Projects Somebody Gave me a 1955 F100 “Effie” It’s a rough one . Paint with iodine and mark it duty Doc!!
Discussion in 'The Hokey Ass Message Board' started by F-ONE, May 27, 2024.
  1. F-ONE
    F-ONE
    from Alabama
    Yep.
    It’s been in a pasture since 1978.
    So I’m gathering parts. It needs a lot. The first thing to do is get it to roll. Right now it’s locked up on 4 flats. I had to drag it off the trailer.
    It’s really a decent old truck.
    I’m going to get it to roll. Then I’ll pull it into the shop.
    I’ll make it stop.
    I’ll make it turn.
    Then I’ll repair or replace what’s rusted away.
    After all that I’m going to ruin it with a 283.
    bymanr, craig b blue, Deuces and 31 others like this.
  2. CyaNide
    CyaNide
    from Texas
    Don’t have to ruin it. You said Effie, that means it needs an FE.
    CN
    Deuces, Cooon, blue57ford and 12 others like this.
  3. williebill
    williebill
    Take it back to the pasture......
    rpm56 and 29A-V8 like this.
  4. I'd drive it as Anthony would say. No painting needed.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Keep posting your progress. Any engine choice is better than sitting in a field;)
  6. The37Kid
    The37Kid
    EFFIE, old people take the time to spell things out, saves going to Google the definition.
    warhorseracing and hotrodjack33 like this.
  7. You mean like: Aunt Effie and Uncle Harold?
  8. brady1929
    brady1929
    That truck deserves to be fixed up.
    Deuces, Gasser 57, Irish Mike and 3 others like this.
  9. Budget36
    Budget36
    Piss them all off.
    Have “powered by SBC” stenciled on the hood sides:)
    FWIW, I’ve always ***ociated Effie with Ford PUs from the start of F1’s to the ‘56 year.
    Deuces, Gasser 57, Johnny Gee and 4 others like this.
  10. manyolcars
    manyolcars
    my grandmothers name was Effie. Its weird to name a truck an old ladies name
    Deuces, deadbeat, clem and 2 others like this.
  11. The37Kid
    The37Kid
    Care to share your definition with the rest of the world? What the **** is a EFFIE?
  12. gary macdonald
    gary macdonald
    One that collects F-1 trucks ? Is my guess , or the f-1 is an effie
  13. squirrel
    Effie is a euphemism for a four letter word that starts with F.
    or a vehicle nomenclature that starts with F.
  14. The37Kid
    The37Kid
    Everything sold since 1903, sounds a bit vague. I did punch in EFFIE in an eBay search and turned up a postmark from EFFIE, Minnesota, 1955 Ford Pickup turned up 4100 hits.
  15. hotrodjack33
    hotrodjack33
    Look like an "F-bomb" to me...that's what I called my old F-100.;)
  16. ClarkH
    ClarkH
    Careful with your searches, guys. If the Urban Dictionary is anything to go on, that's one hell of a truck. :eek:
    Deuces, deadbeat, lumpy 63 and 4 others like this.
  17. flamedabone
    flamedabone
    She's a cutie. When you lower it, make sure and move the front axle forward about two inches, Those things are just a tad buck toothed and it gets worse when they are low.
    And, don't forget a build thread.
    -Abone.
    Deuces, Irish Mike, Okie Pete and 6 others like this.
  18. VespaJay
    VespaJay
    Nice looking project, look forward to the build.
    Ford truck nickname reference chart:
    Deuces, Cooon, Gasser 57 and 15 others like this.
  19. Bandit Billy
    Bandit Billy
    So…the first Gen ford truck came out in 51? What do they call the first 40 or so years worth? Oh yeah, hot rods!
  20. F-ONE
    F-ONE
    from Alabama
    Not counting the “big trucks such as TTS and AAs, the first truly purpose built Ford Light duty truck was 1937. Prior to ‘37 Ford trucks shared the same ch***is as a car.
    In the 1910s and 20s It was common to remove the turtle deck on a runabout or the rear section of a touring car and use a home made bed. Companies started making these beds.
    It was either 1925 or 1927 when Ford built a “truck” which was simply a runabout (coupe) with a factory built bed instead of a turtle deck.
    1948 was the first year for the Ford F series. The ‘48 Bonus Built was Fords first all new post war vehicle.
    1953 was the second generation F series and the first to use.....
    100.... 250...300....
    As far as I know there was not a F200 like there was an F2.
  21. Perfect
    Give it a bath
    Make it stop and go
    zoom zoom
  22. Budget36
    Budget36
    “F” 1, “F” 100
    See, starts with “F”. I’m certainly not saying it’s a definition.
    Just what I was used to the trucks being called at a much younger age.
  23. leon bee
    leon bee
  24. hotrodjack33
    hotrodjack33
    A slight correction: Ford light duty pickups used the same frame as p***enger cars up until 1941. The first Ford light duty pickups to use a pickup exclusive frame was 1942 which was more of a straight rail ladder frame and incorporated a parallel leaf spring front axle (while the p***enger cars used the transverse spring front axle up until 1948).
    And yes, 1925 was the first year Ford offered a factory pickup...which was a roadster with a 56" long, 40" wide bed replacing the turtle deck.
  25. 31Apickup
    31Apickup
    There’s a 54 on our local Craigslist now down to $1000 in similar condition.so temping to haul it home just don’t need a bunch of future projects sitting and rotting til I get to it.
    chryslerfan55, F-ONE and Budget36 like this.
  26. s55mercury66
    s55mercury66
    from SW Wyoming
    A friend had one many years ago, that he pulled the dead flathead from. When he replaced it with a 283/Powerglide combo from a '61 Impala, he used one bolt on the front mount kit that was a touch too long, binding up the fuel pump rod. After replacing the fuel pump several times, he gave up and used an electric Lucas pump, that ran for many years. When the 283 gave up (after 20 plus years of daily F100 service), it was finally discovered why the mechaniacal fuel pumps refused to pump.
  27. 57Fury440
    57Fury440
    Nice old truck. I'm a Mopar guy, but what's wrong with a 283? They are nice reliable engines and really easy to work on. The first engine I worked on was my older cousin's 265.
  28. poco
    poco
    from oklahoma
    It will make you a good driver and the 283 is a very good choice.
  29. Toms Dogs
    Toms Dogs
    from NJ
  30. Budget36
    Budget36
    The talk of the 283, reminded me of when I was 16/17 years old.
    To get to my girlfriend’s place. I had to drive through Turlock.
    The phone rang and her mom said just a minute, my dad was calling me.
    He says I was looking in the paper and a guy has ‘56 Ford pickup”. I think was maybe under 500, fair price in the ‘70s.
    Asked if I could get there and look at it by 9pm.
    Sure, so off I went.
    Was a decent truck, manual trans, and SBC. I don’t recall the size.
    So went home and told my dad about the truck and said a “sounded like a good running engine”. He asked and I told him a Chevy.
    Aw, no way.
    lol.
    Thing is years before that he put a BBC in his ‘57 Chevy PU.
    Before that a 292 in a ‘46 Chevy 1.5 ton truck.
    I never did ask him why he was against a SBC in a Ford, heck he was Chevrolet through and through.
    Yes, takes me sometimes to remember things.
    But I can say this, no one has ever given me a ‘55/6 Ford PU before!
