The Upper Krust - a Jaguar custom
Discussion in 'Off Topic Hot Rods & Customs' started by Hellfish, May 7, 2024.
  1. Hellfish
    Hellfish
    I thought about adding IRS, but it would require narrowing it, and it's a lot of work just to fit it. Yes, the S-Type did have IRS, but Jaguar extended the trunk to make it fit, if that gives you any idea how much work is required (compare the Mk2 to S-Type trunk). There's a gret YouTube channel from the UK called RetroPower If you want to see some low-stress builds. They added IRS to a MK2 and it took a lot of work and engineering and they were professionals, with all the tools and skills.
  2. Oh I love Jags. This might help get the juices going.
  3. Hellfish
    Hellfish
    That's Fluevog's MkX. This is Justin Hill's 1953 xk120 custom with a v12 upload_2024-5-20_12-22-15.png
  4. bchctybob
    bchctybob
    I mildly customized my Mk II. I looked at it from the driver’s side one day and thought it just had too many things breaking up the sensuous curves, 4 doors, a gas door and the skirts, each it’s own gaps.
    So I used wheel opening flares from the front fenders of a donor Mk II to create new wheel openings just large enough to allow for changing the tires and then welded and molded the skirts on.
    It cleaned up the side nicely. Then I did a driveway black lacquer paint job.
    I sure like like what you’re doing with yours.
  5. Phillips
    Phillips
    Thanks for the tip on RetroPower! I have a 'thing' about Cortinas and MK1 ******s, they have some beautiful builds.
    BTW listened to your Albini show, it was more than great. Thank you.
  6. Hellfish
    Hellfish
    Thanks! This past week's show was all goth for World Goth Day. This week will be back to the regular postpunk mix. I'm also starting a show for summer called The Speed & Danger Hour, which will be mostly a hot rod mix of modern rockabilly, garage and surf, with some cl***ic country thrown in (Sundays 8-9 EST). The station has an all vinyl show on Fridays (5-6:30pm) where community members get to spin their records on the air. I'm doing one soon and it will be all psych and acid rock. I like a lot of different kinds of music. :D
  7. Hellfish
    Hellfish
    Nicely done! I hate the stock skirts (spats) and Coombs skirts on these things. The S-type rear wheel arches looked better to me
    bchctybob likes this.
  8. Bandit Billy
    Bandit Billy
    I drove the 41 PU to the hardware store the other day to grab some krylon semi flat (how do run out of that stuff?). A gentleman loading his purchases in a hardtop MG next to me asked me who does my painting to which I responded I do. He asked me if I would paint some cars for him, small English stuff and I told him I wasn't really interested in becoming a "hired gun". But short story long I mentioned this build to him @Hellfish and he thought it may the coolest idea ever. He asked where he could see the thread and told him the HAMB and he said BS! I laughed and told him to check the OT forum for your thread.
    That car is going to look evil. You are on to something cool!
  9. Hellfish
    Hellfish
    Thanks! Let's see if he pops in. I also have bits and pieces on a Jag forum, but most of those guys get pretty uptight about any modifications. Dropping in a later 4.2 is barely tolerable, but they get squeamish when the inner fender needs to be cut for it to fit.
    Until now I couldn't post anything here because, apparently, no one in the US or elsewhere ever customized foreign cars in the 50s and 60s... except for all of the examples of people who did... so they can't possibly be traditional... and I can't post about it on Jag forums because of the obvious sacrilege. Oh well! :D
  10. Flatrod17
    Flatrod17
    As a XKE owner I have an interest in all things Jag. I have several 4.2 engines. I say keep posting customs or not!
    Hellfish likes this.
  11. 73RR
    73RR
    Were these pics taken at the Flash Back Cruise?
  12. It is Fluevog's car. Picture was taken in Vancouver, BC at VanDusen Gardens British Car Show. All on gr*** with a band playing Beatles tunes. Can't beat the venue.
  13. Hellfish
    Hellfish
    I'm nowhere near doing body work but I needed to know what I was getting into, so I stripped the paint and s****ed off all of the filler. It was almost 1/2" thick in one spot, but the rest was all about 1/4" or thinner. It looks like the car may actually be as rust-free as it appears. Clearly some collision damage and sculptural filler work, but rust-free. A car from the 60s. A BRITISH car from the 60s. The metal work isn't too bad and the fender is pretty straight. I need to make sure the frame is straight but all looks good. upload_2024-7-4_13-59-49.png upload_2024-7-4_14-0-49.png upload_2024-7-4_14-1-24.png upload_2024-7-4_14-2-8.png
    With a quick rattle can pre-primer job, you can see it a little more clearly. It can use a little more work, but it's already been metal worked a lot, so I may make things worse by doing too much. This explains why the filler goes back into the rocker. All the door gaps are good. Doors close perfectly.
    upload_2024-7-4_14-3-32.png upload_2024-7-4_14-3-53.png upload_2024-7-4_14-4-40.png upload_2024-7-4_14-5-16.png
  14. kustomkat1950
    kustomkat1950
    from Coastal GA
    Good on you! I have been known to keep a couple TR250/TR4's in my back pocket. Fun cars to drive!!
  15. Hellfish
    Hellfish
    Fired it up (very) briefly just to confirm it runs. Now I need to borrow a run stand to fully break it in.
    How long can you run a fresh engine before going through the 20 minute break in sequence? I thought you weren't supposed to let them idle much, but getting the carbs and timing dialed in requires it to be running.
  16. Hellfish
    Hellfish
    I borrowed a run stand from a local shop so I could do the initial break-in. He said to run it for 20 minutes and DO NOT shut it off unless there's a catastrophe, like it's spewing oil everywhere. Definitions may vary. I got it going and started discovering problems... carbs were backfiring a bit, the alternator was squealing like a banshee under load, but most importantly, it was running hot... really hot. I finally shut it off when the head p***ed 450. I should have stopped earlier, but like I said, definitions may vary. That was a 15 minute run. I doubt 5 minutes will make much of a difference.
    Once it cooled down I checked: compression (all good), oil (no water in it), water (no oil in it), spark plugs (showed signs of running lean, which I knew, so I cleaned them), timing (advanced 2*, so I corrected that), and carbs. Re torqued the head per spec. So far, it looks like a may be lucky and didn't damage the head. Dumb*** me filled up the radiator until it wouldn't take any more and ***umed it was good... but forgot to account for the amount the WP would **** out of the radiator and circulate, so it was low on water, hence the hotness.
    The carbs all looked good, but once I started messing with them, I realized that they were imbalanced, mostly due to a vacuum leak on the center carb. Got all that sorted. So now she's running pretty well. Probably needs some more tinkering with timing and mixture, but not too bad for my first time doing this.
    https://youtube.com/shorts/fNzsNaFyjVg?si=3tnzBDFAYyzhQ1tm
    Not sure how to embed this!
  17. RodStRace
    RodStRace
    Ouch, that's HOT! Check HAMB for debate on drilling a hole in the thermostat to relieve the air.
    In the toolbar at the top of where you reply, it has a smile (Similes) a landscape (Image), then filmstrips
    (Media). When I paste a video, it usually recognizes it without having to use the tool, but you can edit and click on the Media then paste in the address.
    chryslerfan55 and rod1 like this.
  18. You probably dodged a bullet on the overheating as Jags like to drop valve seats when run too hot.
  19. Hellfish
    Hellfish
    Yeah, I'm a little worried about that one. How do I check to see if a valve seat is at risk of dropping? Leak down test? Is there a visual inspection? Google isn't being very helpful. Compression was good on all cylinders.
  20. AFAIK, if a seat is going to drop it'll do it while its hot. So that's why I said you dodged the bullet... it didn't get hot enough. They're actually pretty tough motors.
    chryslerfan55, bchctybob and Hellfish like this.
  21. Hellfish
    Hellfish
    I stripped the other side. It was definitely not better than the left. Really thick Bondo, but nicely sculpted! I no longer think the car was in an accident. It looks more like someone attempted some rust repair and panel replacement, but did a really bad job at welding and heat control. That may explain why the front fender supports were rusted to nothing, but no rust in the rest of the car. To simplify the process, I ordered some pre-made panels, but will end up making a few, too. The right rocker needs a lot of work, so easier to replace, then start on the 2-door conversion.
  22. RodStRace
    RodStRace
    Man, it's tough, but I've always heard, First, Restore, Then Modify.
    porkshop likes this.
  23. Hellfish
    Hellfish
    I got the replacement outer rocker and fender patches in, so I started stripping the interior. When's the last time you saw an old car without rust in the floors (and only a small handful of mouse poop)?? There may be a small patch under the driver's feet, but otherwise it looks good.
  24. Squablow
    Squablow
    I like Jaguars, and I like 2 door conversions, so I'll definitely be following along with this one. I have a very wadded up E-type that I hope to do something non-stock with someday.
    chryslerfan55 and porkshop like this.
  25. Hellfish
    Hellfish
    I'm probably going to need to follow some of your conversion threads when I start messing with the doors. We had a conversation about this years ago. Now I'm finally doing it.
    If I've learned nothing else, Jaguar people HATE anything non-stock, and hot rodders HATE anything non-American, so I get to piss off everyone. :)
  26. Squablow
    Squablow
    I've learned the very same thing. I had joined a Facebook group for non-stock Jaguars that was supposed to cater ONLY to modified cars, but when I brought up the idea of doing anything other than a full restoration on the E-type I got all kinds of pushback about what a terrible idea that is. It's not even one of the more desirable ones. Jag guys get all kinds of sensitive when you start talking about cutting up cars from the glory years.
    I wonder if E-type 2+2 quarter window frames would fit your project? They sure do look like the same shape as your concept photoshop (which is beautiful, by the way).
    chryslerfan55, bchctybob and porkshop like this.
  27. Hellfish
    Hellfish
    Well, E-type's are kinda special, but can be made cooler in the right hands. Have you seem Marcy's E-type build?
    Speaking of E-type mergers, here's another JamesD Photoshop that would make a great build, but far beyond my skill set. I did find the rear hatch once, but it wasn't cheap. The 2+2 quarters might fit, but it's hard to find used (or affordable) E-type anything.
  28. Uncle Ronn
    Uncle Ronn
    from Modesto CA
  29. Flatrod17
    Flatrod17
    I have a 67 2+2, and a friend of mine is parting out a 67 2+2, but I am way up here in Alaska, long way to chase parts!
  30. Squablow
    Squablow
    I don't know that I have, where would I find it? I'd like to see that.
