Technical ***May 2024 Banger Meet Thread - Remember your Mom this month***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 2, 2024.
  1. 29Sleeper
    29Sleeper
    from SoCal
    I wonder if any more are available. I need one now for my Rutherford headed B I'm restoring. Now the engine has a wider not deeper pan on it.
    Outback likes this.
  2. 25mercury
    25mercury
    29Sleeper, I just looked and he does show the pan on his site, but looks like he reworked the patterns so you can now run an oil pump in the pan. Check out Dan4banger the pan is on the second page.
    Outback likes this.
  3. fourd
    fourd
    from Colorado
    IMG_3840.jpeg I bought this 2 piece oil pan from an “old guy” in CA in 1987. He said it was a Rutherford pan. I was 18 then, now I’m the old guy.
    Dan from Ohio saw it on my car and I believe he said he made it. In a A ch***is the tie rod interferes.
    Outback and 4BangerDean like this.
  4. 4BangerDean
    4BangerDean
    More cool stuff… I graduated high school in 85. Model As and bangers were not on my radar at the time. I’d like to think I’m not an old guy yet.
    BeaverMatt and Outback like this.
  5. fourd
    fourd
    from Colorado
    Of course none of us are the old guys, but when your 18-20 anyone over 40 is old.
    Outback likes this.
  6. jim1932
    jim1932
    Finally getting traction on my "WinterProject"........
    mvee33, GuyW and Outback like this.
  7. jim1932
    jim1932
    Are shims between the flywheel and a B block required? or only in certain situations?
    GuyW likes this.
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    No guts… no glory! Now for some quality time with the band saw:confused:
    F7D49151-4DC2-4741-BC3E-FA69D69BD445.jpeg BE7AAEE2-472A-4E1B-89E7-427BB910AF9E.jpeg
    Outback and johnneilson like this.
  9. Kevin Pharis
    Kevin Pharis
    from Califunny
    It can’t get any worse…:eek:
    burl, Outback, GuyW and 5 others like this.
  10. 4BangerDean
    4BangerDean
    Making some progress!
    Outback, GuyW and mvee33 like this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Not the prettiest welds I’ve ever made… but they’re burned all the way thru and should clean up nicely!
    40 Olds, 282doorUK, GuyW and 7 others like this.
  12. BLACKNRED
    BLACKNRED
    Engine in and ready for setting the hood, inner fenders and grille.
  13. joemac05
    joemac05
    I am enjoying the ride Kevin, thanks. :)
    Outback likes this.
  14. Kevin Pharis
    Kevin Pharis
    from Califunny
    Mama said she wanted to be left alone to read her book all day… Cool! I’ll be in the shop!:D
    Finished up the welding this morning and got the easy side of the manifold blended out. It may be a candidate for polishing after all! The drawback to full penetration welds is all the stalac***es in the runners, nothing a carbide burr and a couple hours won’t solve. Just have to resurface the flanges now…
  15. Dan from Oakland
    Dan from Oakland
    Just keep grinding away at it!!
  16. 29Sleeper
    29Sleeper
    from SoCal
    When I was 16 (1966) there was a saying "Never trust anyone over 30".
    Outback and Jiminy like this.
  17. Outback
    Outback
    from NE Vic, Oz
    That looks like the a nice casting, what is the purpose for all this work, better flow? Better carb position? Aesthetics?
    Looking good @Kevin Pharis
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    It’s a looooong story… so short version. Custom cast manifold to crowd 2 Winfield’s close together (sideways) on a plenum style manifold. Works great… as long as I’m driving straight! I had underestimated their sensitivity to fuel sloshing. Having another cast without drawing the wife’s attention was not likely to happen.
    Soon I will be able to mount the duals back on the car to see how it runs (while turning). I know the pair of carbs are too big given the sideways mounted experience, but will be making sleeves to size the Winfield’s down from B’s to A’s. Will reduce from 300 cfm to 200 cfm (probably still a bit too big)
    Outback likes this.
  19. Kevin Pharis
    Kevin Pharis
    from Califunny
    How it was set up last summer:cool:
    How it’s set up now to solve the oversize and drive ability issues:oops:
    29 Speedster, 40 Olds, burl and 5 others like this.
  20. Outback
    Outback
    from NE Vic, Oz
    johnneilson likes this.
  21. So…..
    On wind hold today at ElMirage
    Thought a pic posted would be appropriate
    Flathead roadster and OHV Belly tank lakester
    Phil Damon, GuyW, Stan Back and 3 others like this.
  22. So today both cars ran
    130.9 for the roadster on a 133 record
    Tank ran 167.3 for a licensing run
    Owen, my son made both p***es
    J
  23. douglasb
    douglasb
    Wow Phil that's a crazy looking little fan on that hopped up 4 banger
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    @hotrodfil
    I believe that little fan may be intended for use in the southern hemisphere… where toilets and fans run in the opposite direction;)
    Outback, Jiminy and hotrodfil like this.
  25. Garpo
    Garpo
    BMC east/west models are all sideways with radiator on inner fender, hence the pusher fan. Might work OK if you reverse down a really looong driveway
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Maybe the fan is a good enough excuse to build a reverse rotation engine…?
    hotrodfil likes this.
  27. That’s on the list of things to do today…
  28. Crazydaddyo
    Crazydaddyo
    Congratulations John.
    Outback, 4BangerDean and Stan Back like this.
  29. Kevin Pharis
    Kevin Pharis
    from Califunny
    @hotrodfil
    Lookin closer at yur engine, what plugs are you runnin…? I can only make out part of the number but looks like LZK??? Google says maybe 12mm x 26.5mm thread? I put 10mm plugs in my T and looks like we have a similar problem… loose boots! I have yet to find any wire sets for these smaller porcelain plugs as they are all intended for use with modern direct mount coils. Have been considering making a mold and casting my own boots from silicone…:eek:
    Outback likes this.
