Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Six Ball
    Six Ball
    from Nevada
    Damn near drowned at Pacifica! Got caught in the undertow. I wrapped my arms and legs around my board and held on! I bounced long the bottom and popped up about 100 yards off shore. I paddled in, put the board in my '51 woody and headed for Half Moon Bay! :D
    Ragged Edge, rod1, J.Ukrop and 4 others like this.
  2. Tim
    Tim
    from KCMO
    I’m picturing a time lapse video in the garage of the body swap with Your usual cast of characters.
    it involves some pizza, a chain fall hoist, a random dog and some benny hall music
    winduptoy, Six Ball and Outback like this.
  3. RodStRace
    RodStRace
    If there aren't wacky hats involved, it'll be hard to keep track of the players!
    Six Ball, J.Ukrop, Tim and 1 other person like this.
  4. Tim
    Tim
    from KCMO
    Joey, take down a note: make hats with initials.
    winduptoy, Six Ball and J.Ukrop like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So so good. It has such a good old-time feel. I love Colorado too. You know how to pick the spots!
    Thanks!
    There are some great houses on Crespi. What year was that in?
    Thank you, Mitch. You and I both. We'll be in pretty good shape once it's time for the swap. I can't wait!
    Hahha some things never change! That stuff can be pretty scary. My worst one was getting caught in a rip-current in Bali. I don't recommend that either. That said, Version 2.0 will be set up to haul surfboards.
    Hahahhaha you have the vision. Want to come out to help?
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Small update for tonight. Earlier this afternoon, I got my steering shaft from CPP. I came in a huge box, but I did open it up and upon initial inspection it looks nice. IMG_2491.jpg
    The other update involves this low-quality photo. Back when I was ***embling the e-brake, I discovered that the stock e-brake ratchet wouldn't fit the mount. Even when I used my best rat-tail file, I wasn't able to expand the bolt hole in a way I was satisfied with. So, I found a reproduction one from C.W. Moss and it bolted right on. Problem solved. As you read this, the paint is drying. (Don't worry, I'll wipe down the transmission and paint the Grade 8 bolts once the engine goes back in.)
  7. Tim
    Tim
    from KCMO
    Go figure the aftermarket bolts to the aftermarket maybe that’s what I’ve been doing wrong all these years lol
    and if someone tips me a bunch of airline miles I’ll be there straight away for the swap :)
  8. Six Ball
    Six Ball
    from Nevada
    Thanks for the E-brake shot. I'll have to build one of those. I doubt the aftermarket has one to mount a Chevy handle to a Studebaker transmission.
    I have mixed feelings about the body swap, but I have a feeling the banger ch***is will get a new life.
    Outback, Ragged Edge and Tim like this.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahaha right? Maybe there's something to it.
    Dennis Lacy made mine, and it's a super clean setup. I'm happy to take more pictures of it if you'd like to use them for reference. Don't you worry—the parts will live on!
    Outback, Tim, Six Ball and 1 other person like this.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Today was one of those days where I learned a lot. After spending the morning relaxing and catching up on all sorts of things, I was feeling well enough to head down to the garage to work on the first of the brake lines. It took a little bit of jockeying, but eventually I got everything set up. Using steel wire as a guide, I laid out the route. I made sure to run the line in a way that wouldn't get pinched, and also so I could remove the radiator without having to disconnect the brakes.
    One of the hardest parts about building this car in San Francisco is that I don't have space for a workbench. So, I improvised. Great idea, right?
    Not quite. I tried bolting the vise on the frame, and then I eventually C-clamped it to the fence at the end of our street. I just couldn't get the leverage. After spending the bulk of the afternoon bending the first line to perfection, I botched the flare. I then cut it off—and botched it again.
    Sore knee. Failed flares. No progress. Disappointing first day back in the garage. But I wasn't down for long. My roommate Benj handed me a cold root beer and I started brainstorming solutions.
    Long story short, I bought this piece of tubing with a tight 90-degree bend to fit the space (my bender can't accommodate that tight of a bend). As far as I knew, the company only offered it in stainless steel, although I planned to build the rest of the system in NiCopp. Well, after sending them a message, I have a tight-bend 90 piece in NiCopp heading my way. I'm feeling much better. Sometimes you have to mess up to learn the right way to do things.
    This is the best my bender can do. I think we'll be in good shape with the new tubing.
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Before calling it a day, I went down to the mailbox and found an envelope from Rick Bales in St. Louis. Inside was a pair of reproduction King Bee tags and rivets for the lights I got from @nickthebandit. I love little details, and having these add an extra bit of character to the nose of the car.
  12. Tim
    Tim
    from KCMO
    Learning how to make hard lines do what you want is an art/ craft unto itself. I love it now but I sure made a lot of s**** learning.
  13. RodStRace
    RodStRace
    If you can do it, you will want that line to dive under that lower radiator neck. It's another couple inches and 2 90 degree bends, but the radiator will lift straight up and out.
    Just be glad you are building a HAMB worthy rod, not some modern thing with A/C and A/T lines too!
    Outback, Ragged Edge, Jeff34 and 3 others like this.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So true. It's been a few years since I did my fuel lines for this car, and these are a slightly different type of challenge. I'll get them figured out!
    Noted. After some head-scratching, I think I figured out the best route that will clear the radiator. I'll give it a shot when my tubing shows up.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Today I got to take on a task where I knew I could be successful: cutting my dash for the Stewart-Warner "Mate" instrument cluster. It's a project that started with a whole lot of measuring.
    I then created a paper template and moved it into position. Both the combination square and the cow magnets belonged to my grandpa. I remember being fascinated with the magnets as a kid. They really came in handy here. IMG_2535.jpg
    Next, I made myself a smoothie and mapped out my cuts.
    Using the tailgate of my truck as my workbench, I cut through the dash with my angle grinder. Success!
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    To help make things more complete, I pulled a couple of lights and a switch from my collection. Longtime readers will recognize them from my Sunset estate sale haul back on page one of this thread. I plan to touch up the black on the cluster tomorrow.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    A very fun piece of the project, now complete. I look forward to seeing this in the car.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This weekend was the big swap meet in Petaluma, but I stayed home to rest. That being said, my friend Jason Roth dropped off my new steering column with David, so I'm excited to now have that in our possession. 73783798150__3DF150FB-5F2C-4E88-80A2-2D0A9E208146.jpg
    The column was shortened at one point, but Jason was kind enough to bring it back to the correct length. Per my calculations, the bell at the end will work great with the Hudson steering wheel.
    Oh, and I added some fresh paint to the e-brake ratchet too. Notice the new globe lamp at the end of the terrace? That was the work of my roommate Michael. You can get the full story here.
    That's pretty much it for tonight. I'm closing the laptop this weekend feeling very grateful to be back in the garage, even if it's in a limited capacity. I recently looked at my ongoing to-do list for the car, and it's never been shorter. Thank you everyone for sticking with me on this project!
  19. Tim
    Tim
    from KCMO
    Awesome good progress
  20. Jeff34
    Jeff34
    That's funny. I was in the parking area looking at all the cars, and I saw him put the column in David's roadster. I wondered why he did that, but then remembered that you were looking for one!
    Great stuff, Joey! Things are moving quickly.
    winduptoy, Outback, J.Ukrop and 4 others like this.
  21. Beanscoot
    Beanscoot
    A truly rare, and satisfying, occurrence in life!
    J.Ukrop, Six Ball and Sharpone like this.
  22. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Hey Joey, I am super impressed at how well the gauge panel looks, now that its mounted on the super cool painted dash.
    I like the way the black paint on the panel, corresponds to the black oval around the cool painted patterns!
    Bravo dude!
    Thanks from Dennis.
    winduptoy, RodStRace, J.Ukrop and 2 others like this.
  23. Six Ball
    Six Ball
    from Nevada
    The dash looks great. You'll never park next to one like it.
    Cow magnets? That must be what was holding those two bovines together in the pasture I drove by. :confused:
    Outback and J.Ukrop like this.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! Seeing @Austin kays' coupe blast around the yard is getting me fired up to get this thing on the road.
    Thanks Jeff! I'm bummed I missed the swap, but I think my knee thanked me. I'm glad the column is already getting some seat time in an A-V8. Looking forward to making my way back up to Petaluma once I'm a little further along on the healing process.
    Yes! That said, I just added a few more things to the list tonight hahah
    Thanks Dennis! I've always been a fan of cars with custom paint that retain their trim. My favorite example is the Mox Miller '58 Impala. I love how the trim brings the car back to reality, breaking up the candies, pearls, and fades.
    Here's a photo from the article in Rodder's Journal #32. If you haven't already, check out Pat Ganahl's video about the car here.
    Anyways, I approached my dash with that same mindset. There's a lot going on, but adding the black and chrome panel makes it much more manageable. The panel came from David's collection, and I couldn't be more excited that it has a permanent home in my A-V8.
    Thank you! That's very true. It'll make my car easier to find in the grocery store parking lot!
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight's progress came in the form of parts hunting. Before logging off, I pulled the trigger on more NiCopp tubing, brake fittings, and my starter solenoid. Not the most riveting things, but it's good to know they are on their way.
    Three photos to keep things visually interesting.
    Love this Vicky that I found online.
    A snapshot from our 2022 campaign to keep gr***roots journalism alive. Over the weekend, I discovered that this sign (actually a piece of an outdoor bar I built) still exists and is living in a friend's backyard.
    Aren't waterslide decals in lower corners of old car windshields just the neatest thing?
  26. drdave and J.Ukrop like this.
  27. Beanscoot
    Beanscoot
    Like most things, these got ****pier with time.
    They switched to particle board vs. the original plywood, and the earliest ones even had aluminum frames.
    Buy the old, good ones!
    RodStRace, drdave, J.Ukrop and 6 others like this.
  28. pprather
    pprather
    Like all horizontal surfaces, they become covered with stuff, unless folded up after each use.
    I have two, both covered.
  29. Speedy Canuck
    Speedy Canuck
    Proud to say that for 4 years now, mine has sat without collecting clutter. Mind you, I can't get to it because it's folded up on the top shelf of my pallet rack behind a bunch of other junk, but... :D
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone for the workbench idea. Those things look like they could certainly solve some problems.
    During the work day today, I received a large bubble-mailer from New York. Inside, I found my latest shipment of NiCopp with tight 90-degree bends on one end. IMG_2572.jpg
    So, after dinner, I made my way down to the garage and got to work.
    No music, no distractions, just pure focus on the task at hand. The new material bent far easier than the previous stainless steel. And, with a little bit of persuasion, it looks as if I completed my first piece of the brakes. I ran some brake cleaner though it and immediately found leaks. I then tightened everything down and I think I got it! (I actually ran out of brake cleaner, so I'll grab some more tomorrow and continue to test.) IMG_2577.jpg
    I made sure there was adequate space between the radiator and the brake line.
    Although the setup feels sturdy, I plan to make a little tab to keep everything in place. It will be welded to the frame. As discussed earlier in the thread, this configuration will allow me to remove the radiator without having to dis***emble the brake system. I'd say it was a good night in the garage.
    tr_rodder, BigJoeArt, drdave and 13 others like this.
