Technical How many hours would it take to wire a '32 Ford?
Discussion in 'Traditional Hot Rods' started by 32blownhemi, May 8, 2024.
  1. alchemy
    alchemy
    Did the OP ever come back?
    32blownhemi, Texas57 and 2Blue2 like this.
  2. twenty8
    twenty8
    Nope. No time for the HAMB. Stuck half way through a wiring job. Maybe in June..........
    32blownhemi, Balljoint, clem and 2 others like this.
  3. Ziggster
    Ziggster
    It seems that anything I do always takes 2-5 times longer than what I’ve seen posted by other folks. Makes me wonder if I’m that “special”, or if folks just BS the time they’ve spent. Most of my time is spent “head scratching”, researching, buying parts, picking up parts, looking for parts, looking for tools, putting tools away (to make room to actually do some work), and running back into town to buy stuff I either forgot, or didn’t know I needed until I started head scratching. Actual “work” time is just a fraction of the time spent on above. So, how long it takes depends on what you count as “time spent”. Lol!
  4. Jim Mothershead
    Jim Mothershead
    An absolutely loaded coupe sans interior about 40 hours.
    Since 1957 I have wired a good 35 cars.
    Retired master electrician in 23 jurisdictions.
    I prefer a Ron Francis kit.
    Jim Mothershead, Street Rod Works
    32blownhemi, Texas57, nochop and 2 others like this.
  5. Jim Mothershead
    Jim Mothershead
    ............and if your battery is in the trunk the ground cable should be a 1/0 straight up to the 3/8" bolt on the bell housing closest to the starter. A #10 ground to the frame. Use a grounding block near the steering column with a #10 to the block. All grounds should be the same wire gauge as the positive feed to the item. Headlights should have a dedicated ground to the block. Electric fans should have all wires #14 AWG.
    All good things take time.
    32blownhemi, RodStRace and Ziggster like this.
  6. Jim Mothershead
    Jim Mothershead
    I use 1/2" plywood, one side smooth sanded, yes expensive, on the firewall and floors thru the trunk. It will not warp. That way you always have an attachment point for wiring and what ever.
    Temporarily use grocery store twisties on the wiring harness. When 100% finished, use tie wraps then remove the twisties.
    I will ONLY wire a car sans interior.
    32blownhemi and nochop like this.
  7. Jim Mothershead
    Jim Mothershead
    Back in the day, fifties and sixties, I would always buy a donor car for the drive train and the wiring harness....a crashed five-five Chevy for example. Then Ron Francis went in to business = the best.
    With old faithful started in 1985, I bought a crashed 1985 Iroc, 942 miles, for $500. Used the original harness for 2 years while I figured out all the goodies = two years to wire while driving, har, har. Then went to a Ron Francis kit. In 147,281 miles it has NEVER blown a fuse or any other electrical issue.
  8. RodStRace
    RodStRace
    @Jim Mothershead you bring up something that I thought about but didn't mention and nobody else said either. If this is a 'gl*** '32, the grounds for everything are going to add a bunch more time.
  9. Dennis D
    Dennis D
    Figure some time for making the brackets for the battery cables if mounted in the trunk. Takes time to do those and put grommets in them to protect the cables. Same thing when you p*** a wire bundle through the frame, fire wall. ect.
    32blownhemi and clem like this.
  10. verno30
    verno30
    20-25 Hours for someone knowing what they are doing. This does not include wiring removal.
    32blownhemi likes this.
  11. bobss396
    bobss396
    I went off the deep end with mine. I made a harness board, a formal wire list in Excel. Made up a binder with the instruction book and my notes.
    I had the dash out anyway, made things a breeze. I had the interior out too, and painted the floor pan. I made myself comfy with a Harbor Fright packing blanket on the front floor.
    32blownhemi and Ziggster like this.
  12. Ziggster
    Ziggster
    I hate to admit it, but this simple harness took me a few days to wire up. Not full days, but still…and it’s not permanent, only for start up, but wanted an idea what it will kinda of end up like in reality.
    32blownhemi and bobss396 like this.
  13. uncle buck
    uncle buck
    How long is a piece of string? Why would people buy a panel that has all the wiring already hooked to it? Do you just cut all the unused wires off or coil them up?
  14. Texas57
    Texas57
    Exactly!!. Jim Mothershead mentioned in his first post he preferred Ron Francis. Their harnesses have the connectors attached to the long-length free wires, not attached to the fuse panel. Makes much more sense, and your dealing with one wire at a time, not the full harness. That's a big concern, especially if your dealing with something like my 94 wires engine harness on the OT engine/******.
    My '57 is wired (as Ron Francis advises) as though it was a fibergl*** car. After 7 years, 77k miles, of driving, I've never had a wiring OR GROUND issue.
    No made-in-China wires such as your going to get when you make the talked-about runs to the local parts store.
    75 responses, and none from the OP!
    32blownhemi and uncle buck like this.
  15. Things to think about -- at typical shop rates of say $100 per hour (yes, I know, it will vary - some are a lot more, some less) - you're talking about $5000 for 50 hours of work. That doesn't include any fuse panels, kits, wiring, connectors or components.
    There is nobody going to do this work (correctly) for $500 - $1200 . . . unless they aren't running a business and don't need the money.
  16. k32t
    k32t
    from Hog town
    I had a 1959 ford dash cut down in a 32 gl*** 3 window coupe. using the original gauges It cost me 4000 can. for the work worth every penny. All the gauges work fine even the trouble lights for oil and temp.
  17. SDS
    SDS
    I wired my 32 Ford roadster (with SBC) from scratch this past fall and it took me around 60 hours total. I soldered every connection, no crimps. The guage cluster took quite awhile to neatly ***emble and wire, probably 8-10 hours.
    I was stoopid about it though and used a NOS Centech fuse panel which has NO relays for headlights, tail lights and brake lights. It is ill-engineered and that's probably why they are no longer in business. I had to add an auxiliary fuse panel for the relays and some other fuses.
    Half way through the wiring, I found Coach Controls and the lights went on over my head - it fixes EVERYTHING that was a pain with the setup I have. I almost ripped it all out as started over with a Coach panel.
    https://coachcontrols.com/
    You don't have to buy their wires, but their fuse panel has everything built-in including many relays.
    Check out my build thread to learn from some of my pitfalls.
    https://www.jalopyjournal.com/forum...-cars-but-never-a-32-roadster.1244478/page-17
    32blownhemi and lothiandon1940 like this.
  18. SDS
    SDS
    I respectfully disagree, I purchased some kits from Ron Francis and didn't use half of the circuits or wires. Many of the pig-tails and plugs didn't have much use and actually hindered my completion. I bought a lot of silicon jacketed copper wire (which is very pliable) from Amazon and wired most of it from scratch...proved WAY less expensive.
    Larger shows, like NSRA always have a guy selling plugs, pigtails, switches, LED's, etc.. for low $. I bought several components from the guy at the Burlington VT show.
    My 2 cents~
    32blownhemi and firstinsteele like this.
  19. I would think 40 hours wouldn't be out of the realm of reality.
  20. LOU WELLS
    LOU WELLS
    from IDAHO
    It Goes Along Fairly Fast Once You Start And The Advisors hqdefault.jpg Go Home...
  21. pprather
    pprather
    So, is it done yet? We've been talking for a week.
  22. The37Kid
    The37Kid
    I guess the cost of wiring will be more than the chrome plating.
  23. goldmountain
    goldmountain
    I can do wiring. Chrome is a bit more challenging.
  24. theHIGHLANDER
    theHIGHLANDER
    I wired mine with a Rebel, but I'm a ****. I did **** like this to make it seem legit.
    I modified the new harness to use the OG light switch in the column.
    Lots of other tidbits which seem to fit how I want to see things. I also had a very dear friend help as wiring race cars is his side hustle and he's damn good at it. Using the old lacquered loom stuff blew his mind a little. We have over 40hrs in it and I still have to connect it all and add a few things yet. I don't care if I have another 30 or 40 once it's turnkey. It takes me 7 to 10 working days to wire a Packard with a new authentic harness.
  25. seb fontana
    seb fontana
    from ct
    First thing I thought of. I'd like to rewire my eyeballs [soon], three fingers, four toes and my back.
  26. The37Kid
    The37Kid
    A 1932 Ford isn't that much bigger than a Model A, so the time to wire one would be the same, correct?
    32blownhemi and pprather like this.
  27. bobscogin
    bobscogin
    And I thought I was the only one who lost sleep over that decision. I decide where to cut, and then end up making it a couple of inches longer "just in case".
  28. T McG
    T McG
    from Phoenix
    I have wired a lot of cars over the past 40 some years and I agree with the 40 hour mark. I will also give you my feelings on harnesses since I have used a lot of different ones. This is just my opinion for what that is worth! Painless and American Autowire I feel are the best in quality and customer service but are also expensive. Ron Francis is the worst, they are the most expensive, absolutely horrible customer service, the most time consuming to install and they take up a lot of room since the wires come out of all four sides. I have also had the most voltage drop issues with them. The Speedway 12 circuit mini panel isn't too bad for the price although the printed lettering isn't the best. I have actually had good luck with EZ Wiring but zero customer service and a terrible manual so you really need to have some experience with this one. I'm sure I will get flack about Ron Francis but after multiple bad experiences I have nothing good to say.
  29. oj
    oj
    He didn't mention it but with blown motor & transbrake it is going onto the racy side of things, I'm thinking MSD box, 2step rev limiter, tach & shift light or shift solenoid, battery in the back? well, that means battery disconnect switch, that and the 1st time you bust loose a blown engine on the transbrake I'll wager wireing will be the furthest thing from his mind, he'll be doing some serious ch***is and rollcage work, know what I mean?
    32blownhemi and Just Gary like this.
  30. nochop
    nochop
    from norcal
    And that’s why the back of my dash looks like a birds nest
