Technical 1950 Chevy and a box of parts
Discussion in 'Traditional Customs' started by BoxOfParts, Feb 4, 2024.
  1. BoxOfParts
    BoxOfParts
    I had to grinded down the nose of the starter to make it fit the 216 bellhousing ,but its on now
    Going to get the manifolds on this week and it should be ready to go in.
    Okie Pete likes this.
  2. BoxOfParts
    BoxOfParts
    Had to order the intake rings and intake gaskets ,but its all on IMG_2358.jpg
    Going to install the fuel pump,dist and the breather tube this Sunday.
    It should be ready to go in.
    Any advice where to attach the chain for the engine hoist?
    tb33anda3rd and Okie Pete like this.
  3. BoxOfParts
    BoxOfParts
    Oh one more thing , i will be heading out to the lonestar roundup in Austin hope to see some of you out there. Wont be there with my car but next year is my goal
  4. to lift those engines I made a plate that bolts to the two holes where the coil would mount. the bracket extends up and has a hole for a chain to hook/bolt to. the other end of the chain either wraps around the manifold or if the manifold is removed bolts to an intake bolt. this will lift the engine nice and even.
  5. BoxOfParts
    BoxOfParts
    I got axle straps and put one where the starter mounts and the other i will wrap around the manifold, Thank you for that idea
    Algoma56, Okie Pete and squirrel like this.
  6. squirrel
    watch the balance...lifting an engine below it's center of gravity can result in it flipping over....
    I've attached a chain to the rear intake bolt and the opposite side thermostat housing bolt on the head, iirc
    or remove the rocker assembly and use two of those bolt holes
    Algoma56 likes this.
  7. BoxOfParts
    BoxOfParts
    More advice needed, I tried installing the engine but cant get it to mate with the tranny,
    My question is should i remove the tranny and install it with the engine?
  8. Trans in neutral so input can rotate freely? It looks like you are hung up.on the splines going into clutch disc. If my memory is right, 10 splines, so you need to get lined up.
  9. Yeah you can install transmission with the engine without pulling the torque tube. Once you unbolt the tail housing it becomes pretty self explanatory. Just make sure to support torque tube with a jack or jack stand before disconnecting
  10. A couple long bolts with the heads cut off and screwed into the bell housing go a long way to getting the trans lined up.
    Jacksmith likes this.
  11. BoxOfParts
    BoxOfParts
    Thanks guys, i hope this weekend i will give it another shot will use all the recomedations and see which one works .
  12. BoxOfParts
    BoxOfParts
    I failed. I tried and still could not get the tranny and engine to bolt up.
    I was afraid to either strip the treads on the bellhousing or break the ears off the tranny
  13. Cosmo49
    Cosmo49
    Doesn't that transmission need to be rotated 90* counter clock wise? Something isn't right there.
    Sorry for the misdiagnosis, I haven't seen a torque tube transmission in a while.
  14. BoxOfParts
    BoxOfParts
    I took the tranny out, was not that hard,and i did put a jack stand under the torque tube.
    Since its out I am going to clean it paint it and change the fluid
    Hope to get them bolted up together this weekend.
    Okie Pete and tb33anda3rd like this.
  15. BoxOfParts
    BoxOfParts
    Maybe its the way i took the picture?
    The shift linkage and speedo cable are on the driver side.
    Cosmo49 likes this.
  16. Pilot studs are used to guide the trans into place; if the clutch disc isn't lined up or some other problem is present; using all thread to force the trans isn't going to do anything but cause more grief.
    Does the throw out bearing fit the trans collar and slide on smoothly?
    Was the disc aligned with a pilot tool or trans shaft while the pressure plate was tightened down?
    Is the disc correct; bore size and number of splines?
    I hate seeing people having this kind of grief on something that should go easy and wish I could be around to help.
    Cosmo49 likes this.
  17. BoxOfParts
    BoxOfParts
    You are right, I think something is not lining up.
    Now that the tranny is out I will get a chance to see whats going on.
    I dont have the orginal disk to compare it to, I really got this car in boxes and tubbs.
    I did match the pitot/ clutch alignment tool that was in the kit to the input shaft on tranny.
    I got bummed , after a good night rest, life is still good!
    I hope to work on again tonight after work.
  18. whenever I get a new clutch kit. I always slide the throw out bearing, clutch disc and pilot bushing on the tranny before putting them in place. a SMALL dab of grease on the splines pilot bushing hole and the collar the throw out bearing rides on.
  19. BoxOfParts
    BoxOfParts
    I think it must have been the angle ?
    Took me no more than 2 minutes to bolt them together. I used another jack to help me balance it out.
    Now that I know its works I took them apart again. I cleaned up the trans and painted it.
    Tommorow I will give it a second coat and clean out all the mounting threads with a die.
    Okie Pete, Cosmo49, Jrs50 and 2 others like this.
  20. Make your pilot studs out of long bolts with the heads cut off; the smooth shank and lack of threads will make the trans slide easier.
    Cosmo49 likes this.
  21. BoxOfParts
    BoxOfParts
    Thanks, for the tip...
  22. BoxOfParts
    BoxOfParts
    I cleaned up the input shaft, it was full of gunk.
    I wonder if that was a problem why it gave me issue?
  23. BoxOfParts
    BoxOfParts
    Its ready for installation
  24. BoxOfParts
    BoxOfParts
    Guys , I will be starting back up my car again. I had life happen kind of hard. My awesome mother inlaw ,which I took care of for almost two years, past in late May. My 27 year old daughter took it kinda of hard and moved back in. She was by herself 550 miles away.
    A house came on the market that we could afford, after 3 years of looking! So we moved from Round Rock to Georgetown. After remodelling the new house and selling the old one,the holidays came. So it was not easy staying out of here so manny cool projects that you guys are building. Now its time to unbox my garage get my list of "things to do " find the boxes of parts and get back to work on my car. Anyway I will be posting pictures again, asking for help and opinons Heres to a better year!!!
  25. BoxOfParts
    BoxOfParts
    One on the things I wanted was sombero hubcaps but could not find a complete set, so the ones I bought a year ago needed the macthing wheels
    Okie Pete, CruznArt and 6inarow like this.
  26. BoxOfParts
    BoxOfParts
    After trying to install the engine front mounts did not align, time to track down a 216 front plate
  27. BoxOfParts
    BoxOfParts
    Did the redrill the front plate trick and it worked! The 235 is in. IMG_4010.jpg
    SS327, Okie Pete, tb33anda3rd and 4 others like this.
  28. saltflats
    saltflats
    from Missouri
    Nice. I always feel safer when I have something plugging all the critical holes in the engine.
    Okie Pete and leon bee like this.
  29. BoxOfParts
    BoxOfParts
    Was going to put the plugs on but notice the engine was not at TDC .After messing with it i think I got it. Was going to put the distbutor on but I dont know if this is a 12 volt or 6 volt
    6inarow and Okie Pete like this.
  30. BoxOfParts
    BoxOfParts
    Oh i was also going to put a new fuel pump on and it came with two gaskets. Thought it was maybe packaged wrong but I see many new pumps on the web comming with two gaskets .
    6inarow likes this.
