Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    Having trouble with valve stems for the slot mags, had to order some tractor ones, is 5/8” a normal car valve size over there?
  2. Oneball
    Oneball
    Phew! Glad that’s over.
    Beer time!
  3. bobss396
    bobss396
    With my pillar garnish, I took an old bolt cut off the head and turned a point on one end. Threaded it into the mounting hole with the pointed end sticking out. Laid the garnish in place, tapped it with a mallet and I had the hole location.
    Oneball and Truckdoctor Andy like this.
  4. Oneball
    Oneball
    I put some masking tape on the pillar then screwed the trim on and marked the hole. Took the tape off and put on the front of the trim, locating it with the screws. Then drilled the hole.
    bobss396 likes this.
  5. bobss396
    bobss396
    Hey if it works, it works. My pillar bolt had a large shoulder on it, so I drilled a pilot hole and had to use my mill to open the hole to the final size, it was around 5/8" or 16mm-ish.
    Oneball and Algoma56 like this.
  6. Oneball
    Oneball
    Bumper irons and inside of the ch***is rails painted
    Painted the tank
    And made a list of things to do before I can have a proper drive. IMG_7566.jpeg
  7. Oneball
    Oneball
    Paint polishes up better than I expected
  8. Oneball
    Oneball
    Bumpers back on, needs the stainless lower trim putting back on and a good clean, then it’s just a case of sorting the carb
  9. Oneball
    Oneball
    PS that shocking bit of fencing is next door’s, they paid for that!!!
    deadbeat and Cooon like this.
  10. Oneball
    Oneball
    Took a while to get the correct size valves for the wheels, eventually got some from a tractor place, well it is a Ford!
  11. J. A. Miller
    J. A. Miller
    from Central NY
    She cleaned up nice. Looks great!
    Oneball likes this.
  12. Pontmerc
    Pontmerc
    from Finland
    Also 63 buicks has those large valves.
    If you need new ones, you need to ask valves for mercedes-benz 508d.
    Oneball likes this.
  13. Oneball
    Oneball
    Power steering pump went pop!
  14. ClayMart
    ClayMart
    Was it a hose failure? Pressure side or the return hose?
    Have a fun weekend at the races. Good luck. Knock 'em stiff!
    Oneball likes this.
  15. Oneball
    Oneball
    No, it’s coming from the front seal, either it’s popped out or the bearing has failed completely
    Thanks. There’s a guy racing with us with a Thunderbolt this weekend. Looks fab!!
  16. Oneball
    Oneball
  17. ClayMart
    ClayMart
    Oneball likes this.
  18. bobss396
    bobss396
    Oneball likes this.
  19. GeeRam
    GeeRam
    Oneball likes this.
  20. T. Turtle
    T. Turtle
    What series is this? Looks like Brands Hatch... Last time I was there for race support was 1993 with Hal Danby's Corvette, Gerry Marshall drove on that day. Both are sadly no longer with us:(
    Mercury is looking good, I doubt there's a better example on our side of the Atlantic!
    Oneball likes this.
  21. Oneball
    Oneball
    Full race motor but not by HM, it’s one of the nicest prepared race cars I’ve ever seen
  22. Oneball
    Oneball
    Bernie’s V8s. We’re were at Donington, we’re at Brands in June support the UK round of Euro Nascar, we will be running open headers so bring you ear plugs if you’re coming!
    Truckdoctor Andy likes this.
  23. I would love to come, but my wife and I have different opinions on our mode of transport once we land in your country. I won’t go unless we can make a proper tour of England on a proper motorbike such as a Triumph. She wants to be boring and rent an auto. Man, I miss my Triumph……..
    I’d also love to see the TT at The Isle of Man, I think she would be bored to tears, maybe I could drop her off at a pub?
    deadbeat, guthriesmith and Oneball like this.
  24. Oneball
    Oneball
    You can watch the TT from a pub right next to the circuit. Problem solved ;)
  25. Oneball
    Oneball
    Pump the off and the front bush is really sloppy, it was rebuilt not long ago but before my ownership. There’s a lot of debris in there too, some quite large chunks. IMG_7711.jpeg
    Isn’t there supposed to be a big round filter in here?
    guthriesmith and bobss396 like this.
  26. Oneball
    Oneball
    Looks like there’s a bunch of stuff missing from inside the reservoir IMG_7713.jpeg
    Algoma56 and guthriesmith like this.
  27. Most people don’t know about power steering filters, but pretty standard on Lorries. (Trucks).
    Algoma56, guthriesmith and Oneball like this.
  28. Oneball
    Oneball
    I’ve ordered a new pump as it seemed simpler than trying to sort the front bush and I’ve got a bunch of stuff to do to the Vette before June after being punted off by a Mustang at the weekend. I’ve also ordered an in line filter for the return line. I’ll clean the leaky pump and use it to purge the system properly before putting the new pump on. I’m pretty sure this one has failed because no one cleaned the swarf after the original failed
  29. T. Turtle
    T. Turtle
    If I could I would but it seems my employer decided to make my last two years before pension into a nightmare so that if I can get away any free time will have to be spent on my Comet - if I want to get it past our MOT... Maybe next year. Open headers on a cl***ic series in the UK?! How is this possible if the Earl of March isn't the organizer?
  30. Oneball
    Oneball
    Dropped the trans sump and changed the filter too, didn’t look like it’d ever been off, gave the sump a lock of paint before I put it back on and refilled with fresh Ford fluid. Couldn’t really work out the two o-rings the filter came with as it didn’t look like the larger tube had one on but put it on anyway.
    Also put the new pump on, along with an inline filter and flushed the system. I thought I’d put the pressure line into the ch***is bracket it’s meant to fit in as someone hadn’t when they’d changed the pump before. There was a reason why 2 1/2 hours of swearing. It’s in 3 pieces and held together and on to the ch***is with one bolt, your can only get one had in there two. It’s at least done now and I can move on to cleaning stainless trim :confused:
    I’ve bought a 600 Holley off eBay, I’ve got all the bits to rebuild one and I’m used to them so hopefully that’ll fix the running issue and I’ll be able to actually go for a drive soon!!
