Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Six Ball
    Six Ball
    from Nevada
    My friend has one with a glove on it. I don't know what it is for.
    BJR, impala4speed, fauj and 1 other person like this.
  2. choptop40
    choptop40
    Filed under “Now why didnt I think of this” E4515ADE-C1EE-46EF-9004-D82AE1CDF1EC.jpeg
  3. Moedog07
    Moedog07
    No lie, I just had a spark or red hot BB go into my ear c**** while welding exhaust on my NON-HAMB friendly truck. I was laying on my right side with my left ear pointing up. It left a red burn streak in my left ear. I'm freaked out that one day a wax covered welding BB will be washed out of my ear.
    fauj, Six Ball, GuyW and 2 others like this.
  4. 5brown1
    5brown1
  5. j hansen
    j hansen
    Crazy Steve, Cooon, Driver50x and 4 others like this.
  6. Gasser Mike
    Gasser Mike
    Thanks great idea!
    fauj, hammer-time and ModelAMitch like this.
  7. phat rat
    phat rat
    I'm sure I posted a picture of this arm before but I can't find it. I made an extra arm for my cherry picker in order to be able to easily lift bodies off my trailer. This picture shows just how high it can lift and the arm isn't touching the cab. Overall length is 81 inches and the upright is 15 inches. In order to be sure the tube of the picker itself wouldn't split I wrapped some 2" X 1/4" steel strap around the end. The 4 X 4 cross piece has sliding eye bolts in order to accommodate different widths and I can adjust the length of the chain also. With the extra length I can also set a body on the ground or a dolly without the legs of the picker interfering. I also added some angle iron to the bottom rear of the picker in order to add weight to counter balance if needed P1060658.JPG
  8. choptop40
    choptop40
    Counter weights required I see...good tip...I mean it doesn't tip good tip...lol
    brEad, Tow Truck Tom, enloe and 3 others like this.
  9. KevKo
    KevKo
    from Motown
    Neat. I might suggest making the upright piece on an angle to give a little more space to whatever is being lifted.
    Tow Truck Tom, Dak Rat and Six Ball like this.
  10. phat rat
    phat rat
    This replaced one I made with a Z in it. It's back more than far enough. Realize that it's at max height and still has room. If it were angled the angle piece would be touching the cab roof unless the arm was even longer. The factory arm is 36" overall, this one is 81"
    Tow Truck Tom and Six Ball like this.
  11. Bumpstick
    Bumpstick
    Why bother attaching a brush to a Sawzall? Just get a wire wheel for your angle grinder. Don't overthink this stuff. power-wire-brush-angle-grinder-1_22920161848168630653.jpg
    Rawrench, loudbang and Six Ball like this.
  12. atch
    atch
    Speaking of angle grinders; here's a "little tip and trick for garage hobbyists":
    Have multiple angle grinders. I have eleven with various disks/brushes/wheels/etc. That way I almost never have to change wheels; just grab the one with the wheel you want to use. Most of them hang on a wall rack over my welding table.
  13. Boneyard51
    Boneyard51
    I used to do that all the time with pipe wrenches on my firetrucks! Those 4 inch pipe threads , under water, could really get stuck. I used my little 500 lbs air hoist, had a little more “ distance “!
    Bones
    Tow Truck Tom and brEad like this.
  14. Six Ball
    Six Ball
    from Nevada
    It sort of reminds of when Dad would tie a string around a loose tooth and the door knob. Then he would slam the door. I had the fastest 10 yard sprint in town till I lost all my baby teeth.
    chevy57dude likes this.
  15. [ View attachment 6064163 [/QUOTE]
    An extension for these lifts is very handy, and a standard size of square tube fits down the middle of the jib. Just drill holes for the hook and locking bolt. Picked up an A coupe body using my straight extension, but went in through the window and secured the lifting chains to the floor. A suitable human counterweight is required as well!
  16. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Notice that he used a 4x4 thru the doors to lift. If you use a strap it will cinch tight as it raises and bend the door tops.
    b-body-bob likes this.
  17. onetrickpony
    onetrickpony
    from Texas
    Here is a related tip. Don't put a wire wheel on the $15 Harbor Freight grinder. It will burn out in just a few minutes. They do work fine for grinding and cutting if you are only working a few minutes at a time.
    The $25 HF grinders hold up much better to wire wheel use. They are often on sale (or you may get a 20-30% off coupon) . I have 4, using a flap disc, cut-off disc, grinding disc, and a wire wheel.
  18. atch
    atch
    Right. Some of my grinders are HF but none are the bottom of the line. My oldest one is a Makita that's probably 25-30 years old but still runs like a new one.
    onetrickpony likes this.
  19. Six Ball
    Six Ball
    from Nevada
    You get what you pay for. At least you used to.
  20. I like this! One big advantage is these won't throw wires that end up in your leg....
  21. j hansen
    j hansen
    Or in your face!
  22. atch
    atch
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Looking pretty buff there, Atch!
    Six Ball likes this.
  24. sidewayzz69
    sidewayzz69
  25. atch
    atch
    Maybe someone can photoshop my head onto that young fella's body. I didn't even look that good when I was his age.
  26. atch
    atch
    Nice way to support the headers during paint. Most of us would have hung them off of a tree limb with coat hangers. You did good my friend.
  27. 31 Coupe
    31 Coupe
    Just be careful to NOT have your lifting point very far ahead of the hoists front wheels otherwise it could topple over ..... understanding that the body weight is relevant too.
  28. sidewayzz69
    sidewayzz69
    Makes it easy to paint.roll them around. Lol
  29. b-body-bob
    b-body-bob
    Beautiful paint job, then scratch them all to **** installing them in the ch***is.
    vtx1800 and caseywheels like this.
  30. sidewayzz69
    sidewayzz69
    No...fenderwell headers...super easy to install.
