Technical Connecting a 1938 ford steering column to a 525 steering box ?
Discussion in 'The Hokey Ass Message Board' started by 38nailhead, May 27, 2024.
  1. 38nailhead
    38nailhead
    from England
    Hi . I’m at the stage with my build now that I’m on to the steering , I have rebuilt the front suspension on my 38 ford and now need to sort out the steering , I have the original steering column / bango wheel but the original steering box is in a rather bad way , so with my build came a new borgeson 525 steering box which I plan on using.
    now my question is how are people connecting the steering column to the steering box ?
    I have the steering u joint that matches the steering box but would need to know how else to proceed , any info / pictures would be very much appreciated.
    Thanks
    Tow Truck Tom likes this.
  2. raven
    raven
    You should be able to bridge the gap using Borgonsen joints. The double D configuration is the simplest approach.
    r
  3. Marty Strode
    Marty Strode
    This will be the same as yours, other than mine is column shift. The u-joint matches the steering box on one end and is 3/4 DD on the other. I took a stub of DD shaft and after cutting the early Ford shaft, I turned it down to plug int the Ford, and welded it. I also machined the br*** bushing at the base of the column. IMG_0590.jpg IMG_2188.JPG IMG_2191.JPG
    rusty1, rod1, Toms Dogs and 10 others like this.
  4. 38nailhead
    38nailhead
    from England
    Thanks for the information / pictures , exactly what I wanted to see . Could you explain to me abit more about the br*** bushing please ? As I read before in a post along time ago about adding a bearing lower down on the shaft .
    also nice work with the bracket
  5. manyolcars
    manyolcars
    its because the steering shaft is floppy in the steering column tube. I did the br*** bushing for my 39 Ford pickup too. (It had a toyota steering column when I got it)
    anthony myrick and 38nailhead like this.
  6. Marty Strode
    Marty Strode
    Also, you want a slight amount of space between the u-joint and the br*** bushing, and have the bushing reach at least a 3/4" up in the tube. Here is a shot from underneath. IMG_2186.JPG
    Jim Bouchard and 38nailhead like this.
  7. chevyfordman
    chevyfordman
    I made a fitting that fits into the end of the column but holds a needle roller bearing instead of a bushing.
  8. dln1949
    dln1949
    Say nailhead, if you do not have access to a machine shop drop by your local hardware store. Get the inside diameter of your column, they have bearings of different diameters that you can press in or hammer in depending. All the ones I’ve used were three quarters inch deep with an outside lip.
    38nailhead likes this.
  9. Marty Strode
    Marty Strode
    I think that is what is referred to as a "Wheel Barrow Bearing".
    vtx1800, rod1 and dwollam like this.
  10. Weedburner 40
    Weedburner 40
    WEEDETR make a kit for that very application.
    lothiandon1940 likes this.
  11. Can also cut the end of a later steering column of similar diameter tube and shaft and use the bearing.
    pprather likes this.
  12. goldmountain
    goldmountain
    You still need to figure out how to hook up the horn after doing all this.
  13. ramblin dan
    ramblin dan
    I bought bearings for a 1948 Ford column I retro fitted for my Deuce that are for a trailer. They are 3\4 inner dia. and the outside has a lip that seats into the end of the tube.
    anthony myrick likes this.
  14. pprather
    pprather
    Lots of good ideas, not much in the way of part numbers, to help this rodder from England.
  15. Mr48chev
    There are a lot of "Column saver bearings" around at a bunch of different prices sold to do the job.
    My experience says that if you do a bushing rather than a bearing everything has to be perfectly lined up or it can bind up or drag a bit. I had that happen when I made a Nylon bushing for the column on my 51 Merc when I swapped columns. I did a 15o mile road trip right after I got it together and ended up at Doc in the box with chest pains that ended up being inflamed chest muscles from working the steering wheel all day. Had a hell of a hot little nurse hooking me up to the ekg though. I switched that out for a bearing the next week.
    Not much getting around having to change the horn to an auxillary ****on on the side of the column or on the dash. There are some wireless horn ****on setups around though/
    https://wolo-mfg.com/horns/horn-acc...universal-wireless-remote-control-system.html
    eBay item number:364618395066
  16. If you know the OD and ID you can find just about anything
    Like this.
  17. 38nailhead
    38nailhead
    from England
    I found this part while searching today which I think will work well
    anthony myrick and pprather like this.
