so lets see some fabbed chassis'
Discussion in 'The Hokey Ass Message Board' started by Cshabang, Oct 9, 2006.
  1. Cshabang
    Cshabang
    we got some killer fabricators on here....lets see some of your fabbed ch***is and frame work(no certain car, etc)...Just wanna see some cool ideas...if theres another post...add the link...thanks.
  2. SUHRsc
    SUHRsc
    dont know if this is what your looking for or not....but heres some ideas for doing a model-T era frame and getting it lower
    Zach
  3. telecaster_6
    telecaster_6
    Here's mine.....Will be getting a newly painted 4" chopped 30' sedan body wrapped around it in a few weeks.
      115.5 KB
  4. Here are a few
  5. flynj1
    flynj1
    from C.B. IOWA
    Nothing fancy here but built this one for a shortened up 37 2dr
  6. flynj1
    flynj1
    from C.B. IOWA
    How about some Dwarfs. Built a bunch of these lil things
  7. T Hudson
    T Hudson
    Now that is cool!
  8. gahi
    gahi
    from Moab, UT
    Seems like alot of leverage to me. But I guess it might not matter.
  9. highboy_04
    highboy_04
    from Kansas
    im with you gahi. that seems like alot of stress for 2 bolts and some plate.
  10. telecaster_6
    telecaster_6
    thats gotta be pretty weak, especially considering he ground down the weld on that outside corner joint. You end up with an effective thickness there of only around 1/4"......
    Not something i'd like to ride in.....
  11. You should see some of his other stuff, the guy's an ace! That's probably just how it was done way back when.
  12. FiddyFour
    FiddyFour
    zach knows his **** fellers. . . trust me.
    here's a couple shots of the back of my willys. . . i have an affection for Watts links, what kin i say. they aint the easiest centering device, but the look cant be beat IMHO
  13. Nice.
  14. Blair
    Blair
    from xx
    Why did you mount the bars to the frame like that?
  15. Here's a couple straight from the TECH archive:
    http://www.jalopyjournal.com/forum/showthread.php?t=87556
    Not fabbbed completely from scratch, but very cool-
    http://www.jalopyjournal.com/forum/showthread.php?t=103232
    The photos on this one are real big and have to be scrolled back and forth, otherwise pretty good-
    http://www.jalopyjournal.com/forum/showthread.php?t=11882&&showall=1
    Some good theory-
    http://www.jalopyjournal.com/forum/showthread.php?t=206&&showall=1
    May want to search through all of Dodgerodder's threads-
    http://www.jalopyjournal.com/forum/showthread.php?t=84507
    And my all-time favorite-Littleman!
    http://www.jalopyjournal.com/forum/showthread.php?t=104568
  16. t-town-track-t
    t-town-track-t
    from Tulsa
    Here is the chasis I am currently working on, I think some of you have seen pics of it in the past. Bob Hindman (yeah that bob Hindman) built it, so I can not take any of the credit.
  17. SUHRsc
    SUHRsc
    hey guys, thanks for the compliments
    unfortunately i didnt build the T sprint car
    i just took the pictures of it at hershey last year
    the metod which he used is actually an old trick though...i think if i were building it i woulda put a little more of a gusset at the top where it kicks out to the "U" bolts...i think thats all bent though and not welded and its about 3/8" thick it appears....
    i think possibly it was heated and bent in a vice or something with a sharp edge which caused the sharper inside corner?
    plus you figure a T motor set back isnt putting alot of weight on it
    my concern for failure would be from the constant twisting from the sides while running a dirt track...causing a stress crack on that inside "kink"
    Zach
  18. Django
    Django
    from Chicago
    Here's a T-bucket we did this spring. Disregard the steam rollers...
  19. FiddyFour
    FiddyFour
    if you're talkin about the 4 bar brackets to the underside of the crossmember. . . in-experiance with a 4-bar, and plain dumb *** move. . . THAT bracket is why the thing was NOT at the HAMB drags my friend :mad:
    live and learn is the name of the game :cool:
  20. FiddyFour
    FiddyFour
    got any close ups of that "H" member and trans mount?
  21. TxRat
    TxRat
    pretty ghetto but heres mine...
    the one good thing about this frame is Keith (leadsledmerc) let me use his super secret plans from his C-Dan build for my frame...
  22. FiddyFour
    FiddyFour
    ghetto my ***. . . that truck makes me twitchy an stuff
  23. I am thinkin you guys got a little to add here...Only things I have done so far do not fit here. But I am working on that....
  24. b0ne dry
    b0ne dry
    from n0r*cal
    heres my low buck ch***is....
    tac'd with flux core..
    about to be tig'd together....
    spent 4x as much on the fricken welder than i have on materials!
  25. Django
    Django
    from Chicago
    Here you go Fiddy...
  26. Looks like it'll be pretty stout.
  27. FiddyFour
    FiddyFour
    gracias. . . :cool:
    that thing is stout as hell man
  28. Beemer
    Beemer
    My underslung frame...
    From the side...
  29. How about some front axle close-ups...
