Technical Algon Fuel Injection for Nailhead - fuel pump ideas?
Discussion in 'The Hokey Ass Message Board' started by BOSTONCAMARO, May 26, 2024.
  1. Any ideas on what to adapt for a pump? I am sure it will not be easy to find an Algon and another fuel injection company went bust.
    I need to through this but want to get some ideas. I appreciate the insight.
    Deuces likes this.
  2. Is this Algon injection some thing that you had for a while, or did you get it recently from " dual quad 55 " here on the HAMB ?
    mad mikey likes this.
  3. mad mikey
    mad mikey
    Call Alkydigger.
  4. Fordors
    Fordors
    Algon injection first used a low pressure pump from an aircraft application. The name of at least some of those pumps was Cherry ****, sorry but I can’t recall the second half of the name. Anyway I believe the pump pressure was around 5-6 psi and the individual cylinders could have their flow adjusted with flow control valves as seen here.
    This is a more modern flow control shown for clarity.
    Hilborn pumps were around 30 psi and when Algon made the switch to higher pressure they stopped using the flow control valves and went to a metering block with a barrel valve. I’m thinking you could get a drive spud for the end of your cam and adapt a Hilborn pump and metering system to your Algon manifolds. Sounds easy but I never tried.
    BTW, am I correct to ***ume this engine will be built for compe***ion use only?
    Stan Back, Deuces and BOSTONCAMARO like this.
  5. Ericnova72
    Ericnova72
    from Michigan
    I think that was Cherry-Burrell.
    They are still in the fluid pump business.
    jimmy six, NoSurf, Deuces and 2 others like this.
  6. Motor is a built motor, may swap on for track use - need to get car together first but starting to research.
  7. miker98038
    miker98038
    The Algon pump for my Yblock set up. Cherry-Burrel, Algon drive unit. IMG_0046.jpeg IMG_0048.jpeg
  8. 1934coupe
    1934coupe
    I second mad Mikey, call Alky Digger
    Alkydigger.com
    307 White Bridge Pike
    Nashville, TN 37209 US
    Customer Service: 615-457-3192
    Pat
    loudbang, mad mikey and 427 sleeper like this.
  9. NoSurf
    NoSurf
    This sounds very cool.
    BOSTONCAMARO likes this.
  10. Stan Back
    Stan Back
    I don't understand the need of individual flow adjusters. On the street or on the lakes, we never needed those in well-maintained systems of Hilborns and Enderles. (Or we maybe just couldn't see the need.)
  11. miker98038
    miker98038
    I don’t know what is true, but this is what I’ve read and been told.
    These early Algon’s (and maybe later ones) used a fuel byp*** connected to the throttle linkage. You can see it in the above picture. It also mounted the fuel hoses. There’s a needle (think a Carter step up rod, or better the fuel needle in an SU) to richen the mixture as more throttle was applied.
    Apparently the circle track guys liked these as they gave better response for part throttle to WOT exiting the corners. But the only really good tuner was Al Gonsalves himself.
    The fine tuning was accomplished with those valves at the injectors. Not so much necessary when only interested in WOT performance.
    Any comment on this more than welcome. Theres also an Algon thread or two here.
    BOSTONCAMARO, 427 sleeper and Fordors like this.
  12. Thanks, I will research thiz
  13. jimmy six
    jimmy six
    I’ve used 2 Algon injector systems on my GMC ‘s. Both had Cherry-Burrel pumps. The were the later ones without adjustable nozzles. According to Enderle they have an excellant barrel valve style. I changed both to Enderle pill/jet nozzles and used a Hilborn pump after fighting the Algon adjustable plate on the C-B pump. Both mine also used a belt drive.
    Stan Back likes this.
  14. jaracer
    jaracer
  15. Stan Back
    Stan Back
    I used a belt drive on the street on and off for about 30 years or so. One time with my way out-gunned roadster racing my friend's strip-ready 427 Chevelle, I got ahead of him (1st time ever!) and went thru 1st and 2nd in my Hydro, throwing it in neutral, over-revving the motor taking the belt drive out and declared me the winner (1st time).
