Technical What are you guys using for roof mounted wipers ?
Discussion in 'The Hokey Ass Message Board' started by Do it Over, Dec 28, 2019.
  1. Do it Over
    Do it Over
    from NYC, NY
    I'm getting close to needing to buy my wiper motor/motors and want to know what works best. My car is a 1935 Ford 5W. Should I do one wiper or two? I don't expect to drive in the rain much if at all but I would like to take it out on the road once or twice.
    Thanks
    Leon
    dana barlow likes this.
  2. Dirty Dug
    Dirty Dug
  3. 12volt vw wiper motor works pretty good for single wiper
  4. Oliver Steward
    Oliver Steward
    I used a series 1 Landrover , it mounts through the screen frame and the casing polishes up nicely if you see it from the inside of the car .
    Jim the Sweep and Do it Over like this.
  5. Hnstray
    Hnstray
    from Quincy, IL
    Several years ago I installed a Newport Engineering electric wiper kit in my brother’s ‘38 Ford Coupe. It was a top mounted dual wiper system operated by a single motor. His car was a originally a single wiper model, but the Newport kit provided templates and detailed instructions to accurately locate and drill the hole for the second wiper. It worked perfectly.
    In addition to my brother’s car, I have since installed Newport Engineering electric wiper kits in
    several vehicles I have owned, including a ‘47 Ford, ‘41 Buick and most recently, a ‘37 Chevy.
    The kits are very well designed, rugged and complete.
    Ray
  6. 1934coupe
    1934coupe
    Back in the old days we used a wiper motor from a boat. Living on LI there were plenty of marine supply places. They worked ok but I'm sure there is better stuff out now like Dirty Dug and Hnstray suggested. Just remember you may not plan on using it but when you need it, it better work well!
    Pat
    chryslerfan55, chopped and Do it Over like this.
  7. I have used the Newport engineering setup on several cars with good results. This is a very well built product and works as it should.
    lemondana, Hnstray and Blue One like this.
  8. Blown35
    Blown35
    On my 35 3 Window I use a stock single unit - since you do not anticipate heavy rain use - should be the easiest to use.
  9. sunbeam
    sunbeam
  10. Frank Carey
    Frank Carey
    I built my 37 sedan before the cable operated after market units were available. I used VW beetle motor and wiper shafts. Added a bell crank to p***enger side so both wipers would park "out". Everything fits under the stock header panel. Made beveled spacers for wiper shafts so shafts would be perpendicular to gl*** (important). Henry used such a spacer on originals. Use carb-type linkage with bearing ends to keep everything tight.
    HunterYJ and Do it Over like this.
  11. krylon32
    krylon32
    from Nebraska
    I've built 2 cars using the Newport top mount dual wiper system. Worked perfect.
  12. Blue One
    Blue One
    from Alberta
    lemondana, gnichols and 1934coupe like this.
  13. chinarus
    chinarus
    from Georgia
    Looking for dual wiper options and found this thread.
    I was able to find the attached picture.
    How complicated is the installation?
    Anyone got a picture of it fully mounted?
  14. Jim the Sweep
    Jim the Sweep
    Volvo 240 series Headlight wiper.Afriend with an OT but 1940s Dodge Military truck uses them inside the original vac wiper housing. Worth a look?
  15. chinarus
    chinarus
    from Georgia
    Volvo 240 parts diagram attached - anyone tried this as an option?
  16. A Boner
    A Boner
    Rain-X for removing water from windshield…Plain old Speedway universal unit to pacify DOT/Cops!
  17. nobby
    nobby
    If you use the trico / lucas system on a 35/6 i think the wheel boxes can only be fitted
    to receive the cable at the top, as if fitted to the bottom with the wiper spindles in the oem holes, the cable would clash with the hinge pocket things
    so..... what does that mean I hear you say,
    well it means because you can only mount the inputs to the top
    you then have to mount the drive motor either to the a pillar at the corresponding side in order for the arms to park in the correct place
    hmm
    i did do a video , but its a bit ****e
    anyplops here it is.
    ii think it kind of helps
    I did fit one to a 37 and its really good
    nobby's 1936 Ford Pickup project shenanigans part1 (youtube.com)
    buy 10'' wiper blades
    get the complete set up from a cl***ic mini
    get the mini escutcheoms
    get LONG wiper boxes
