Hot Rods How about some love for the T-Bucket?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 9, 2021.
  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. 40ragtopdown
    40ragtopdown
  6. RodStRace
    RodStRace
  7. 26 T Ford RPU
    26 T Ford RPU
    Been looking at a lot of exhaust systems on these buckets and many (to me) are just too visually loud and over powering against the rest of the car. JW
    brEad, loudbang and Tow Truck Tom like this.
  8. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    That's what I call 'Payin' Attention.'
    Snicklefritz65 likes this.
  9. RodStRace
    RodStRace
    The typical way to go is the Sprint style
    or Cl***ic style
    header that gets the path outside the frame rails and outer body line. Early Ts had hand built headers that also did this. All mimicking dirt track exhaust or drag exhaust. A few had manifolds and the piping tucked under. Cleaner, but tight clearances, had to be fitted and I'd guess heat in the bucket and other components is a concern. This could be done with 'block hugger' headers too.
    1927 ch***is shown.
    I've seen a few with lakester style headers home built or bought. They can be baffled or routed under.
    There have been a few that went outside the box, but none that have set a new trend, so I don't think I'm alone in thinking most are not visually pleasing.
    Do you have examples of what tickles your fancy, aside from your own? Always open to new ideas!
  10. Paul
    Paul
    Editor
    whatever gets the job done
    Lil'Alb, oldandjaded, Sancho and 14 others like this.
  11. RodStRace
    RodStRace
    Diggin' it, don't know how close to the body I'd want them, seems it might toast paint. Note the pipe coloring.
    That has another thing that I'd want to incorporate into my build IF I did a ground up.
    That super deep dish wheel. Couple that with a quick disconnect and you have lots of room for ingress and exit. Looks cool too.
    brEad and bchctybob like this.
  12. KevKo
    KevKo
    from Motown
    The pipes will get hot, but that discoloration indicates the engine was too lean.
  13. Paul
    Paul
    Editor
    02 sensor says it lives in the 12 to 14 range mostly mid 12.
    plugs show carbon on body and light tan ceramic.
    the blue is from driving it hard.
    there is 4" between pipe and rattle can paint.
    Lil'Alb, oldandjaded, Sancho and 11 others like this.
  14. Sky Six
    Sky Six
    from Arizona
    I had my pipes coated inside and outside and they never turned blue, but they were not shiny. The full car is in the OT section. 1006121611d[18113].jpg 1006121612[18112].jpg
    duecesteve, loudbang, Deuces and 4 others like this.
  15. 26 T Ford RPU
    26 T Ford RPU
    I think i like lakester style the most out the ones shown but the one Paul posted look really good because they are tucked in and the color doesn't make them stand out like dogs balls. The Fad T era set the standard for oversize ugly headers and give a confused look when used on other build styles. On my T RPU i used Rams Horns a hid the pipes underneath and they don't get very hot. There's right and wrong applications for all types used on these cars but that's just the owners personal taste in the end and we can still like or dislike any of them. JW
    loudbang, brEad, AndersF and 3 others like this.
  16. RodStRace
    RodStRace
    @Sky Six , I caught your T over there and like it a lot, plus I've been researching the old Specialty Cars Ts and you've posted a few altereds they had a hand in. Good stuff!
    You are even in AZ, although waaay down there IIRC.
  17. Sky Six
    Sky Six
    from Arizona
    Yes, I am down where the debris meets the sea.
    Tom at Specialty cars made excellent "T" ch***is and Anglia's also.
    He was a great help and sponsor for Bob Nylander's restoration of Pure Heaven II and also the Bantam Hunter. Tom also did a ch***is for Bob's Fiat Topolino that was a piece of art.
    RodStRace and Jim Bouchard like this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    While mixture & hard running does blue pipes , retarded timing will fry headers in a heartbeat .
    bchctybob and Paul like this.
  20. Tim_with_a_T
    Tim_with_a_T
    ^ his plugs look like the heat range and timing are right on to me.
  21. Tim_with_a_T
    Tim_with_a_T
    Tow Truck Tom likes this.
  22. 40ragtopdown
    40ragtopdown
  23. bchctybob
    bchctybob
    ^^^^ Guys with T Buckets get all the hot chicks! ^^^^
    dana barlow, Deuces, deadbeat and 3 others like this.
  24. 40ragtopdown
    40ragtopdown
  25. 40ragtopdown
    40ragtopdown
  26. 40ragtopdown
    40ragtopdown
  27. dana barlow
    dana barlow
    from Miami Fla.
    EX pipes,style/design :D:cool:,I always though helped over all look.;) for my Ford "Y" Thunderbird power
    But as the years p***ed,{ in 1959 #1 set up was not pretty,,just temp*,,and my #2 set of headers I did too look as good as I could do.for custom headers,started cracking an after a few fixs,made a new sets,about every 6 to 10 years,{ I could not chrome them,just not a big enough piggy bank ever!!,, so BBQ black or silver from time to time.
    I liked custom designs* vs m*** built. It gets harder too do your own. as we get older.
    Then a buddy who also had a 23T-SBC power ,I helped him build his,who used a standard chome header set,cracked one of his tubes very close too head flange. He ask if I could weld it for him ,with out killing the chrome< Nope! LOL,so he got a all new set for his SBC 350. < Gave me the SBC cracked chrome set. Chome was still nice,except for the crack.
    I held them near my Ford"Y" block heads,found out SBC Headers,other then SBC being close together on center pipes= were same as Ford;;;So I cut SBC flange off ,open center pipes a little,and welded SBC Headers to Ford pair of flanges. They been holding up well for a few years now.. 001 (4).JPG
    oldandjaded, Sancho, Deuces and 5 others like this.
  28. Z06-LITE
    Z06-LITE
    I have had mine on the road since 1980 and still have the same "Old Hen".
  29. 40ragtopdown
    40ragtopdown
  30. 40ragtopdown
    40ragtopdown
