Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Looking at the next few days, I plan to piece as much of the brake system together as I can as I wait for parts. I'm waiting on two fittings: the one on the back of the master cylinder and the T for the rear axle. Both should be here by mid next week.
    Oh, and I also got my starter solenoid today! What are people running as far as starter ****ons are concerned?
    drdave, Stogy, winduptoy and 7 others like this.
  2. denis4x4
    denis4x4
    from Colorado
    I’m running a floor ****on on one car and keyless pull to start, push to stop on another car.
    Stogy, J.Ukrop and Six Ball like this.
  3. wuga
    wuga
    These are available everywhere. I would paint the ring black and mount it in the upper left corner of the black dash surround. I take it that the hole right of center in the insert is for the ignition switch. I run this ****on with the same solenoid. I also ran my positive battery cable to a shut-off and then to the solenoid.
    Warren
    Stogy, J.Ukrop, RodStRace and 3 others like this.
  4. Tim
    Tim
    from KCMO
    Good progress report. I am curious what points you’re testing for leaks. If your gonna have to pull the lines off to paint the frame testing every junction would seem like waisted effort to me?
    Unless you’ll drive the car as is and then take it all back apart later?
  5. Taboo56Chevy
    Taboo56Chevy
    on my 33 pickup, used two holes in the dash, one for a key for running than an old chrome starter ****on. I have no clue what its out of. You could use a 48-51 F1 starter ****on as well. We actually use those as the door poppers on Taboo, lol. 1538803_781802488500174_490833137_n.jpg
    winduptoy, Outback and Six Ball like this.
  6. Get yourself some flare nut wrenches (the best you can afford) if you don't already own a set, that will let you crank down on the flare nuts without risking spreading the regular box wrench jaws and rounding off the hex corners of the nuts. I have my Snap On ones that I bring home from work since the cheapies I got from Linda Mar ACE (in the 90's no less) don't have the meat around the wrench heads to hold the proper dimensions while tightening. If you can find a tool truck you can just grab the sizes you need rather than the entire set since that would run you almost $400, there may even be used ones available if you ask the rep, usually around 35% or so cheaper than new.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you everyone for the insights. Full replies happening tomorrow. In the meantime, I've been down in the ba*****t making progress on the brakes. IMG_2615.jpg
    And for those of you who are Bay Area-based, I'll see ya at Ocean Beach in the morning!
  8. winduptoy
    winduptoy
    Getting caught up...I have been absent for a bit.... and happy belated birthday. Looking great but I'm having a hard time getting my head around the springy, coiled stuff around the brake lines. I'm just wondering about NiCop and vibration....maybe my worries are unfounded.
    Carry on
    Stogy, Outback and Six Ball like this.
  9. Tim
    Tim
    from KCMO
    @winduptoy the coiled spring is basically a rock gaurd of sorts m. I’ve seen them on some pretty ancient hulks so I ***ume they are pretty traditional.
    the nicop shouldnt vibrate any more than anything else does when properly supported. Lots of over seas cars run it from the factory and I think it being a little softer probably keeps from any real chance of work hardening and failing.
  10. patsurf
    patsurf
    let's just hope he doesn't solder any connections on the brake light switch--would be a ticking time bomb!
    winduptoy and Tim like this.
  11. gimpyshotrods
    gimpyshotrods
    If you go on eBay and search for vintage Snap On flare nut wrenches and flare nut crow's foot sockets, deals can be had.
    https://www.ebay.com/sch/i.html?_fr...l1313&_nkw=vintage+snap+on+flare+nut&_sacat=0
    They will still carry the lifetime warranty! This is how I get all of my Snap On stuff!
    You can always borrow mine. It's not like I am doing brake work every day, or long term.
    winduptoy, Stogy, Driver50x and 5 others like this.
  12. Tim
    Tim
    from KCMO
    I got all my odd ball wrenches like that in a gallon ziplock bag at estate sales. Lots of people go for the big ticket items and then p*** on the bag of smelly screw drivers and wrench’s but more often than not it’s got a couple big $$ wrench’s hiding in there.
    then you’ve got the right wrench and some some new chisels
    Lol
    winduptoy, The 39 guy, drdave and 2 others like this.
  13. gimpyshotrods
    gimpyshotrods
    Ebay vintage is where it is at, especially if they have "owner's marks" on them.
    The rancid tool collecting crowd does not want the marked ones!
    This is how I have a full complement of Snap On tools, and no debt!
    winduptoy, The 39 guy, drdave and 7 others like this.
  14. Tim
    Tim
    from KCMO
    Also I saw a video the other day that you can wash your tools that smell like vomit in a baking powder / water mix and it will neutralize the off gasing stink coming from the handles
  15. Six Ball
    Six Ball
    from Nevada
    You're giving away our eBay secrets. :eek:
  16. Beanscoot
    Beanscoot
    The awful smell is usually from the early plastics used for screwdriver and nut driver handles.
    I think a lot of them were made of Casein (milk) plastic, and kind of want to revert to fifty+ year old milk.
    They also will induce rusting in near by tools, but this can be minimized by giving them a soap and water bath every few years.
    winduptoy, Stogy, Outback and 2 others like this.
  17. Tim
    Tim
    from KCMO
    Yup that’s exactly what’s going on the handles are stinking it up. Dawn dish soap will neutralize a mild acid. I can’t recall exactly what’s happening but there was acid involved lol
    winduptoy, Stogy and Outback like this.
  18. Six Ball
    Six Ball
    from Nevada
    In the '60s a lot of times when we didn't know what was happening acid was involved. :eek:
    ric, Stogy, Jeff34 and 5 others like this.
  19. gimpyshotrods
    gimpyshotrods
    Still true.
    winduptoy, Stogy, Jeff34 and 2 others like this.
  20. trevorsworth
    trevorsworth
    I have an old toolbox that was my great uncle's and it smells so bad I can't even stand to open it. It makes me gag. I have never been able to figure it out because nothing inside is even dirty. That explains it... it has always been in a shed/garage in the heat and humidity.
    Stogy, Six Ball, Tim and 1 other person like this.
  21. Tim
    Tim
    from KCMO
    “Acetate-handled screwdrivers are fairly tough, durable, and easy to clean, but like a lot of materials they age over time and outgas. What’s basically happening is that the Cellulose Acetate Butyrate (CAB) material is slowly decomposing, and the byproduct has a particular smell to it.
    I’ve read that it’s the butyric acid component from the chemical breakdown that causes the vomit-like stink.”
    there that’s basically what I had seen, would explain the neutralizing bath. Wash that tool box and get a lot of usable tools back!
    ok back to joeys roadster guys lol
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    More details, please!
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you everyone for the tool info! eBay and estate sales are my go-to, and it's good to know more about the composition of their handles. Speaking of tools, one of my neighbors must be reading this thread. Look what was left out for Recology to come pick up, but was too big for them to take?
    I scooped it up, carried it four houses down, and put it right into service.
    It's been a goal of mine to be able to drive my roadster again, so on Saturday afternoon I went to go retrieve it from the garage. I slowly climbed in and got a feel for the pedal placement. Clutch? No problem. Gas? Easy. Brake? Eh, not so good. My range of motion isn't quite where it needs to be to get to the brake. But I figured it would be a positive exercise—physical therapy style—to get out there and give it a try.
    And try I did. It wasn't long before I was sailing down Geary, working my way through the gears. The sun was out, and I was back behind the wheel of my favorite machine.
    Now, to a more technical project. I spent the first part of the weekend working on brake lines. IMG_2606.jpg
    Some of them took several tries, but I'm overall happy with how the system is coming together.
    My hardware for the clips should be showing up on Wednesday. For now, blue painter's tape does the job. IMG_2616.jpg
    Clips to be modified.
    Driveway scene.
    Dash board mockup, just for fun!
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I need to go to sleep, but I just wanted to share this shot before I sign off (I'll explain more later). I'm excited to share that the car now has a complete driveline. Running flathead, rebuilt-'39 trans, custom torque tube, and freshly built quickchange. This is big progress. That's all for tonight—I'll be back with more soon!
  26. Tim
    Tim
    from KCMO
    A steering box and a crate to sit on and we’d have a fun video to watch I’m sure of it, but with those local hills I suppose waiting for brakes is ideal ;)
    Thanks for the update, curious to see you attach the lines to the banjo.
    winduptoy, The 39 guy, Stogy and 3 others like this.
  28. Joey,
    Congratulations on the major accomplishment of having a complete driveline unit!! You're making great progress and I am excited to see this version running and driving.
    Brian
  29. RodStRace
    RodStRace
    Jealous! I'll get there!
    Nice work! I ***ume the lines will be evenly spaced away from housing so they won't vibrate and wear.
    Bolts into housing, or welded studs and nuts? Either way, make sure of no leaks and easy removal and installation later.
    Outback, Six Ball and Stogy like this.
  30. gimpyshotrods
    gimpyshotrods
