Technical Autolite 4100 Running Rich
Discussion in 'The Hokey Ass Message Board' started by Oneball, May 7, 2024.
  1. Pontmerc
    Pontmerc
    from Finland
  2. Oneball
    Oneball
    It’s got a thick gasket and it’s the correct Autolite power valve. Plus if it was bottoming out I think it would cause an issue at part throttle not at idle.
  3. Pontmerc
    Pontmerc
    from Finland
    If its leaking thru the threats it leak petrol in the intake all the time.
  4. Oneball
    Oneball
    Should be able to see that.
  5. Oneball
    Oneball
    Had a play whilst waiting for a vac gauge.
    It like 16 BTDC best at idle. At this point I can’t get the rpm below about 900 as the screw is all the way out, need to see what is limiting the throttle blades.
    Covering the primary and the engine gets slower and dies so don’t think there’s a vac leak.
    Covering the secondary doesn’t do anything.
  6. Oneball
    Oneball
    Doesn’t appear to be excess fuel entering the venturis.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Do those carbs have a secondary throttle plate adjustment screw? Maybe second’s are open and into transfer slot???
    Oneball likes this.
  8. Oneball
    Oneball
    Yes they do and they’re closed, I double checked by putting my hand over the secondaries and it had no effect.
  9. Pontmerc
    Pontmerc
    from Finland
    17151831590857099557341216045248.jpg For the high idle, have you check fast idle cam adjust screw?
    Oneball likes this.
  10. Pontmerc
    Pontmerc
    from Finland
    And if powervalve leaking thru you will not see it in venturis because power valve vacuun channel is in bottom between bores.
    And i just look one of my spare 4100 and it has total of 6 air bleed holes in booster ***embly. 17151830221572415832285562520564.jpg
  11. Oneball
    Oneball
    Yes. It was stuck on that.
  12. Oneball
    Oneball
    That’s the vacuum signal orifice, fuel will go through the venturis, it was also dry in there so I know the pv isn’t blown.
  13. Oneball
    Oneball
    I’ve got a vac gauge now and it’s reading 17” at 680rpm
  14. Pontmerc
    Pontmerc
    from Finland
    I guarantee, if power valve leaking thru, it wil **** raw gasoline via that vacuun signal orifice.
    But you dont have to believe me and you are sure power valve is not leaking.
  15. Oneball
    Oneball
    I see what you mean now, it’s definitely not leaking through there as it was completely dry when I took it apart.
  16. Oneball
    Oneball
    I am wondering if the fuel is bad. It’s a bit difficult to tell as it’s US fuel and it doesn’t smell the same.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    How does a blown power valve affect idle “only” (cruise yes) when all it does is feed more fuel via a byp*** to below the main jet? This is where the fuel is drawn from for the idle circuit which in and of it’s self is a secondary metering via idle adjustment screws.
  18. jimmy six
    jimmy six
    I thought they were called economizer valves on Autolites?
  19. Oneball
    Oneball
    I think what he’s suggesting is that if there is a hole in the diaphragm of the power valve it will allow fuel past into the vac*** signal hole and then into the engine.
    But it’s definitely not the power valve.
    Johnny Gee likes this.
  20. Pontmerc
    Pontmerc
    from Finland
    Sometimes its better take break with difficult malfunction and just bolt temporarily known good holley 600 in place of autolite.
    Just wake this beaty up at my barn where it was sitting two years. 17151927029919056879623045990614.jpg 17151927236286883082523023454429.jpg
    Oneball likes this.
  21. miker98038
    miker98038
    I know that 6 month old fuel in my roadster (600 Holley) won’t idle, and with no choke doesn’t want to start below 70 degree F. Siphon it out, new fuel, problem goes away. The old stuff looks fine, smells fine, runs fine in my daily. I've always blamed it on the ethanol and/or the more volatile stuff evaporating off. Doesn’t really act like your problem.
    Oneball likes this.
  22. Oneball
    Oneball
    I’ll put the carb off the race car on it on Monday.
  23. Oneball
    Oneball
    Wouldn’t immediately strike me as bad fuel either but if I set it up to run on bad fuel rather than the fuel went bad maybe it is.
  24. AccurateMike
    AccurateMike
    When you rebuilt the 4100, did you remove the plates from the shaft ? Primaries and secondaries are the same size, but different. The primary plates have a taper that the secondary plates don't. There is also a right side up for both. Get them in wrong and they won't close correctly.
    427 sleeper and Oneball like this.
  25. Oneball
    Oneball
    One other odd thing now I’ve got a known good gauge it always stays at 16-17”hg, unless you rev it over 2000rpm when it’ll climb to 20 and then start to drop off.
    Change the timing, change the mixture, change the idle speed still 16-17” up to the point it just dies
  26. Oneball
    Oneball
    I didn’t remove them but that doesn’t mean someone else didn’t.
  27. jaracer
    jaracer
    Vacuum that starts to drop at high rpm (no load), points to a plugged exhaust system.
  28. cshades
    cshades
    from wi
    I just rebuilt one of these and i had issues with it. the first issue i had was after bolting it to the manifold i cranked it and it was leaking all over the manifold. after a bunch of ****ing it around i finally figured out that the power valve cover was warped and letting fuel leak. after figuring that out i started wondering why it was leaking fuel because there should not be any fuel that far down past the valve. i would suggest that you remove the power valve cover and the top of the carb on the bench, pour fuel in the bowl and check to see if fuel leaks through the valve or the gasket on the valve. the reason it runs rich is the fuel drains through the slots from no mans land between the bowl and the throttle bores. i hope this helps i wasted a lot of time figuring out the problem.
    osut362 and Oneball like this.
  29. distributorguy
    distributorguy
    from MN
    Ok, let's remember that a lot of carb problems are electrical and a weak or improperly timed spark can cause a rich mixture...
    Next, 10 BTDC is the place for timing a car in the 1970's running leaded fuel. Try this as an experiment: set your timing at 16 BTDC (with the vacuum disconnected) and see if the problem resolves. Modern fuel has additives for high pressure fuel systems, and this fuel takes longer to burn at low rpm/dynamic compression levels. This has been increasing over the last 30 years, as it has been since the 50's when fuel liked TDC at idle. My guess is that tuning the carb will feel a lot more responsive once you advance the timing.
  30. deathrowdave
    deathrowdave
    from NKy
    My bet is power valve issue
