustom like this.
  5. B A D dad
    B A D dad
    from NSW
    Thank you rodgeroadster for the pdf's, much appreciated ;)
  6. trammel
    trammel
    Well written a lot of good knowledge.
  7. rawcjw19
    rawcjw19
    While polishing my blower, Just about finished I noticed there is a crack on the side through one of the dowel holes (appears they were a little rough putting dowels in). It doesn't appear to be through the blower can it be fixed? or will it hurt anything? I'm ***uming if they are cracked all the way through they will leak vacuum?
  8. twoponchos
    twoponchos
    I am so glad that I found this thread. I just picked up a 6-71 today, fresh off a 1976 GMC 7500.
  9. hipster
    hipster
    Great read, thanks for dragging it back into the light!
  10. frank spittle
    frank spittle
    BTT. Might be of interest to you future (or present) GMC supercharger owners. My avatar was 4.71 small block Chevy powered and later 6.71 big block Chevy powered back in the '70s and I am building a '55 Chevy 4d moonshine car powered by a 6.71 small block Chevy. The juices are running again.
  11. Kan Kustom
    Kan Kustom
    Go man go ! I am working on a couple 671 blown early hemi's. Some of us have been dormant for awhile but are coming back . There are many of us die hard's out here.
  12. Speed Gems
    Speed Gems
    If you check Ebay or have a copy of Best Hot Rods. Fawcett books #465 has a great article starting on page 36 maybe someone can scan.
  13. DDDenny
    Please tell us more!
  14. frank spittle
    frank spittle
    I am getting close to cranking it. I decided to replace everything that might give trouble including gas tank and lines, the complete brake system including a new dual master cylinder, the complete front suspension and steering parts including new front hubs with tapered bearings replacing the ball bearings. A couple grand in parts alone. This car is the ugliest I have ever had and typical of cars sitting outside for 65 years....faded paint with some areas with no paint and some rust thru. It would have been embarr***ing when I was younger. But I don't care at this stage of my life, it is what I want. A real sleeper moonshine runner with the original three on the tree. All the supercharged cars I have owned in the past were built to display the blower. I was hoping I could close the hood on this one but will have a small blower scoop sticking out of the hood dang it. I hope to have it on the road within two months and will post some pictures.
  15. DDDenny
    Frank this is such a coincidence!
    My wife and I were out for a drive yesterday in a neighborhood next town over from us.
    We rounded a bend and there in a driveway sat the nicest unrestored 55 Chevy 210, black, bone stock, black wheels and dog dish hubcaps. Cripes, I've wanted one for years!
    I didn't realize it until we had p***ed it that it was a four door, now there was a time when I would not have looked twice at one but I got to tell you, this thing was a beauty and all the way home I was quietly scheming on how to pull off buying it and it wasn't even for sale, not to mention not having the coin either, but boy did my mind take off on me.
    My mental picture was more subdued (visually) than the plan you have for your car but no less exciting, picture a "real deal" 302 Z motor and four speed (what else), quiet exhaust, etc. what better car to ****er in the street trolls.
    Then I came home and looked at my three unfinished projects and came back to reality.:(
    Tow Truck Tom and mad mikey like this.
  16. frank spittle
    frank spittle
    That's a car you won't be able to get off your mind for awhile.
  17. Are you sure you can't make it fit? I know I've seen tri 5 Chevies with blowers under the hood. maybe custom motor mounts?
  18. DDDenny
    I've seen a few but I think there's more to it besides modded motor mounts.
    I did see a ?57 Nomad? in a magazine many years ago that had carb adapters that I think is called a "water buffalo" afair where a low profile casting allowed the carbs to mount adjacent to the side of the blower.
    Found this one
    enloe and mad mikey like this.
  19. toxic waste
    toxic waste
    from Iowa
    Someone still makes this casting
  20. frank spittle
    frank spittle
    The first GMC supercharged street car I remember was Charles John's '55 Chevy wagon, who worked at Ace Speed Shop in Charlotte N.C. This was mid 1960s. He ran a 4.71 SB Chevy and put the whole deal together himself from a "how to" magazine article. I believe the hood closed with no scoop. It must have had a side draft carb setup or I was so impressed I forgot the scoop. There were very few supercharged cars at the local drag strips back then and NONE on the street. Charles changed that. It was the first time I was able to hear a GMC supercharger whine at idle. I just loved everything about that car, especially when I was fortunate enough to cruise around the hangouts with him and share the unbelievable attention.
    mad mechanic and mad mikey like this.
  21. frank spittle
    frank spittle
    My first personal experience with a GMC supercharger came in 1971 when a local racer placed his BB/G 1941 Willys coupe up for sale. It had a 4.71 supercharged 368 cubic inch SB Chevy in it. I had finished redoing my avatar, a '33 Es*** Terraplane convertible, about 2 years earlier and the 354 Cadillac engine wasn't enough anymore. So I asked him if he didn't get any buyers would he sell the engine and Muncie 4-speed. He said he would consider it. So I got back with him a couple weeks later and he had no takers so we struck a deal. The Cadillac was a race prepared engine including 2 fours but WOW what a difference it made. I ran that engine for 2 years and built a 6.71 supercharged 427 Chevy, which I ran 5 more years. I ran the **** out of both engines with no major problems, even on some 500 mile road trips. Looking back at some very fond memories I realize how fortunate I am to be posting this.
  22. shawn ramsay
    shawn ramsay
    from Canada
    This is a great read and the reason I joined. Hello to all I appreciate the group and the info found within.I have been doing conversions as well for some years now and really enjoy the car group. I always like helping others and strive to find more information all the time. Anyone on here ever messed with anodizing rotors and cases? Im setting up to do so shortly. Cheers guys
    kidcampbell71 likes this.
  23. Paul
    Paul
    Editor
    bumping this thread back to the top
  24. fastcar1953
    fastcar1953
    Thanks we need more tech threads.
    mad mikey and Desoto291Hemi like this.
  25. Sandcrab
    Sandcrab
    When I built my miniature engine I used the smallblock blue print dimensions from an out of print book. At the last Turlock swapmeet I picked up end plates for a 6-71. I have scaled drawings for making the patterns but I'm curious as to the whether there are any blueprint drawings for the GMC blowers available.
    rod1 likes this.
  26. brigrat
    brigrat
    from Wa.St.
    You want "cropped" pics.......................................
  27. 19Eddy30
    19Eddy30
    from VA
    @Sandcrab
    I have see , but have no ideal where
    Maybe try archives of pat.
    6:71 small bore & big bore for rotors .
  28. saltflats
    saltflats
    from Missouri
    Check Diamond P Production. Or I think that is what it's called.
  29. Sandcrab
    Sandcrab
    I thought I had Pat Ganhal's (sp) street supercharging book but can't put my hands on it. I'll see what I can find. Worst case is laying the end plates on the mill and using the DRO to generate some points. Then divide by three.
    Discussing this with a Detroit mechanic he mentioned the bearings are fed with engine oil. Is that also the case with typical street application. I had thought to just fill the gearcase for the model with a light gear oil.
    rod1 likes this.
