Hot Rods Top Banana Style Slingshot Dragster- Marty Strode-Chris Kopp.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 7, 2024.
  1. Marty Strode
    Marty Strode
    I pulled it from the jig today and rolled it outside. Going to install the cage tomorrow, with luck. IMG_0471.jpg IMG_0473.jpg IMG_0474.jpg IMG_0475.jpg IMG_0476.jpg IMG_0477.jpg IMG_0479.jpg
  2. Fordors
    Fordors
    Marty, do you have the unique king pin retainers/steering stops for your axle or was it drilled 9/16’s for the typical wedge type retainers? The tube axle kingpins had a radiused notch rather than the angular one.
  3. Larry Anderson
    Larry Anderson
  4. James Fanning
    James Fanning
    from Oregon
    Hey, Marty looks great can’t wait to see it tomorrow!
  5. RodStRace
    RodStRace
    You are going to have to wipe off all the drool and gray beard hairs after the show! :)
    Looks great!
  6. Marty Strode
    Marty Strode
    Larry, I am going to contact the guy on here, that makes them in stainless and steel, and order a set.
    chryslerfan55, porkshop and Fordors like this.
  7. Marty Strode
    Marty Strode
    I think we have it handled, Jimmy is hauling the '29, and I am the Dragster. See you there !
  8. Marty Strode
    Marty Strode
    The Quiet One speaks !!! Se you tomorrow Jim, it will be fun.
    chryslerfan55, chriskopp and porkshop like this.
  9. wrenchbender
    wrenchbender
    Marty the car looks amazing you are a talented guy the work is top notch
  10. Marty Strode
    Marty Strode
    Chris came today and we got the basic roll cage bent, fit and tacked. There will be 2 more bars and the light tube helmet surround . Hope to see some of you tomorrow ! And thanks @wrenchbender !
    IMG_0486.jpg IMG_0487.jpg IMG_0488.jpg IMG_0489.jpg IMG_0490.jpg IMG_0491.jpg IMG_0493.jpg IMG_0494.jpg IMG_0495.jpg
    OFT, ratrodrodder, Dean Lowe and 12 others like this.
  11. DDDenny
    I'll be there in spirit Marty!
    I attended the Portland Transmission event for a number of years, looked forward to it because it was the first major event of the season and there was always something new to see, hands down, best one in the NW.
  12. Marty Strode
    Marty Strode
    P-Trans was a great event, lots of interest in the car, and the best was seeing a friend from Longview, Wa. Rod Brown.
    He had a great story about a couple of his buddies in '59 that called him on a Friday night, inviting him on an impromptu trip to Lodi, Ca., he only had time to borrow some money from his Dad, and they drove straight through, It was a week after the Smokers Meet at Bakersfield, when Garlits made his first West Coast appearance. ' In 1959 the first Smokers' March Meet was advertised as an "East-versus-West" showdown, with California drag racers taking on infamous Floridian Don Garlits, who had been credited with record speeds that the California crowd found dubious. That year, Garlits lost early. Art Chrisman triumphed and took Top Eliminator laurels. The loss caused Don to drive to Isky's shop and install a 6-71 with his 8 carbs, set up for Nitro. Rod was able to capture around 16 pictures at the event and these are two he showed me yesterday, of the Top Banana ! It turns out, the two buddies went on to be well known Top fuel racers in the Northwest, Ron Gorans, and Bob McCutcheon. Ron tuned and drove his own cars, while Bob owned and hired drivers, such as Kenney Goodell. I love hearing the history ! IMG_0584.jpg
  13. wrenchbender
    wrenchbender
    Marty I seen some pics from the show that Cedric Meeks posted on Instagram his anglia with a Wayne 12 port sounded good but your dragster looked amazing sitting there
    porkshop likes this.
  14. Marty Strode
    Marty Strode
    A couple of things happened. First of all @SamIyam has been looking over my shoulder, and noticed the snout that pooched out on the front wheels of the original car, and quickly located a set near me. I have acquired them, and after I polish the outer faces, and install 1 inner race, I will get the front tires swapped. Also, I have been thinking about a breather/vent system for the car and remembered there was a nice tank and hoses in a bunch of stuff that another member @Alan Davis gave me a couple years back. It is nice to have friends ! Thank you both. Oh yeah, the dropped '60 axle will be here tomorrow. IMG_0529.jpg IMG_0530.jpg IMG_0532.jpg IMG_0531.jpg
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Are you sure? Looks cool!
    Wishbones too!
    OFT, Dean Lowe, Rolleiflex and 5 others like this.
  16. Marty Strode
    Marty Strode
    I got the axle bolted in, and now I need to bend the steering arms down, so it will turn and the tie rod will p*** under the wishbones. Also, I might be in trouble with the front perch height. That's what I have a cutting torch for IMG_0534.jpg IMG_0535.jpg IMG_0536.jpg !
    OFT, bymanr, Dean Lowe and 15 others like this.
  17. Magfiend
    Magfiend
    Sam, that may have been mine...
  18. Marty Strode
    Marty Strode
    I think I have resolved the front ch***is height problem, by adding more leaves, ( that I knew it would need anyway) and with a little re-work on the removable perch, it should be fine. I also got the 2 extra bars added to the roll cage today. Steering box will get mounted tomorrow. IMG_0539.jpg IMG_0537.jpg IMG_0540.jpg IMG_0541.jpg
  19. Larry Anderson
    Larry Anderson
    What time does the show start. You know my schedule is incredibly demanding…
  20. Marty Strode
    Marty Strode
    It depends on when I get done using a weedeater !
  21. Marty Strode
    Marty Strode
    Mounting the steering box and the DC3 Control Yoke (steering wheel) was a little machine work, but worth it. I started by machining a sleeve to fit the wheel with a 3/4" bore to fit the shaft, then cutting the slots. I will machine the keys next. IMG_0543.jpg IMG_0544.jpg IMG_0545.jpg IMG_0546.jpg IMG_0542.jpg IMG_0547.jpg IMG_0548.jpg IMG_0549.jpg IMG_0550.jpg IMG_0551.jpg
  22. Larry Anderson
    Larry Anderson
    What’s that gauge cluster bezel looking thing for. Obviously I don’t get out much
  23. Marty Strode
    Marty Strode
    It just happens to be on my table, I milled the surface to remove ball mill grooves for a buddy.
    brEad likes this.
  24. Mitchell Rish
    Mitchell Rish
    from Houston MS
  25. Marty Strode
    Marty Strode
    Got the keys machined, and turned out a ****on for the center. There will be a threaded bung welded in the end of the steering shaft, to hold it together, and a cross bolt ahead of the wheel. The quick disconnect will be forward of the wheel around 6", to give the driver more room getting in and out, and allowing the DC3 wheel. IMG_0552.jpg IMG_0553.jpg IMG_0554.jpg IMG_0556.jpg
  26. Marty Strode
    Marty Strode
    I still fit !
    OFT, prez, brEad and 21 others like this.
  27. Larry Anderson
    Larry Anderson
    That’s quite the look of grit and determination in your eyes.
    brEad, porkshop, chriskopp and 3 others like this.
  28. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    brEad, porkshop and Roothawg like this.
  29. Marty Strode
    Marty Strode
    Today I worked on the steering mount/leg hoop. After bending up a piece of 1" 4130 tube, and cutting a couple stubs for the ends, I machined a couple of aluminum sleeves. Now that it is tacked in, tomorrow I will make the angle plate to attach the box, then on to the a-frame sleeved riser to support the shaft. The steering disconnect is on it's way, along with a Girling style Willwood master cyl for the brakes. IMG_0563.jpg IMG_0564.jpg IMG_0565.jpg IMG_0566.jpg IMG_0567.jpg
    brEad, Graham08, VI Lonewolf and 12 others like this.
  30. dwollam
    dwollam
    Works of art!
    Dave
    50John and porkshop like this.
