Projects A Michigan Model A build
Discussion in 'Traditional Hot Rods' started by Hot Rod Apprentice, Feb 4, 2022.
  1. Hot Rod Apprentice
    Hot Rod Apprentice
    Haven’t had a lot of progress on my coupe in the last couple weeks. My 3yo daughter on the other hand has switched from saying “daddy’s hotrod” to “our hotrod”. But with the school year winding down work has been very busy. We do go karts the last day for seniors. Every year I make modifications to make the our karts a little less high maintenance. Last year I installed cross steer steering linkages to wear tires less. This year I’m fabbing and installing chain tensioners so I won’t have to do chain adjustments anymore. Unfortunately I’ve been off for a couple days with a nasty sinus infection. I was going a little stir crazy so I masked up and ran up north to pick up a few vintage Mallory Distributors . IMG_5848.jpeg
    Outback, Deutscher and Jeff34 like this.
  2. HankAz
    HankAz
    How did you break the profile hammer? Just asking because I just cut one out and I might be better off cutting it out of 3/8ths to begin with. Also did you make the dies to make the body lines on the front of the cowl? Would like to see some pictures of them if you could.
  3. Hot Rod Apprentice
    Hot Rod Apprentice
    The profile hammer frame itself is fine in 1/4”. The driven arm seems to be the problem. I’ve made it in 1/4 and 3/8” both struggle. It keeps cracking an 1/8” below the weld. I messaged Carl Fischer on instagram asking if he had had any issues. He said “I’ve been able to keep together a quarter inch upper holder but you definitely have to gouge the corners out and really weld it”. I suspect the 16 gauge is pretty brutal. I think I may eventually mill an arm from tool steel. I made my front cowl in 4 stages. I started tipping the front lip with tipping pliers. Don’t use a metal brake, it’s not a straight line. Ask me how I know. I then did the narrow bead, followed by the joggle, then the joggle with the bead. I will post some pictures tomorrow of the dies.
    Outback likes this.
  4. HankAz
    HankAz
  5. Hot Rod Apprentice
    Hot Rod Apprentice
    IMG_5867.jpeg These are the profile does I used and abused to make my front cowl. It took several attempts to make one that I was happy with.
    Okie Pete, Deutscher and Jeff34 like this.
  6. Hot Rod Apprentice
    Hot Rod Apprentice
    Progress!!!
    I haven’t posted in a bit. Project car time has been limited between work, house projects, and taking care of family. Still have to button up the lower quarters and remake the lower trunk pan. Slowly but surely we are getting there.
    Okie Pete, Outback, Deutscher and 5 others like this.
  7. Hot Rod Apprentice
    Hot Rod Apprentice
    IMG_6558.jpeg IMG_6559.jpeg IMG_7104.jpeg IMG_7111.jpeg IMG_7574.jpeg IMG_8062.jpeg IMG_8072.jpeg IMG_8070.jpeg IMG_8096.jpeg IMG_8097.jpeg
    Here is my past due photo dump. I haven’t posted much in the past year. It’s been one of those situations where toys often have to be put on the back burner. Family, work, and home ownership can often cut into “garage time”. Progress has been slow but my ‘31 has continued moving forward. In fact, so much so that I am now finally attaching body panels to the subrails. I had a buddy over to check my work and give me a
    second set of eyes before I locked everything down. Then I had my little inspector come out and share her thoughts. She just said “it needs to be loud”.
    I am very excited to move away from body work for a little bit and begin some chassis work.
    My goal for the summer is to have a tack welded rolling chassis come its end. I think I am right on par for end of August.
    Kiwi 4d, CSng61, Okie Pete and 10 others like this.
  8. Deutscher
    Deutscher
    from Germany
    You've done a great job, the Model A is going to be fantastic, and you're a great dad to a sweet girl.
    Keep up the good work, life has so much to offer.
    Greetings, Harald
    Hot Rod Apprentice likes this.
  9. Outback
    Outback
    from NE Vic
    Well done, my lil gurl loves our model A too! - The louder the better she says!
    Sounds like you are doing a good job with the juggle Resized_6E8CC782-_1719708486350.jpeg
  10. Deutscher
    Deutscher
    from Germany
    My daughter was born in 1993.
    Time has flown by so quickly.
    I always worked shifts.
    She's a young woman now.
    Where has the time gone?
    Have a wonderful time with your children. Oh... I'm getting sentimental, sorry.
    Greetings, Harald
  11. Just joined the page today. I live down in Battle Creek Mi. I have a 1930 Tudor. I haven't started anything yet due to trying to finish up my 71 F-100. Once I get that on the road I wanna start the A. Haven't decided on a direction for it yet though. Probably traditional, mild chop, leaning towards fenders, engine will either be a banger or flathead.
    Okie Pete likes this.
  12. Three97’s
    Three97’s
    from SE MI
    Wow, from a fellow Michigander, very impressive work. I just picked up an A Tudor a month ago, so I'll be following along!
    Outback and Okie Pete like this.
  13. Three97's. What city are you in?
  14. Hot Rod Apprentice
    Hot Rod Apprentice
    Lansing
  15. get ahold of me if you need a hand or if you come down around Gilmore car museum. I am finishing up a different project and will be starting on my 30 ASAP!! I worked at the GM plant a few times. That's about 40 minutes from me here north of Battle Creek
  16. Hot Rod Apprentice
    Hot Rod Apprentice
    Thank you. I will keep that in mind!
  17. Three97’s
    Three97’s
    from SE MI
    Brighton area, if it was really me you were asking, lol.
