Technical ***May 2024 Banger Meet Thread - Remember your Mom this month***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 2, 2024.
  1. 282doorUK
    282doorUK
    Could you give us any info on those banjo fittings you have on your oil filter please Phil ?
  2. Phil Damon
    Phil Damon
    from San Diego
    Watched the live stream on Saturday. Started watching on Sunday, but had yard work to do. I did see the roadster run, but not the belly tank. A friend of mine is the guy that does all of the Ardema-Braun videos.
  3. Stan Back
    Stan Back
    "May Is 2024 Banger Month . . . Remember Your Mom"???
    GuyW and Mainedrifter2 like this.
  4. Phil
    I think Greg does the video for Pete and team
    Owen and Greg are First Robotics compe***ors and went to World Finals Championships this year in Houston
    It truly is a small world
    J
    Outback likes this.
  5. Dan from Oakland
    Dan from Oakland
    Straight Rajah terminals would solve hotrodfil's problem and look period correct but you need the boot to insulate your wires in the plug well as I recall. I'm probably going to end up with 10mm plugs in some adapters because a 14mm plug in an 18mm adapter makes for a pretty thin adapter cross section. So I'm planning on Rajah terminals to slay that dragon.
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Yur absolutely right Dan, nothing I do is normal! My plugs are down in a hole so limited options for wires and lots of opportunity for arcing. I haven’t actually identified an arcing problem, but any air gap will eventually allow arcing or at least corrosion eventually.
    Outback likes this.
  7. LZKAR7A - a Citroen Berlingo plug by all accounts.
    Just being lazy - the boots were already on the leads. Also, the top of the plug is fixed without the removable nut.
    Oh, and the fan has been swapped out for a Northern Hemisphere one... I was checking the diameter to see if a Morris Minor one might fit.
    Outback likes this.
  8. wuga
    wuga
    We just started working on a 28 roadster and found this e-brake setup. Unlike the AR setup on the left side in the Tudor or the side mount in the 30, I have not seen this before. What do we have here?
    Warren
    meteorpete likes this.
  9. Phil Damon
    Phil Damon
    from San Diego
    I've known Greg for 25+ years. I didn't realize it was him doing the videos until I saw him last year at a Christmas party. Very small world. I worked for Randy Nelson 30 years ago, but wasn't involved in his land speed efforts. I was crew chief on his drag race team.
  10. Phil Damon
    Phil Damon
    from San Diego
    I have one of those transmission top covers. It was with a bunch of parts that came from my dad. I have always wondered which model it fits.
  11. I believe that's the mid 28-mid 29 top. I'm at work and not around my book collection. I'll try to remember to check for you tonight
    G Baese likes this.
  12. 1/4” BSP hydraulic banjo into the block And 1/2” BSP straight into the filter I recall. Had the hydraulic hoses made up, and the fitting into the gear cover was made by RKE to run into the gallery in the Burtz block.
    282doorUK likes this.
  13. Stovebolt
    Stovebolt
    I believe you're right on that one.
    My coupe has the same setup. My body number is 313, so it's an early production
  14. Crazydaddyo
    Crazydaddyo
    This Sunday.
    GuyW likes this.
  15. Exhaust blowing at the manifold flange but it’s running…
    GuyW, G Baese, Stovebolt and 4 others like this.
  16. Jeff34
    Jeff34
    You know you’re on the wrong side of the road, right?
    GuyW, BeaverMatt and Stan Back like this.
  17. Outback
    Outback
    from NE Vic
    Woohoo, good to see! @hotrodfil it's a cool jigger!
    I drove my model A to the local historic's race day, but no photos or it didn't happen yeah!? Haha I guess it didn't happen.
    @Jeff34 didn't even notice hahaha
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    It turns left!!!! :cool:
    I changed the leverage on the linkage and installed the barrel reducers… it sure feels snappy!!! Gonna lower the floats a touch to reduce the accelerator charge and ****on er up. Ready for the Virginia City FAST hill climb next weekend:cool:
    akkhotrod, 40 Olds, GuyW and 5 others like this.
  19. Outback
    Outback
    from NE Vic
    Woohoo
  20. 29Sleeper
    29Sleeper
    from SoCal
    Good Antique Nationals video
    I want the spun aluminum wheel covers on the '32 at 1:26
  21. denis4x4
    denis4x4
    from Colorado
    Probably should wait until tomorrow, I need the part number for a throw out bearing for a T-5 transmission in an A with a v-8 clutch. One I have says MADE IN USA. GREEN. It’s 3/4” thick.
  22. brokenspoke
    brokenspoke
    Someone on here sells one that has a bushing installed in the bearing, Cornhusker ?
  23. Jiminy
    Jiminy
