Hot Rods Turbo 350 Tranmission Forward Clutch Drum springs
Discussion in 'The Hokey Ass Message Board' started by Heimbig, May 19, 2024.
  1. Heimbig
    Heimbig
    I tore apart my turbo 350 and found that 3 of the springs on the forward5 clutch drum are broken. There are 21 loose springs on my unit, anyone have a source or have any used ones?
  2. gimpyshotrods
    gimpyshotrods
    Don't put used ones in.
    Brand new direct clutch spring sets are under $30, plus shipping, with the retainer, and even less without.
    If you are ok with used, you can get the entire ***embly for $25, plus the ride: https://globaltransmissionparts.com/th350-direct-piston-kit/
  3. Heimbig
    Heimbig
    I have been trying to find new ones but internet search turns up nothing. Do you have a source or reference for them?
  4. Heimbig
    Heimbig
    also it looks like the direct clutch sprigs are different than the forward clutch drum apply springs.
  5. gimpyshotrods
    gimpyshotrods
    Please post a picture of what you are working with.
    milwscruffy likes this.
  6. justpassinthru
    justpassinthru
    Turbo 350 clutch drum springs are generally different for forward and direct drums.
    The springs and retainer are separate on earlier models. The most common was forward drum springs were green and heavier than the purple, lighter springs in the direct drum.
    Sometimes, the color can be gone.
    If the springs and retainer are integral, you will need to replace as an ***embly.
    I replace collapsed or broken springs with good used all the time, without issue.
    If the springs and retainer are integral, just replace as an ***embly.
    Go to a local trans shop or talk to a supplier like Fatcso or Northwest Transmission Parts.
    Bill
  7. Heimbig
    Heimbig
  8. justpassinthru
    justpassinthru
    Better buff all that rust off the input splines before you put it together.
    You could always do the hillbilly shift kit modification, although I would not recommend it, and install 6 springs, space, 6 springs, space, 6 springs, space. You may get a harder apply though, I have seen it done before.
    Bill
    gimpyshotrods likes this.
  9. Heimbig
    Heimbig
    I think that is what the prior re builder did, as the 3 springs weren't broken they were missing, hoping to find some to get back to all 21 of the springs.
  10. Kevin Ardinger
    Kevin Ardinger
    I wouldn’t bother. Leave them out. May apply very, very, very slightly firmer but you will never notice.
    squirrel likes this.
  11. squirrel
  12. woodiewagon46
    woodiewagon46
    from New York
    Fatsco Transmission Parts in NJ 800-524-0485
  13. gimpyshotrods
    gimpyshotrods
  14. gimpyshotrods
    gimpyshotrods
  15. squirrel
    I figured there had to be a deal on them somewhere. I used to have bins of that stuff, all gone now
  16. Heimbig
    Heimbig
    On order as I type.
    Thanks everyone
