Technical SBC EDELBROCK 1721 FUEL PUMP
Discussion in 'Traditional Customs' started by 54FISH, May 15, 2024.
  1. 54FISH
    54FISH
    Hello Hambers ,just wanted You ALL to know if you didn't already .the Edelbrock 1721 fuel pump which has been REDESIGNED and NOW looks like many other pumps ( Holley ,Quickfuel etc....) has the same issues as the Holley ,Quickfuel etc.. as that the inlet / out ports are close to each other. The pump can be dis***embled & the " whole" bottom can be turned( clocked) in a 360 degree . BUT YOU CANNOT separate the VERY BOTTOM ( pump looks like there is 3 sections) to put inlet & outlet 180 degrees out from one another ( LIKE THE OLD EDELBROCK 1721 ( which is redesigned) .YOU CAN GET THE "OLD" STYLE EDELBROCK PUMP BY PURCHASING A " JEGS # 15969 " FUEL PUMP .THIS PUMP IS DESIGNED EXACTLY LIKE THE OLD EDELBROCK 1721 WITH INLET & OUTLET PORTS 180 DEGREES FROM EACH OTHER IF YOU NEED THIS FOR FITTMENT . JUST A HEADS UP . THANKS & HOPE IT HELPS . IT MAY HAVE A BACK ORDER SO IF YOU NEED GUESSING GET THE ORDER IN .
  2. hotrodA
    hotrodA
    Thanks for the tip. They must be on B/O, ship date is June 26.!!
  3. 54FISH
    54FISH
    Yes ,I talked to them and that's what they told me .I was able to find a NEW one being sold on facebook marketplace . Drove 45min & got it , bailed me out . So try other avenues . I didn't see any reseal kits for the Jegs 15969 either . WISH they sold em ,I'd reseal my old edelbrock 1721 & keep a spare seal set for future .Good luck , hopefully Jegs get more in .
    Deuces likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sure looks like a “Polished” Carter M6900.
    427 sleeper likes this.
  5. 54FISH
    54FISH
    NOT EVEN CLOSE! the Carter M6900 looks JUST LIKE the New Edelbrock 1721 , the 30-350QFT Quickfuel fuel pumps . The " OLD original" Edelbrock 1721 looks like the JEGS 15969 WHICH HAVE INLET & OUTLET 180 degrees from each other .the Carter M6900 , NEW STYLE Edelbrock 1721 & Quickfuel 30-350qft ALL have inlet & outlet close to each other & CANNOT be separated due to valve to gasket location inside . There are many other brand names that look like these also which is why I made the statement on another post that it looks like fuel pumps are being built like compressors .Compressors look to ALL be made by the same manufacturer ( all look identical except color & name) BUT Snap on , Husky , Campbell ,Ingersoll paint them their color with their Name on it . Look up sbc fuel pump images . They mostly look the same IMO .First 2 are old 1721 edelbrock & new Jegs 15969 . The last 2 are New 1721 edelbrock & 30-350qft quickfuel ,which holley & Carter both look like . The Bottom bowls of NEW sbc fuel pumps can't be 180 out . Unless you buy jegs15969 .IMO
