Hot Rods Blown Caddy? Pics? Help? SUPERCHARGER 101
Discussion in 'The Hokey Ass Message Board' started by bobbleed, Sep 13, 2010.
  1. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    I've looked into this for my 331 and a 3-71 driven 1:1 will give you approx. 4 lbs of boost which will give you a bottom to mid range kick you'll definately feel.I dont recommend more than that given the restrictive nature of the caddys small ports and valves not to mention the long rods become unwieldly at higher rpm.With the original 7.5:1 compression you'll get about the equivalent of 9:1 with the 3-71 and still be able to run pump gas.Two Carter WCD's are all you need on the intake side.If you want more than this I suggest a 365 or 390.Good luck and post pix if you go thru with it.
  2. bobbleed
    bobbleed
    from Awesome
    No real progress, but I have a line on some Vbelt stuff and some ideas for a top.... its going to be awesome!
  3. Louie
    Louie
    from NJ
    any progress?
  4. 60elky
    60elky
    I know someone making adapter plates to put nearly any SBC intake on the early Caddy, "me", :). Here is a 671 on a '59 block. They'll be available later this summer. I'll post them "for sale" on the appropriate page once they're ready. I want to have all the accessories fit up before I release them.
    Enjoy,
    JK
    Fordors, Paul and rod1 like this.
  5. 60elky
    60elky
    Here is some info on the lower adapter and the shiny pullies. I used big block Buick by "CVF Racing". I have a 3D model and a 2D machinist drawing of the adapter. I'll stop stealing this thread now.
    JK
